Results 1 to 9 of 9
    Junior Member Two Rings
    Jun 18 2021
    Prov RI
    Is the DSG service an essential before getting the TCU (DSG) tune?
    Hey y’all!
    Im new to the Audi world and recently purchased a certified preowned 2017 Audi A3. The car currently has roughly 30,000 miles, I purchased it with 15,000. I’ve serviced it regularly since purchase. Im now looking into getting the APR stage 1 as well as the DSG tune and as everyone knows the internet is filled with all sorts of misinformation. In a post I read elsewhere and other things I’ve read said it would be a good idea to get a DSG service as well as a haldex service before getting the DSG tune. Im wondering if anyone on here has done the tune WITHOUT said services and if anyone did the tune WITH these services. Do people feel these are necessary? I know the DSG service is recommended around 35/45K miles, what about haldex services?
    Thanks everyone!
    Dec 25 2004
    Earth
    The service is based on miles....
    However its a 2017... Audi publishes the maintenance intervals...which states exactly what and when to change....
    https://www.audiusa.com/content/dam/...aintenance.pdf
    Yours maybe based on years old vise miles driven....
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Dec 25 2004
    Earth
    I diy both my DSG and Haldex. VW and Audi both changed haldex to 3 years reguardless of miles...so your haldex is over due....DSG would be a good idea to change cause yours is 4 years old...and the first DSG oil change is important.
    It cant hurt to change. Could if not...
    Jun 18 2021
    Prov RI
    Quote Originally Posted by MikTip View Post
    I was interested in performing both services myself but I don’t have the tool needed to check fluid temperature (DSG) which in turn is suppose to correlate to fluid levels. Any chance you can link that? They want to charge an arm and a leg to perform the DSG when you can by the kit (gravity fed) for like less than $200.
    Dec 25 2004
    Earth
    Quote Originally Posted by Slow8VA3 View Post
    I use VCDS for the temp check, however after DIYing my DSG few times now (5 years & 150,000 miles) I dont check the temp as I have learned it reaches the temp very quickly while performing the drain procedure. I drive my S3 up on ramps to drain and fill its DSG. So the DSG is already warm. By the time I remove the battery and its tray to get at the filter change the filter and refill with oil..its cooled enough to do the drain proceedure. I fill my DSG thru the filter AKA Top fill method. DQ250 takes 5.5 quarts for refill. Then I put everything back together. Start the car and perform the drain. The times I had VCDS looking at the gearbox temp...it reached it within a minute. I could see needing the temp check if you live where it freezes and the gearbox is ice cold when you drain and fill... It has a fill tube. So You cannot over fill it.
    OBD 11 may read the gearbox temp?
    Or some other OBD read
    The Hadlex...most pull the pump to inspect its screen. Which IMO is a good idea as it gives you visual indication of the Haldex internals.
    Separate from the Haldex...the rear diff has a 75w-90 side. I change this oil too.
    The DSG has a bevel box....separate from the DSG oil. The Bevel box uses 75w-90. I have found the bevel box oil needs changing...despite Audi saying lifetime fill.
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    You don't need the service to tune, but it's always a good idea to ensure the car is properly serviced and maintained. It is also highly advocated for on this forum to focus on preventative maintenance aka replace things before they fail.
    Some see it as over serving, but that approach has kept my cars on the road and performing well.
    2019 SQ5 Prestige
    Dec 25 2004
    Earth
    Quote Originally Posted by texasboy21 View Post
    You still have your A4?
    I see mine every once in a while!
    Apr 01 2007
    houston texas
    Not the B6 unfortunately, but the B7 is alive and well. Silver is the fastest.
    2019 SQ5 Prestige
    Veteran Member Four Rings Spinnetti's Avatar
    Dec 10 2004
    R8_LS400
    Dallas, TX
    B6 FTW! :)
    2008 R8 V8 Manual: Uni 93 ECU tune * Avior Exhaust * Spacers * R8 Puddle lights * Custom mats. All 12 of my other VAG cars are gone :(
