Results 1 to 17 of 17
    May 20 2016
    New Brunswick
    Tire size for 20X10 Tires!
    Hi guys, I've heard that 255/30zr20 is the way to go for best fitment on the car.. Unfortunately I'm finding this a tough tire to locate (at a respectable price). Just curious if there is an alternative size that will fit well with this tire.
    My vehicle is lowered on KW HAS system.
    Thanks in advance.
    Feb 02 2014
    Focus RS, Audi S4 & S5
    Knoxville, TN
    That is the recommended size for a 20" wheel, but a 10" width wheel will stretch the tire. The offset will be critical as to whether or not they will rub on a lowered car.
    I had 255x30x20 on an 8.5 wheel, et 40mm offset on a 2015 S4 with H&R sport springs and they would rub.
    There is a very limited selection of summer tires available, and even fewer all season tires. I ended up going back to 19" wheels near factory offset.
    May 20 2016
    New Brunswick
    Quote Originally Posted by whts4 View Post
    20x10 ET 40!
    Feb 02 2014
    Knoxville, TN
    The challenge is that a 40mm offset adds 3mm to the outward position of the OEM 43mm et wheel and tire, plus half of the additional 38 mm (1.5") wheel width = 3mm +19mm wider = + 22mm outer edge of wheel. Doubt this will work, even with the stretched tire.
    May 20 2016
    New Brunswick
    Several members on this board are currently running this set up with little issue.. But if you have an alternative size I'm all ears!!
    Feb 02 2014
    Knoxville, TN
    I couldnt find a 255x30x 20" tire that I felt comfortable with that would clear the front or rear outer fenders on my H&R springs. If others have a specific tire brand/model and 10" x 40et wheel on their same yr S4 with the HAS then go for it.
    On my 2015 S4 with 20" et40 BBS wheels and H&R springs, I still had rubbing front and rear, even with front fender inner lip flattening.
    Ps, I won't run Chinese brand tires.
    May 20 2016
    New Brunswick
    Quote Originally Posted by ndirish1994 View Post
    To give you an idea of the difference between the et40 and the et35, here are the 2 setups I've run on 20x10s.
    20x10 et40 255/30 tires
    20x10 et33 255/30 tires, note I'm running 2.8 degrees of rear camber
    this is what I'm talking about
    Junior Member One Ring
    Feb 11 2017
    Taunton, UK
    I run a 265/30/20 on a 10x20 et35, fits fine with less stretch,
    May 20 2016
    New Brunswick
    Quote Originally Posted by Cerbera9 View Post
    Would ET 40 make much difference?.. And yeah not looking for a super stretched tire.
    Veteran Member Four Rings Ashtonts's Avatar
    Jan 17 2015
    Quote Originally Posted by DB_S4 View Post
    ET40 would make exactly a 5mm difference. Your wheels will sit 5mm into the fenders further than his wheels.
    2007 Porsche Cayman | 5MT
    May 20 2016
    New Brunswick
    Quote Originally Posted by Ashtonts View Post
    So the tire he's suggesting might be a problem?
    Jan 17 2015
    It could hit your strut or fender liner inside. You can solve that problem with a 5mm spacer if you ran into that issue
    Senior Member Two Rings ndirish1994's Avatar
    Dec 29 2014
    Portland, Maine
    Hey that's me! I'm running Hankook Ventus V12s
    How low are you? I couldn't even imagine how bad a 265 would rub on my set up
    2017 S6 Prestige / Daytona Gray / Black Optics / DS1 Stage 1 / TGK Dumpbox
    Formerly:
    2013 S4 / Glacier White / DSG / APR Dual Pulley / APR CPS / CTS Intake / AWE Track / KW V1 / Rohana RFX11
    IG: Portland_S6
    Jan 07 2019
    2021 M3 Competition | 2017 Q7
    I ran 20x10 ET 40 Niche wheels for two years with very minimal rubbing in the rear (KW V1 coilovers). I ran a 255/30/20 Hankook Ventus V12 which is one of the narrowest 255s you can get. This will stretch pretty good, the lip of the wheel will stick out past the tire. This setup would look ridiculous on factory suspension. Springs would work, but a HAS kit or full coilover setup would be ideal to dial it in how you want.
    With that said, I just switched to a 19x9.5 ET 40 wheel with a 265/35/19 tire with absolutely zero stretch. My area is not the greatest for the 30 series life.
    2021 ///M3 Competition
    May 20 2016
    New Brunswick
    Ha yep it is.. You have no issue with your tires and fitment? I'm worried that the 255s are going to be too stretched. the 265s sound like a good idea, but again I'm worried about running against my struts.
    Dec 29 2014
    Portland, Maine
    On the et40 wheels, had little to no fitment issues, would only rub when fully loaded on big bumps. On my current et33 setup, I rub on pretty much everything. I personally don't think the 255 on a 10'' wheel is too streched, this should give you an idea of how much of a strech it'll be.
    Formerly:
    IG: Portland_S6
    May 20 2016
    New Brunswick
    For the narrowest 255 tire - that doesn't look overly stretched. You've won me over. Ordering a set of 255/30zr20's today.
