Results 1 to 8 of 8
    Veteran Member Three Rings thorlax240's Avatar
    Jun 27 2017
    Boston, MA
    C7/C7.5 A6 Lowering Springs
    I have a C7.5 A6 S-line and I want to install some Eibach or H&R lowering springs.
    Somebody was selling Eibach springs on AZ but they're no longer for sale.
    C7 Glacier S6 APR STG2 | APR dp's | AWE touring | Roc Euro | Eurocode F&R sways | 20" RS7 forged | 20" OEM rotors | -17mm VCDS | 15% Luminex | RS6 grill | transmission/differential inserts
    C7.5 Mythos A6 APR STG2 ECU+TCU | Single Pulley | Injen Intake | Eurocode F&R sways | H&R Springs | 17.5mm + 20mm spacers | 35% Luminex | transmission/differential inserts
    Veteran Member Three Rings bonafyd's Avatar
    Nov 27 2008
    New Jerz
    I have a brand new set of H&R lowering springs.
    Bagged C7.5 aka FISHBOWL
    |Airlift Bags|Accuair E-Level|Endo-CVT|I-Level|Aluminum Mirror covers|Aspherical Mirrors|Full 40% Ceramic Tint with Windshield|
    |AWE Touring Exhaust|RS7 Airbox|Flat Bottom Wheel|S7 Wheels|S-Line Sport Pkg|LED Headlamps|Frameless Mirror|
    |S6 Oem Trunk Spoiler|RS Pedals| RS Door Handles|S6 Diffuser|RS6 CT3 Carbon Fiber| RS6 Shift Knob|IE Intake|IE TCU Tune|
    Sep 16 2020
    West Michigan
    Aren't the stock S line springs a ~1 inch drop already? (30mm)
    I would bet the Eibach to be pretty close to that since they advertise as a 1 inch drop from standard suspension.
    2012 A6 Prestige - APR single pulley via Fluidampr 189, Injen intake+RS7 airbox, IE HPFP, EPL TCU, JHM HX, 034 motor mounts, Eurocode drivetrain inserts, gutted cats - 034 tunes purchased, not installed.
    Jun 27 2017
    Boston, MA
    Quote Originally Posted by sepheroth86 View Post
    Honestly I wasn't sure myself but below are some snippets from my research. Maybe I need to get some forum members to do some center wheel-to-arch measurements for me??
    "The audi sport springs on us spec cars have a higher height than H&R and Eibach. Ride height for the 3 are in this order: sport suspension, Eibach, and H&R being the lowest. I will mention, in European markets there is the sport suspension and an S-line suspension that is 10mm lower than standard sport."
    "The Eibach Pro springs are a 30mm drop so on the S-line model you'd see a max drop of 15mm but more towards 10mm."
    Veteran Member Four Rings Shane Horning's Avatar
    Nov 16 2018
    2012 A6 Prestige IE dual pulley. custom trans tune. mercracing hx. autotech hpfp.
    Upstate. New York.
    Quote Originally Posted by thorlax240 View Post
    Honestly I'm not quite sure, maybe I need to do a bit more research. My goal is definitely to lower it beyond S-line suspension by about an inch or so.
    H&r sport springs will be about right for you then.
    Nov 27 2008
    New Jerz
    Op I replied to your message.
    Sep 16 2020
    West Michigan
    https://www.audizine.com/forum/showt...ort-Springs-A7
    In this thread, the H&R appear to be approximately 1/2" lower than USDM Sport suspension. H&R advertises a 1-1/2" drop from standard.
    This leads me to believe that Eibach will be very comparable to factory Sport Suspension.
    Jun 27 2017
    Boston, MA
    I think you're right
