Results 1 to 26 of 26
    Junior Member Two Rings
    Mar 02 2021
    East Coast
    Ongoing issue with coolant
    Now it’s been a month now battling an issue with a coolant leak, I’ve replaced the pcv some hard pipes under the supercharger that connects to the thermostat, also replaced the thermostat, one of the intercooler bricks because I knew it was going bad, What are some other things that can it be? I have a new water pump but mine isn’t making any sounds or leaking that I can see, I checked around the water pump as well and don’t see any dripping, car seems fine normally driving soon as you do a wot pull that’s when it seems to loose coolant, maybe other intercooler brick going bad? Coolant cap? I really need some help figuring this out before I go drop it off and have someone else look at it
    Veteran Member Three Rings GilliamOS's Avatar
    May 26 2015
    2013 A6 3.0T Prestige | 2013 Elantra GT
    Mormon Country
    Check the coolant solenoid valve under the car that connects to the ATF cooler. Lots of threads on it failing. When it does, it leaks into the wiring and ruins harnesses and controllers.
    2013 A6 3.0T - Slightly better than poverty package.
    2009 A4 2.0T Avant - Totaled
    2000 A4 1.8T - Sold
    1999 Millenia S - Sold, though it should've been crushed 'n cubed
    1997 A4 1.8T - Totaled, repaired, sold years later better than before
    1990 Maxima - Totaled from hail dents
    1987 Maxima - Sold
    1986 Golf Diesel - Rusted and fell apart
    Mar 02 2021
    East Coast
    I’ll check this out, no signs of it dripping out or beneath the car and I know it’s not the head gasket, pcv was bad and leaking coolant into engine fixed that now dealing with this last issue
    Veteran Member Three Rings WatchMeSpend's Avatar
    Mar 19 2019
    2016 A6 3.0T Technik S-Line
    Toronto/Ontario
    My coolant is slowly disappearing too. I think it is from the radiator or HX because I can smell it, but only when the car is very hot and the fans are on high. So walking towards the car from the back to the front, I can smell it, but when the fans are off the smell goes away. Right in front of the car the smell is being blown backwards. Face in the engine bay, the smell is coming from the rad side, not the engine.
    The hotter it is and the more frequent I drive in hot weather, the faster it goes.
    A sensor was replaced last year that was at the back top of the engine. That particular leak you could smell, engine off or on and easily locate it.
    Mar 02 2021
    East Coast
    I will get a coolant system failure sometimes and I read with vcds it says coolant pump, secondary pump is fine and pumping only thing I doubt is the waterpump I squeeze the pipe and I don’t really feel a flow or anything so I’m gonna change out the waterpump but does that explain the loss of coolant on wot? Evaporated? Not sure hopefully this helps
    Mar 02 2021
    East Coast
    Just drove normal for 30 mins just fine soon as wot get coolant fault at end of pull and coolant loss
    Jul 20 2017
    Kent, UK
    I've just got my 3.0 V6 TDI back from the garage for coolant leak. There was no coolant on the floor, but pooling in the bottom of the engine tray. Apparently it's a very common fault over here in the UK. £950 later, 6 hours of labour (a very good independant garage) it's sorted. Transpired my 3.0 V6 had two leaks at the bottom of the "V". A replacement thermostatic housing and a coolant regulating valve were to blame. They are both common failure points apparently but a bitch to get to, hence the engine strip and large labour cost.
    Mar 02 2021
    East Coast
    Checked the coolant solenoid for the trans not leaking checked everything on the coolant system no visual leaks no drips, car doesn’t loose coolant when driving very moderate soon as you get on it that’s when it’s having issues, replaced waterpump today no fix, I did replace the thermostat and crossover pipes no luck, I have one intercooler brick I didn’t change because I thought it was good maybe it is bad I tried to pressure test it but it seemed fine, maybe should test again. Making me feel like it’s a head gasket now I hope not any other suggestions on what I should do to test the system? Pressure held when I tested it, get home from a drive and the system is pressurized and holds pressure I don’t hear any leaks or hissing nor see any. I’m stumped
    Jun 19 2018
    21 Jeep Gladiator / 05 Tahoe Z71
    NH
    If you are getting an error message on your display, have you pulled the fault codes to determine what it actually is? You mention you read online what the error message is, but the fault codes through VCDS should give you more info.
    With everything you’ve replaced, I may suspect air in the system. When I had my 3.0T, I was told it was a self-burping system (local Audi dealer). Maybe try a coolant flush and vacuum bleed.
    2013 Q7 / Prestige / Mugello Blue Pearl
    2014 S7 Phantom Black on Black / B&O / DS1 ECU Stage 2 / SRM TCU tune / RS7 Inlets & Airbox / JXB Carrier / 034 Drivetrain Inserts / Cooling mods coming - SOLD
    2016 A6 3.0T / Premium + / Glacier White on Black / S-line / Sport Package w/ 20" wheels / No Mods - TOTALED
    Mar 29 2018
    Northeast
    Coolant pump and thermostat replaced at 38k miles. It's a fairly common issue.
    Sent from my ONEPLUS A6013 using Audizine Forum mobile app
    Jun 19 2018
    NH
    Quote Originally Posted by FirstAudiA6 View Post
    Fairly certain her already said he did… didn’t solve the issue
    Veteran Member Three Rings AudiC7Owners's Avatar
    Jan 14 2016
    Wilmington, NC
    Stupid question but are you checking your coolant levels when the car is warm and on level ground?
    Might not need to be said, but make sure you are always checking & topping off your coolant at operating temp.
    That being said, the common leak points are:
    -Thermostat
    -coolant pipe that goes from heater core to the t-stat
    -where the rubber coolant hoses connect to your sc crossover pipes
    -trans cooler valve under the car
    -water pump
    If none of those are showing visible signs of leaks then you need to do a pressure test on your coolant system to find the leak.
    Sent from my Llama using Tapatalk
    Kwikstix DIY Video Thread
    //2013 A6 Prestige 3.0T |IE Stage 2 Single Pulley | Berk TCU Tune | Injen Intake | Cende Valvetronic Full Exhaust | Gutted OEM Catalytic Converters | Merc Racing HX | H&R Sport Springs | 034 Motorsports Control Arms & Engine Mounts | Eurocode Drivetrain Mount Inserts | Eurocode Front & Rear Sway Bars + End Links | P3 Multi Gauge | StoneCarbon2009 RS Style Grille //
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    This likely has nothing to do with your issue, but FYI from the service manual:
    • The coolant level must be at that MAX marking when the engine is cold.
    • Coolant level may be above MAX marking with engine at operating temperature.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Mar 02 2021
    East Coast
    Yes I checked vcds the code hasn’t came back in a bit but I did replace waterpump pcv thermostat and the crossover pipe that breaks that’s goes into the thermostat car is fine when I drive under 2400 rpm if I get on it and at the end of the pull there is hardly any coolant left in the tank and the temps spike up I replaced the coolant tank cap as well no visual leaks outside or under the car, I did a vacuum fill as well didn’t seem to help
    Mar 02 2021
    East Coast
    Just found out something I want to try with the “n489” valve the vacuum port on the waterpump it could be bad I can’t feel water pumping thru the hose at idle maybe that’s how it’s suppose to be but I’m use to feeling pressure at idle, also I got a code for intake flaps stuck not opening which could be the issue with the control valve I have a couple laying around the house I’m gonna try to replace it, and I know the flaps aren’t stuck because I’ve undone the blower 70 times by now pretty experienced in my book on Audi to a point but this has me stumped
    Veteran Member Three Rings choy188's Avatar
    Jun 02 2019
    2019 S5 Sportback, 2022 Polestar 2; Sold: 2012 A6 3.0T, 2006 A6 4.2
    Danville, CA
    Quote Originally Posted by murdera6 View Post
    I would try that color changing fluid stuff that changes color when It contacts exhaust gases on your coolant reservoir and pray it's not a head gasket leak, I think it's called block tester combustion leak or something, i think they have it on amazon
    Sent from my SM-N986U1 using Tapatalk
    2019 S5 Sportback Prestige | Navarra Blue Metallic | Black | Options: Sport Package, Dynamic Steering, Cold/Warm Weather Package, Black Optics, Direct TPMS Retrofit
    Sold: 2012 A6 Prestige | Oolong Gray Metallic | Titanium Gray | Options: Innovation Pack, Cold Weather Pack | Mods: Lane Assist Retrofit, Injen Intake, 034 Stage 1 ECU+TCU
    Sold: 2006 A6 4.2 | Atlas Gray Metallic | Platinum | Options: Technology Pack, Cold Weather Pack
    Nov 03 2019
    San Francisco
    If you’re going through the whole tank of coolant in a single run and you don’t see any signs of coolant in the engine bay, it’s likely either head gasket or the other inter cooler bank leaking. In either scenario I’m surprised you don’t see any smoke out the tail pipe, but you did say you can smell it.
    Jun 19 2018
    NH
    Quote Originally Posted by TheBlackMarvel View Post
    If you’re going through the whole tank of coolant in a single run and you don’t see any signs of coolant in the engine bay, it’s likely either head gasket or the other inter cooler bank leaking. In either scenario I’m surprised you don’t see any smoke out there tail pipe, but you did say you can smell it.
    Or poor, muddy looking oil… fairly easy/common checks for a head gasket leak.
    Veteran Member Three Rings Burkeomatic's Avatar
    Feb 22 2021
    14 A8L 4.0T, 96 Corolla Wagon
    San Antonio
    Thing that sucks, is that if it is a leak from a coolant passage to the cylinder, none of that stuff will show. Those leaks can come and go. Though typically when those manifest themselves intermittently like that, the combustion goes into the cooling system forcing air in. I had an issue like that, it would pressurize the system with air, then it would look like the coolant went down. If you carefully unscrewed the reservoir, the coolant would magically return to normal level after the combustion gasses exited the cooling system.
    2014 A8L 4.0T - DS1 Stage 4/JHM TCU, FE Axlebreakers, E85
    Jan 14 2016
    Wilmington, NC
    Quote Originally Posted by Burkeomatic View Post
    What did you do to fix it? What was causing the system to pressurize?
    Mar 02 2021
    East Coast
    What did you do to fix this?
    Nov 28 2018
    Northern Virginia
    I myself had a coolant leak, and took it to in for service with that complaint. They said it had a failed motor mount, and subsequently replaced it. It was such a slow leak that I thought that maybe I misdiagnosed the fluid that was pooling in my garage. After the car sat for a few days, come to find out it had the same slow leak of the same fluid. I take it in, and they decide it is a coolant leak this time. (Gee, thanks.) Mine was from near the center of the engine block, requiring enough disassembly that the car required a full re-calibration of the parking sensors, radar, and so forth for the ACC, Brake Guard, and something else I can't remember. Thankfully, my extended warranty covered it all. Still sucks though.
    Feb 22 2021
    San Antonio
    Quote Originally Posted by AudiC7Owners View Post
    It wasn't on this car. Combustion was getting into the cooling passages, leak detector die would not pick it up. Turned out to be a bad HG and the head was warped. He could look in the cylinders to see if one of the pistons has been "steam cleaned." Most cars with a leak like that, the coolant cleans all of the carbon and gunk off the piston, and it looks brand new.
    Jan 14 2016
    Wilmington, NC
    Damn. You have me worried bc my coolant has dropped when warm and once I unscrew the cap it comes back after depressurizing.
    But I would assume there would be white smoke if I was burning coolant like that
    Feb 22 2021
    San Antonio
    NO, it was on a Chrysler Cordoba with a 4.8 LS motor. lol. A little is normal. Funny thing, is no coolant was leaving the car, it was just building huge amounts of pressure in the cooling system which wouldn't vent. My cousin drove it for another year with the radiator cap cracked until we finally pulled that head off.
    Jan 14 2016
    Wilmington, NC
    Lol gotcha. My coolant levels are staying the same so I think I'm good haha
