So, 1995.5 Audi S6 with a 5.2 V10 out of a 2007 C6 S6 (435hp). The URS6 chassis had 290,000 when swapped, and the engine had 106,000. I've since then put about 10,000 miles on this car since the swap has been done... NOT. A. SINGLE. FAILURE.
It is extremely hard for me to put everything into words so if you feel I missed something, ask away. I don't get offended, just laugh in sad tears...
Engine/Trans
5.2 V10
- Carbon Cleaning 10k ago
- B7 RS4 Ringer Racing Stage 5 Clutch/Flywheel
- B7 RS4 Rear Timing Cover
- B7 RS4 Starter
- 2006 A3 2.0T Alternator
- Coilpacks (10)
- Spark Plugs (10)
- Injector Reseal (10)
- Oil Pan Reseal
- Valve Cover Gaskets
- Intake Manifold Gaskets
- Exhaust Manifold Gaskets
- Rear Coolant Crossover Tube Inner + Outter O-Rings
- Oil Cooler O Rings
- Oil Filter Housing O-Rings
- Fuel Pressure Sensor
Exhaust
- 5.2 Exhaust Manifold Flanges Cut on Plasma Table from a shop out in PA
- 1 1/2" Primary Tubing to a 3" Collector
- Dual 3" Midsection to Single 4" Axle-Back
- Summit Racing Electic Cutout (4")
- Vibrant Muffler (4")
Cooling
- Summit Racing Triple Pass Radiator
- Derale Fan + Shroud (2400cfm)
- Painless Performance Fan Relay Kit (195 on/185 off)
Electronics
- Factory C6 S6 ECU's with almost every code out imaginable. Runs like a champ thanks to Blake Beadle.
- OBD2 was transferred over and works great with OBD11 or VAGCOM.
- C6 S6 Throttle Pedal
- AEM CD5 Dash with GPS Speed runs off CANBUS from Factory C6 S6 OBD2)
- AEM X Series Coolant Temp Gauge (Redundant)
- AEM X Series Wideband Gauge
Chassis
- Koni Yellow Shocks
- H&R Green Springs
- ESM Wheels... Reps lol 5x112 18x9.5 wrapped in 235/40/18 Tires (300 miles)
Also, have another 5.2 I can throw in as well as an R8 Intake Manifold...
Oh, and the radio works too!
$32,500
Tuckerton, NJ 08087
Having issues adding pictures to Flickr at the moment and will add pictures as they upload, feel free to have a look at my Instagram RS6_Jolio in the meantime
