I guess I was confused about your original post about what you meant for "my hands on a cheap dab receiver on ebay". Is this some 3rd party receiver you plan to input to the Audi system via aux or such? Or do you mean a DAB equipped radio unit for MMI 3G, replacing your previous radio unit. So I presume part number 4F0 035 061... or 4G0 035 061...? And by "no Bose", I presume you mean "not B&O". So you have either the 4-speaker basic, 8-speaker basic plus, or 10-speaker standard sound system.
I note a comment about the DAB tuner in the MMI 3G radio unit: "The DAB tuner is encoded for the country of use, because there are various intermediate frequency bands between channels that can be can be used. If the DAB tuner is not correctly encoded, then reception will be impaired."
I don't know if that is of any relevance to you.
We can see from:
https://audi.7zap.com/en/rdw/audi+a4...6/0/035-35015/
that it appears there are four amplifier units, 21, 22, 23, and 24.
21, R111, antenna amp 2, right d-pillar, will be 8K9 035 225 N (
https://www.ebay.co.uk/itm/Audi-A4-S...-/303139813108), only if DAB equipped. This supports the black DAB connection to the radio.
22, R112, antenna amp 3, left c-pillar, will be 8K9 035 225 (
https://www.ebay.com/itm/174495911072). This supports the yellow AM/FM1 connection to the radio and the gray CLS connection to the J393. If TV equipped, then it will instead be revision C (
https://archiwum.allegro.pl/oferta/w...636442666.html). C also supports the TV3 connection to R78 tv tuner.
23, R24, antenna amp 1, upper left of rear lid, will be 8K9 035 225 A (
https://www.ebay.com/itm/372651304960). This supports the white FM2 connection to the radio. If TV equipped, then it will instead be revision E (
https://www.ebay.de/itm/353321132593). E also supports the TV2 connection to the R78 tv tuner.
24, R113, antenna amp 4, right c-pillar, will be 8K9 035 225 J (no pics, I presume it looks like G but only the green plug), only if TV equipped. This supports the green TV1 connection to the R78 tv tuner. (the B and G rev stuff is for MMI 2G era, FM3/TV3).
So it looks like you added "B", which is the MMI 2G switching diversity FM tuning FM3 connection. You need N.
