Results 1 to 22 of 22
    Mar 30 2018
    Kentucky
    Maintenance List
    Hey all, ever since I had to swap my B8 engine for a B8.5 I've become very intentional with maintaining and servicing my vehicles. I just purchased a 2018 Q5 for my wife and am putting together a maintenance list where I can track and monitor service history.
    I'm very much a rookie at all of this, so please let me know what I'm missing or if you have any recommendation for my current list. Thanks all.
    Service List/Service Frequency (miles):
    Oil Change / 5,000
    Rotate Tires / 5,000
    Replace Spark Plugs / 30,000
    Replace Engine Air Filter / 60,000
    Replace Cabin Air Filter / 60,000
    Flush Radiator Fluid / 60,000
    Transmission Oil Change / 60,000
    Front/Rear Differential Oil Change / 60,000
    Transfer Case Oil Change / 60,000
    Flush Brake Fluid with purchase of new tires
    Align Car with purchase of new tires
    Check Rotors & Brake Pads with each tire rotation
    Monitor Serpentine Belt wear
    Fuel injectors?
    PCV Valve?
    Established Member Two Rings TLR_0125's Avatar
    Apr 23 2019
    East Coast
    Dec 01 2020
    2014 Q5 2.0T
    2018 Q5 is B9 so you would need to head over to that forum.... but Audi publishes service schedules. Many of the items you have listed are on there.
    https://www.audiusa.com/content/dam/...ges_022317.pdf
    Transmission ATF should be done every 75K miles per the manufacturer if you have the ZF 8HP. Same with diffs. Doing it earlier like 60K or 50K is not a terrible idea if you are so inclined. Also change the filter and put on a new gasket -- both OE.
    Always get an alignment with new tires.
    Check brake fluid moisture % before just blindly changing it.
    Yes 5,000 oil change interval is good.
    I do the PCV every 50K as a general rule of thumb... else if you want you can use a manometer to monitor your crankcase vacuum to know when it needs to be replaced.
    Good luck
    Mar 30 2018
    Kentucky
    Just trying to pick everyone's brains here. My intention is to help my cars run smooth and for many many years. I can only take Audi's suggestions with a grain of salt after my issues with my engine and their "lifetime transmission fluid".
    PCV every 50k, I like it. Cheers.
    Jul 16 2018
    Atlanta
    But a B8 Q5 would have a ZF transmission. A B9 Q5 would have a DSG transmission. Very different maintenance concerns. My ZF is still on the original fluid at 223k miles. An Audi DSG would never survive that. And the DSG in the B9 (DL382) is different from the one in the B8 (DL501). Audi would still qualify the front and rear diff fluids as lifetime, but the ATF in the DSG is most certainly not marked lifetime.
    Likewise, the EA888 Gen2 engine in the US B8 is different enough from the EA888 Gen3 evo/b-cycle in the B9 that you shouldn't relate too much about the common issues of each. Except the coolant pump it seems.
    The B9 A4 forum here is pretty dead compared to the one at audiworld. While it's the opposite for the B8 A4 forum. I have no clue about the B9 Q5 forums; I don't drop into those.
    Also remember that a B9 Q5 has the quattro "ultra", so you don't have a real center diff. Just a slip clutch that electronics engage when they feel like it.
    Feb 15 2016
    Cambridge,Ontario
    always best to stick to the correct forum ...
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Mar 30 2018
    Kentucky
    Sorry if I was misleading, the list is for my A4. The thought came to mind because I recently purchased a new car. While of course there are variations between the A4 B8 and Q5 B9 platforms, I was speaking in more general terms (while they may have different transmissions you should still service the fluid, and whether that's 60k vs 70k miles, it doesn't matter to me, I'd rather do it at 60k then).
    Oct 15 2019
    '12 TTRS, '10 A4 Avant
    Golden, CO
    I'd add cleaning the carbon from the intake valves. Every 75k or so?
    Junior Member One Ring
    Feb 17 2019
    Houston
    Quote Originally Posted by hamfisted View Post
    Is this the same as "carbon cleaning / walnut blasting"? If so, I had noticeable gas/mileage drop of around 12% at 55k before getting one done at 70k miles.
    I was then told by my very reputable Audi mechanic in Houston that it's better to get one done at 60k miles - based off my experience, I'd have to agree with him!
    If you aren't referring to carbon cleaning, ignore my overreaching reply!
    Feb 17 2019
    Houston
    Quote Originally Posted by Misticvega View Post
    I have a b8.5 allroad and also am very proactive in maintenance - I was recommended by one of the best audi mechanics in my city (take that with a grain of salt, of course) that even the "lifetime transmission fluid" should be changed around every 75k miles. Not sure if this includes getting the filter changed as well. But I went ahead and flushed mine at 35k miles (no filter replacement), because I purchased mine used. However, I'm going to do the fluid replacement and filter around the 75k mark just based off his recommendation.
    Dec 01 2020
    2014 Q5 2.0T
    Quote Originally Posted by Zeroed View Post
    Your mechanic is just relaying the information from the manufacturer. Assuming you have the ZF 8HP, changing the fluid and filter both every 75K is the recommendation of the manufacturer. "Lifetime" to Audi only means until it's not their problem anymore. Pretty much there is no such thing as any lifetime fluid......
    Veteran Member Three Rings Chillaxin's Avatar
    Mar 28 2018
    Jacksonville FL
    Or before every oil change: http://www.crcindustries.com/gdi/
    Veteran Member Four Rings Spawne32's Avatar
    Nov 20 2016
    Quote Originally Posted by Chillaxin View Post
    junk.
    2019 Audi A4 Quattro Premium Plus | Manhattan Gray | APR Stage 1 | ECS Intercooler Kit
    *goodbye sweet prince* 2009 Audi A4 Quattro Premium | Ibis White | CTS K04 Hybrid | 034 Motorsports HFC | REV9 Intercooler | Ward Performance Tuning
    Visit us on FB @ Audi B9-B9.5 A4 Owners Official Group
    Mar 28 2018
    Jacksonville FL
    Quote Originally Posted by Spawne32 View Post
    junk.
    How many times have you used it? Solid trolling bro.
    Nov 20 2016
    Suggesting something with no evidence supporting it working is a troll in itself. Anyone with any sort of mechanical experience knows that these sprays don't work on this kind of carbon buildup.
    Oct 15 2019
    Golden, CO
    Yes, that's what I was referring to. The buildup is gradual so the cleaning interval mileage isn't critical. (not like an oil change or anything)
    This video shows that chemical treatments don't really work:
    https://youtu.be/PkUq5mp2plc
    Shouldn't be surprising to anyone that's actually done a true carbon cleaning. It gets baked on the valves and needs some sort of mechanical removal to really get it off. Not the same as cleaning throttle bodies or whatever. When I've done it I've used throttle body cleaner to try and loosen any crud before using the picks & walnut blast, but the cleaner doesn't really do much.
    Mar 30 2018
    Kentucky
    Good thinking. Thank you!
    If I made it this far, is it worth taking a look at fuel injectors or not until they become a problem?
    Dec 01 2020
    2014 Q5 2.0T
    Don't mess with the fuel injectors if there is nothing wrong with them. But don't ever run anything other than top tier name-brand gas........ the #1 killer of injectors is cheap quality gas with cheap detergent packages. You can also run a bottle of Techron once per oil change, just before the oil change.
    Veteran Member Four Rings bb-tt's Avatar
    Apr 30 2018
    2017 TTS, 2011 Avant, 82 c3 vette, 2002 TT (sold), 2010 CC (sold), 2013 Jetta, 2018 Q7, 2019 Tiguan
    DFW, TX
    Quote Originally Posted by Smac770 View Post
    omg SMAC i am disappointed in you!!!!!! just did mine (zf) last week in the garage on jack stands, was a PITA but really not that hard. Snaked a tube between engine and firewall and had daughter pour the fluid since i dont have a fluid extractor/pump. Think it was previous over-serviced (or maybe from factory) with the transmission at ambient temp i opened the fill port before trying to open the drain. Fluid cam gushing out.
    2011 A4 Avant S-line Prestige
    Nothing to see here, keep moving!
    WPT+
    Mar 28 2018
    Jacksonville FL
    Way to answer the question bud. I've logged lower misfire counts, better fuel trims, and better mileage after using the product, but again, HOW MANY TIMES HAVE YOU USED IT? Just because you read something about carbon buildup doesn't make you a chemical engineer does it?
    Nov 20 2016
    Are you talking to me? Because if you are you better come with better evidence than that snarky attitude and youtube videos from chrisfix.
    Mar 28 2018
    Jacksonville FL
    Are you talking to me? If you are, you'd better come with better evidence that this product doesn't work than a derpy attitude and youtube videos from this guy.
