Hello everyone,
I’m looking to make the S3 a little more track friendly. I have a non-mag ride version.
The set up is actually pretty comfy and fun but 50mph turns the body roll comes in and you have to fight it a bit so I’m hoping to tighten up the suspension.
Stock rates on a golf R:
195 lbs/in front
245 lbs/in rear
Stock on an RS3 (non mag)
326 lbs/inch front
404 lbs/inch rear
Audi and the tuning companies are reluctant to share data so take these with a grain of salt. But APR uses the same springs for the RS3 and the S3. They would not disclose the spring rate to me.
Neuspeed;
260 lbs/inch front
404 lbs/inch rear
So I suppose the question is: will RS3 springs physically fit? And are the dampers too soft a setting to work with springs that stiff? I’m not savvy enough to answer this question.
I’m not really into ‘stance’ lowering. The RS3 and S3 share the same ride height as far as I can tell and So I’m trying to avoid options that have a more visual goal than performance aspect. Really I’d avoid lowering at all if I could.
Thoughts and experience?
