Results 1 to 27 of 27
    Junior Member Two Rings
    Apr 10 2019
    Supercharger belt idler pulley replacement
    Hi all, I have diagnosed a squeaky noise from my idler pulley, has anone replaced this before, looking for any hints/tips or steps to replace.
    Its the one in the red box, part of the supercharger belt system. It has a triple square head, not sure of the size (M12?). I assume I can get it off without removing the front bumper etc. Do i need to move the tensioner to get the belt on/off?
    thanks
    (I tried searching but I keep getting hits for supercharge pulleys)
    Veteran Member Four Rings B18b1ex's Avatar
    Jul 02 2004
    FL
    Service position and it’s very easy, however if your belt is a bando or not new, I’d change that first as my squeaky noise was the belt although I wasted time and money on the pulley. 🥲
    Veteran Member Three Rings B7TitaniumA4's Avatar
    Mar 26 2016
    Montgomery County, PA
    Not sure if this will help. It’s a real photo of my motor. The water pump pulley, SC pulley and the idler are removed. The SC idler sits over the accessory idler and the SC tensioner is down lower. You should
    Be able to get it out without removing anything more than the belt, but I agree service position is your friend. Circled is where the idler bolts into.
    Apr 10 2019
    Thanks all. So Service Position needs removal of front bumper cover etc. Or I see if I have enough room for my wrench to get in between the rad and pulley.
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    Quote Originally Posted by djsauce View Post
    You can change the belt without service position, even install an oversize crank pulley. But to replace the tensioner or idler pulleys you need enough room to pull tbe center bolt out without it hitting the radiator or shroud. The bolts are long. There might not be enough room.
    Someone else might come along and make a definitive statement. Bolt length will be the issue. I'd put it in service position.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    Mar 26 2016
    Some more pics. My factory idler and the new idler have the bolt “secured” to the bearing so It cannot be removed without the pulley… mine are both 10mm triple Square. Doubt you’re getting it out without being in service position.
    Feb 14 2017
    Gulfport, MS
    Quote Originally Posted by B7TitaniumA4 View Post
    Given the length of that bolt, service position seems necessary. OP can try, but highly doubtful.
    Jul 02 2004
    FL
    This is from today personally I think service position is absolutely necessary for this.
    Veteran Member Four Rings RPMtech147's Avatar
    Apr 05 2014
    Texas
    Quote Originally Posted by B18b1ex View Post
    It can be done without service position but you fight with it so hard and tear up your hands and arms, you actually spend less time going service position.
    B6 S4, B8 A4, 8P A3, and something, something.
    Apr 10 2019
    Update: Was only able to pull out the front bumper/clip about 1.5", not sure why its not sliding out to the full 3-4" THEN, the old pulley bolt is not coming out, whe nI took a picture of it, it does not look like the new M10 triple suqre head, it looks really stripped but more like a hex - which can be oringal (I boughtthe car used).
    So now I need to figure out how to get the old pulley off, cut pulley, penetrating oil, heat....?
    Apr 10 2019
    Pic with old pulley bolt attached (taken usin a mirror)
    Sep 16 2020
    West Michigan
    Maybe a Torx?
    2012 A6 Prestige - APR single pulley via Fluidampr 189, Injen intake+RS7 airbox, IE HPFP, EPL TCU, JHM HX, 034 motor mounts, Eurocode drivetrain inserts, gutted cats - 034 tunes purchased, not installed.
    Mar 26 2016
    Wtf happened to the face of the bearing? Jagged metal?
    Apr 10 2019
    That was me trying to grip it, after the m10 bit wasnt working
    Mar 26 2016
    Ouch
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    Damn, that sucks. It definitely looks like someone replaced the bolt with something else, since it should be a Triple Square. That could well be why it is failing. If you can't get a bit or an extractor on it, you may end up having to take entire front clip off for access.
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
    Apr 10 2019
    Quote Originally Posted by sacandagaD View Post
    This thought keeps crossing my mind! Going to try and use penetrating oil and a wire brush on the head and threads if i can
    Apr 10 2019
    Last update: After a gruelling few hours in the sun, the idler pulley is on and the noise I had is gone , so good. Here is a quick summary of what I did:
    1) Uses a cheap auto stethoscope from Amazon to diagnose what was making the noise, listened to the centre pins and housings of all pumps, pulleys and etc - BE CARFEUL when doing this due to moving parts. This also helped be save over $1000 as I thought it was the servo pump first
    2) Remove radiator shroud, 5 screws on the bottom of the bumper skin, headlight connectors and expansion tank hose - makes sure the hose retaining clip doesn’t fly off lol. Search for putting the car in SERVICE POSITION for more info
    3) Remove the front bumper skin and disconnect the fog light connectors
    4) Remove the 6 bots on the crash bar and pull out (service position) - this gives you about 3" from the pulley and radiator fans to get your wrenches in there
    5) Remove the supercharge belt but putting a 16mm wrench (preferably long) on the tensioner to remove the slack
    6) Normally you would take off idler pulley with M10 triple square bit. For me, see the pics, I had to cut with an angle grinder, VERY CAREFULLY, as the head of the pulley boly was previously stripped. Once cut, I pried away the pulley and bearing pack, then put a pipe wrench on the bolt and it turned out of the housing. This took the most time and you have to be very careful.
    7) Put in new pulley and torque to 31 ft-lbs
    8) Reverse steps 2) to 5)
    The pics show the old and new pulley side by side and the cut open bearing pack
    Sep 16 2020
    West Michigan
    Your old one definitely looks like a Torx or similar bit from the last picture.
    Jul 02 2013
    Kudos OP! Even though it was a obviously real bitch, it's very satisfying when you encounter a mechanical problem that looks catastrophic at first, and then finally conquer it. And also, the next time you need to pull the front end, you will know what you are in for.
    Veteran Member Four Rings 20vturbo's Avatar
    Nov 24 2004
    2004 A4 2.1t, 2015 Q5 3.0t
    MOntreal
    hi, anyone knows how much torque for the pulleys and tensioner bolts?
    BetaAlphaTau member #19
    Senior Member Two Rings ccssid's Avatar
    Jul 03 2011
    michigan
    2011 S4 prestige. Imola 6mt.
    Nov 24 2004
    MOntreal
    Quote Originally Posted by ccssid View Post
    Tx
    Sent from my LYA-L0C using Audizine Forum mobile app
    Nov 24 2004
    MOntreal
    Is it the same for all if them?
    Jul 03 2011
    michigan
    If you mean for both the tensioner bolts...yes
    Sent from my moto g power using Audizine Forum mobile app
    Nov 24 2004
    MOntreal
    There are 2 idlers and 2 tensioners, 2 for acc belt, 2 for the supercharger belt,the bolts look the same, i am assuming torque is the same as well
    Jul 03 2011
    michigan
    That is correct
