The block diagram below shows a basic plan for upgrading the factory B&O system. The plan is to retain the factory amplifier and initially all of the factory drivers. The rear door and D pillar speakers are mostly fill for front seat occupants and other people rarely sit in the back seats anyway as I have few friends. Audio Control makes decent single-chassis DSP amplifiers so their D-4.800 will be used to drive the front door woofers, tweeters and side dash mids. The factory amplifier will drive the center channel. An outboard mono amplifier will drive a single 10" or 12" subwoofer and the factory 6.5" spare tire sub will be removed.
The reason for installing the D-4.800 is to use its built in DSP and RTA to measure the output of the factory amplifier before its signals are sent to the front speakers. Testing and research has found the B&O system is actually 10 channels of amplification driving 14 individual speakers. The front and rear door tweeters are not separately driven, they are wired in parallel with the front dash side mids and the rear door woofers. Future upgrades may involve disconnecting the front door tweeters and adding passive or active filtering/amplification. The table below shows the pinouts and color codes for the factory 32 pin connector into the B&O amplifier. Of the eight speaker level output wires needed to connect the D-4.800 to the B&O system one color code in the vehicle did not match the factory wiring diagram. The right front door woofer in the vehicle was Brown/Yellow but the factory diagram shows this as Brown/Blue.
Using the D-4.800 to measure the output of the factory amplifier will allow for changes to the bandwidth, filtering, phase, etc. so that a summed full-range signal will be available to send out to the front speakers. This will allow the amplified response of the B&O system to be measured and to determine the capability of the factory speakers. In the future the front factory speakers may be upgraded. After the D-4.800 is installed and set up stay tuned for Before/After plots to show the system response. The reason for this post is to take personal bias out of what an audio upgrade really means and to show what the factory B&O system is capable of.
