Results 1 to 18 of 18
    Jul 09 2016
    new york
    9K to replace rear main seal on B8.5 S4
    Hello, so i noticed a small leak under car around the transmission. I took car to dealership and was quoted $9K to repair leak. i included there statement and break down of cost below. has anyone ran into a similar scenario? i would honestly rather sell the car then pay 9K for a leak.
    Car is a 2014 S4 with 44,000 miles and automatic transmission.
    Senior Member Three Rings no thx's Avatar
    Feb 26 2017
    DTW
    Quote Originally Posted by daniel.718 View Post
    If it's a rear main seal leak it shouldn't be red ......?
    Sent from my SM-G970U1 using Tapatalk
    Feb 26 2017
    DTW
    Also go somewhere else lol. Like anywhere else
    Veteran Member Four Rings fastboatster's Avatar
    Apr 23 2019
    2010 Audi A4 3.0T, lol
    CA
    first off, confirm this is really the rear main seal and not your oild filter housing and/or it's gasket. second, find somebody who charges more reasonable labor, should be about 10-11 hrs if it's really your rear main seal.
    P.S. is that really a quote for a rear main seal? It doesn't say anything about that, did they tell you that specifically or just offered a price to fix that leak?
    Jan 28 2021
    Orange County, CA
    If it's not warranty work, avoid the dealership at all costs. Find a trusted Audi/VW independent shop nearby and they'll take much better care of your car and at a cheaper price.
    Mar 23 2018
    Quote Originally Posted by RosSauce View Post
    this. No Name Motorsport in LI is a solid shop if you’re close
    Veteran Member Four Rings f1torrents's Avatar
    Apr 27 2012
    B8.5 6MT S5 Coupe / B9.5 S5 Coupe
    Guelph
    Even the $190 to look under the car and see a leak is insane.
    And how red fluid is diagnosed as a rear main is beyond me???
    Veteran Member Three Rings wangshuo1989's Avatar
    Jan 09 2016
    Only red fluid in this car is coolant, I could be wrong though.
    2013 S5 Misano Red, DSG, B&O, Sport Diff, MMI+, JHM 207mm crank pulley (7PK1370 Contitech belt), APR Stage II Dual Pulley, APR TCU tune, APR CPS, CR15, IE CAI
    2018 XC90 Inscription, B&W sound, Convenience Pkg, Air suspension
    2014 Mercedes E350 rwd
    2021 BMW 540i
    Apr 27 2012
    Guelph
    The DSG fluid is clear is it not?
    Jul 31 2016
    PA
    For 9k you could just buy a new engine....
    Sent from my SM-G988U using Audizine Forum mobile app
    Custom DP 194/57 E40 Water-Meth (Aquamist) | BG HPT ZF8 Tune | APR CPS with AWE Reservoir (Divorced Coolant Loop) | APR Open Intake and 034 Intake Tube | RSE Heat Shielded HFCs | CTS Downpipes with Vibrant UQ Resonators Added | AWE Touring Exhaust | 034 RSB | Bilstein B8 Shocks and H&R -3 Springs | ECS Trans and Drivetrain Inserts | 034 Trans and Motor Mounts | Moog Front End Links | Headlight Projector Retrofit and Painted Housings
    Veteran Member Three Rings B7TitaniumA4's Avatar
    Mar 26 2016
    Montgomery County, PA
    I’d do it for 2k lol
    Though if you’re going that deep, do it all while it’s open like I did.
    Sounds like it’s not oil leaking tho, I agree, get a second opinion!!!
    My engine not to long ago…
    My engine now… ready to go back in.
    Apr 27 2012
    Guelph
    Great work...
    Veteran Member Four Rings Ashtonts's Avatar
    Jan 17 2015
    That’s a crackhead price. I was getting quotes closer to $1k in labor to do a clutch job including the rear main seal
    2007 Porsche Cayman | 5MT
    Jul 31 2020
    Austin
    Rear main seal is easy once you have trans dropped. That’s highway robbery
    Veteran Member Four Rings blackfunk's Avatar
    Jul 12 2012
    That's call a fuck off price. They price it that way so you'll go someplace else because they don't want to be bothered.
    Life has taught me never try to make something idiot proof, they'll simply come up with a better idiot.
    I'd agree with you but then we'd both be wrong.
    I have neither the time, nor the crayons to explain this to you properly.
    Aug 08 2018
    Quote Originally Posted by blackfunk View Post
    Totally agree!
    2016 S4 P+ Ibis White | DSG | Nappa leather interior | Technology Package | Sports Diff | Black Optics | CR-15
    Apr 04 2012
    MSP
    This.
    Mar 26 2016
    Lol
