Results 1 to 18 of 18
    Dec 09 2020
    San Francisco, CA
    Left signal light and rear brake light bulb replacement
    Hi,
    I have a 2013 Audi S6 and getting a faulty bulb on the dashboard for either left signal or rear brake light. Has anyone replaced the bulbs before? Is there a step by step tutorial or video on how to do it?
    Established Member Two Rings Aaronl4903's Avatar
    Feb 22 2021
    HARRISBURG, PA
    Quote Originally Posted by AudiTurbo4me777 View Post
    Hi,
    As far as I’m aware, I don’t think there is a video. I remember seeing a video of a guy retrofitting C7.5 brake lights but it was sped up and chopped. If I were you I’d just go to those, they’re around $400-$500
    2018 S6 Phantom Black w/Sport Package
    Veteran Member Three Rings jcoleman_11's Avatar
    Apr 21 2016
    Toronto, ON
    There are no bulbs, you need to replace the whole assembly.
    Veteran Member Four Rings Alabama's Avatar
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Quote Originally Posted by jcoleman_11 View Post
    If it's the turn signal or brake lights, this is correct (lights are non-replaceable LEDs). The only owner replaceable bulbs in the rear are the rear "fog light" and the back up lights when in reverse gear. Presumably as these lights are infrequently used, some Audi engineer decided to save a little money on LEDs.
    2014 CPO S6, SunTek PPF (applied by CGS Vinyl), BlackVue dashcam (installed by Radio Active), Hawk Brake Pads/Zimmermann Rotors/Goodridge SS Brake Lines, H&R sway bars, Alu Kreuz, 034 Drivetrain Mount Inserts, SRM Driveshaft Carrier (mechanical/maintenance by Franklin Automotive)
    Aug 09 2014
    1987 Scirocco, 2019 Q7, 2022 Jetta SE 2024 A6
    Connecticut
    I have had a similar issue. mine is absolutely weather (rain) related.
    I had to replace the groments on the trunk lid,(forward corners) but still have the issue.
    I have the new light, but haven't changed it yet.
    Dash warning light goes on when it rains, and off as soon as it dries out.
    Here is another post on the topic. https://www.audizine.com/forum/showt...light-went-out
    2014 A6 TDI Prestige
    Dec 09 2020
    San Francisco, CA
    Quote Originally Posted by 67ITB View Post
    I think it just started happening after I did a good wash on my car just recently? Where do you get the grommets? I guess I have to wait til the car fully dries out? Hopefully the issue goes away.
    Veteran Member Three Rings A665's Avatar
    Oct 26 2019
    Mid-Atlantic
    I’m getting the fault warning now about once per month, then it goes away the next time I start the vehicle. There’s never any actual taillight failure, just the fault warning on my dash. I presume this is an indication of fluctuating resistance, which suggests a weak or failing connection rather than a failure of the taillight assembly itself.
    2013 Audi A6 3.0T Prestige | S-Line / Sport | Full LED | 034 Stage 1 ECU+TCU | ECS Trans Mount Insert | JHM Driveshaft Carrier Bushing | FormulaOne Pinnacle Tint
    Aug 09 2014
    Connecticut
    I got them at the dealer, they are about the size of a quarter, I think cost only about $1. one of mine was completely torn so I had assumed it was/is/caused my problem.
    part # is 4H0 827 589 B
    (pretty sure the third character is a number zero "0" and not a letter "O" but my notes weren't clear)
    Veteran Member Three Rings prestige.phantom's Avatar
    Jul 16 2018
    Connecticut
    Quote Originally Posted by A665 View Post
    Both of my inner taillights have failed. Each time, it started with a dash fault warning (once a month) that progressively got more frequent until it came up nearly every time I started the car. At first, the tail light was perfect, worked absolutely fine even when the warning was on the dash. Eventually, however, the issue started to actually pop up (in both cases it was the LED section that turns on when the headlights are on). Sometimes it would flicker, others it was noticeably dimmer than when new, and eventually it would just turn off completely.
    | Phantom Black Pearl | Nougat Brown interior | LED Headlights | Cold Weather PKG | 20" Sport PKG Wheels & 3 Spoke Heated Wheel | Fine Grain Ash Natural Inlays | Michelin Pilot Sport AS3+ Y | OEM "Rings" Puddle Lights |
    | AWE Touring Exhaust | JHM Non-Res DPs | Eibach Pro Kit & Bilstein B4 Sport Shocks | Eurocode Trans Mount | JBX Carrier | S8 Front Brakes w/ EBC Red Pads | 034 ECU 93 STG 1, TCU, Rear Swaybar, and Endlinks |
    IG: @prestige.phantom @ctautoart
    Oct 26 2019
    Mid-Atlantic
    Quote Originally Posted by prestige.phantom View Post
    Please remind me what is the true solution. Is it replacing the taillight alone, refurbishing the harness connection for better contact, replacing grommets, or all of the above?
    Jul 16 2018
    Connecticut
    If you notice the gromments are ripped, torn, damaged, etc. then you could try replacing that, but generally speaking, the only way to fix these taillights is to replace the whole tail light. I replaced mine with a used set. I got my right one off a salvage car on eBay for like $175 and my left one for the cost of shipping from a forum member who swapped their OEM lights for aftermarket ones. I have had the eBay one on for over a year now, and the fault has not returned and it works perfectly. I just installed the other one last week, and I have had no issues with faults or lights since.
    Just for context, dealer quoted me like $1000 to replace ONE of my inner tail light assemblies. If you want a brand new one, there are plenty of OEM wholesale sites online where you can buy the part ~30% off. Install is extremely easy, it takes like 15 minutes.
    Oct 26 2019
    Mid-Atlantic
    Got it. Thanks.
    And confirming that the replacement part is the inner tail light assembly only.
    Apr 21 2016
    Toronto, ON
    Rockauto sells literally the OEM part (Valeo) without an Audi badge for $220-$260 depending on which one you need. No reason to buy used.
    Jul 16 2018
    Connecticut
    Got it. Thanks.
    Whichever is broken. It could be any of the 4 assemblies.
    - - - Updated - - -
    Good to know.
    Veteran Member Four Rings ichi d's Avatar
    May 10 2013
    Toronto,ON
    i have a full set of oem all working for sale shoot me a pm if anyone is interested.
    C7 S6 / AWE Touring / -14mm / EuroTails /
    Sep 16 2020
    West Michigan
    - - - Updated - - -
    Good to know.
    Amazon as well.
    2012 A6 Prestige - APR single pulley via Fluidampr 189, Injen intake+RS7 airbox, IE HPFP, EPL TCU, JHM HX, 034 motor mounts, Eurocode drivetrain inserts, gutted cats - 034 tunes purchased, not installed.
    Oct 26 2019
    Mid-Atlantic
    Ordered the Valeo (OEM-quality) unit thru Amazon.
    Thanks
    Sep 16 2020
    West Michigan
    - - - Updated - - -
    Good to know.
    Thanks
    Your factory original ones will say Valeo on them and have a sticker elsewhere with the Audi Ring Logo. At least mine did.
    That is why I did not feel bad about buying the Valeo units elsewhere.
