I am in the midst of an upgrade on my son's 1.8T B6 150A alternator - going the route of the Valeo B8 180A version with the B7 Brush/Regulator.
I received a used/low mile alternator from a wrecker/eBay, and testing the diodes shows that the "B post" to ground flows as it should (one way only)...but when testing individual diodes in the rectifier one side of the alternator is passing current both ways (six out of the 12 diodes). I then tested the one I pulled out of the car, and all of the diodes pass current both ways, but the overall "B post" test is also fine. Both alternators test fine at the local NAPA, and the car had no issues with charging or discharging. In the midst of a T-Belt and hose change, so I can't do the AC test at the battery until that is done (waiting on multiple parts from ECS and FCP).
Any thoughts on why, or is this just how Valeo alternators work? The last thing I want to do is have to replace the alternator shortly after install, or to damage the car with AC bleeding into the system.
