Results 1 to 4 of 4
    Apr 22 2021
    san diego/ ca
    upgrading coils and spark plugs when tuning to stage 2
    getting a full exhaust and intercooler soon and was going to tune to stage 2 right after those were installed. The question is should i upgrade coils and plugs at the same time i do the tune or before/after?
    also, any recommendations on coils and plugs?
    i was leaning towards apr coils and NGK R7437-9 Racing Spark Plugs.
    Jul 17 2016
    El Paso, TX
    Do the tune at the same time as the mods or you’ll be throwing codes and running like shit.
    As for plugs and coils… stick to the factory stuff or go with an iridium tipped plug. That’s about it. There’s no magic in coil packs and honestly you’re likely just throwing money away if you go all out. The spark and current is regulated. And bigger coil pack won’t do anything but amplify the voltage (same current though) and that’s pretty meaningless in the end. The only time I’d modify the ignition is if it were on an older vehicle or if I were an F1 driver. These newer cars are fully controlled electrically. Don’t bother.
    Good luck
    Veteran Member Four Rings Sly Raskal's Avatar
    Jan 22 2007
    Fontana, CA
    Upgrading the intercooler would contribute to throwing a code? Never heard of this before.
    -Anil
    2019 A4 Sedan, Nardo Gray, 45TFSI, Prestige Plus, S-Line, Quattro, Black-Optic, PPF, Ceramic Paint Coating, Ceramic Tint, Audi Black Door Handle Kit
    Senior Member Two Rings AudiSportDre's Avatar
    Mar 14 2020
    B5 1.8T track car (soon to come)
    Worcester, MA
    Quote Originally Posted by Sly Raskal View Post
    I believe he specifically meant the cat as that’s the most crucible piece required for a stage 2 tune. Everything else quite honestly doesn’t matter and it’s a recommendation. Although the car would perform loads better with everything.
    If you throw on a high flow cat without the Stg 2 tune it will throw a CEL. Otherwise all of the other mods should be totally fine. I myself have an upgraded intercooler and no lights.
    2018 B9 Audi A4 P+ S-Line Quattro Mythos Black
    Stance is dumb performance is fun.
