Results 1 to 10 of 10
    Junior Member Two Rings jonbishop's Avatar
    May 28 2021
    Glendora
    Where is the MAF sensor?
    Cleaning the air filter(k&n) and wanted to clean the MAF as well but since I’m new to this vehicle idk where it is so does someone have a video or pic of where it is?....
    Mar 11 2007
    Colorado Springs
    Just to the left of the 4 rings on the cover. follow the intake and where it curves and straightens. That's it, it's in your pic.
    2022 Q8 S line Prestige Stock
    2012 A7Plus APR Stage II+ UC
    2012 A8L 4.2
    Still own them all...
    May 28 2021
    Glendora
    Is it that?
    Mar 11 2007
    Colorado Springs
    That's it!
    2012 A8L 4.2
    May 28 2021
    Glendora
    Quote Originally Posted by A6sport View Post
    That's it!
    Sweeetttt thank youuuuu, after seeing how dirty the air filter was im sure it’s gonna be dirty too
    Junior Member One Ring
    May 11 2019
    Saskatoon, SK
    That is not a MAF sensor in the intake tube.
    I believe the Supercharged V6 work of a MAP sensor that detects pressure and vacuum changes in the intake manifold.
    Saskatoon Auto Connection
    2013 Audi Q7 Prestige 3.0T
    2011 Silverado 6.2
    Oct 19 2009
    Hendersonville, TN
    Quote Originally Posted by dsmmace View Post
    My ‘13 3.0TFSI doesn’t have one… must be controlled by MAP sensor
    May 28 2021
    Glendora
    Yup it’s like a vent hose to something, next question is cleaning the throttle body by itself or should I just clean it when I change out the supercharger oil? Is the throttle body difficult to get off?
    May 11 2019
    Saskatoon, SK
    Quote Originally Posted by jonbishop View Post
    I clean them on the vehicle, but be warned, any adjustment in the 'learned' position can cause a rough running issue and to have the idle speed and or idle air values relearnt with a scan tool. Do not have the ignition on while cleaning.
    2011 Silverado 6.2
    Veteran Member Four Rings gdawg'05a4's Avatar
    May 03 2005
    '17 Q7, '95 Audi 90 AAN Swap
    Boston
    No MAF on the 3.0T. Two MAP sensors, one on each side of the supercharger.
    '17 Q7 3.0T | Graphite Gray | Rock Gray || Prestige | Cold Weather | Tow
    '14 A6 3.0T | Daytona Gray | Black || Prestige | Cold Weather | Driver Assist | Rear Sunshades | 19" Sport
    EPL S2 + TCU
    '95 90 Quattro Sport MT5 | Pearl | Black || 20vT AAN swap
    Previous Cars:
    '12 S4 | '13 Q5 2.0T | '11 A4 2.0TQ | '07 A4 2.0TQ | '06 S4 25quattro | '05 A4 1.8TQ MT6
