Looks like my radiator developed a leak at the bottom left corner, probably due to corrosion with leaves and crap collecting there. Do I have to remove the front bumper to remove the radiator? I’m at the stage where I removed all the splash shields, upper and lower radiator hoses are disconnected, overflow hose is disconnected, top rubber fittings are also gone. Does the fan assembly come out first or can the radiator be removed with it attached? Any help is appreciated. Thanks
