Results 1 to 17 of 17
    Established Member Two Rings James115's Avatar
    Jun 02 2021
    Audi A6 3.0 TFSI ABT, Mercedes C63 amg
    Italy
    3.0 TFSI version’s Differences
    Hello, I am looking for an Audi A5/S5 3.0 TFSI,
    I would like to know the differences between the A5 and S5 version of the engine. I’ am planning to tune the engine, is it possible to reach the same power with the 2 version? What are the differences between the engine?
    I also have seen that the new CREC is installed also on both the car, I have seen many pictures of the A5 with the new cover. Can somebody explain? Thanks
    Nov 02 2007
    95 S-6 Avant, '73 911 E Coupe, '03 Boxster S w/3.6 swap, '15 Q5 3.0T loaded
    Evergreen, CO
    Both engines can be tuned to same output. S5 starts with inherently more to differentiate. Trans are the same. S will have different interior, suspension, potentially brakes.
    Sent from my SM-G955U using Tapatalk
    Jul 16 2018
    Atlanta
    EA837 3.0T for EU5/5+ emissions in the B8.5, running SIMOS 8:
    CGWC = 245kW
    CMUA = 200kW
    EA837evo 3.0T for EU6/6+ emissions in the B8.5, running SIMOS 16:
    CREC = 245kW
    CRED = 200kW
    As for what are the physical differences between the 245kW and 200kW versions beyond the ECM tune? Only thing I know offhand is the exhaust manifolds are different between CGWC and CMUA, but they are not different between the CREC and CRED. Cooling system robustness will be different between 245kW and 200kW.
    If you want to read about EA837evo changes, search for Audi SSP 624.
    Senior Member Three Rings S5boxster's Avatar
    Sep 14 2016
    986 boxster
    East Brunswick NJ
    (B8.5 S5 has a 3.0L v6 supercharged 6cylinder)
    (B8 & B8.5 A5 comes with 2.0L turbo 4cylinder)
    (B8 A5 couple years had a 3.2L v6 naturally aspirated 6 cylinder)
    (B8 S5 has 4.2L v8 naturally aspirated 8 cylinder)
    All info is based on Audi NA, if ur outside North America your configurations will be different.
    B8.5 S5 gets dsg 7spd
    A5 gets either zf 6spd or zf 8spd
    b8 and b8.5 s4 s5 gets the same front calipers as A4,A5 but bigger rotor size and they are single piston which are terrible, new b9 S models gets new 4 or 6 piston calipers
    Hopefully this helps
    Since links to apr on engine tuneability
    https://www.goapr.com/products/softw...0T-EA837-SIM85
    https://www.goapr.com/products/softw...-20T-EA888-2-L
    Jun 02 2021
    Italy
    From the document Ssp 624 I read
    Key modifications compared to the third-generation 3.0l V6 TFSI engine:
    Reference
    • Cast-iron cylinder liners
    • Deactivable supercharger (Roots blower)
    • Multipoint injection added
    • Exhaust-side camshaft adjustment added
    • Compliance with exhaust emission standard EU 6 W • Repositioning of the motor oil cooler (switchable)
    to the back of the engine
    • Chain drive with different chain routing
    • Positive crankcase ventilation on one cylinder bank only • A continuous design hood
    The following adaptions were made:
    • Piston shape
    • Oil pan and rear engine cover (sealing flange)
    • Crankshaft with hollow-bored crank pin
    • Coolant pump with modified pump gear ("potted")
    • Terophon ↗ coated timing chain covers
    • Package of modifications to reduce friction and weight
    So enough differences, seems that the CREC, is enough improved
    Nov 27 2015
    UK, West Berks
    FYI my 2015 UK spec CREC S5 has been stage 2 (480PS/585Nm) for over 4 years and I have had no engine/transmission problems.
    2015 monsoon grey S5 sportback (yes the one with 4 doors)
    - MRC stage 2 (189mm Vdamper/Fluidampr crank pulley)
    Jun 02 2021
    Italy
    I am contacting many S5 owners, with the CGWC, and they say that have high oil consumption, around 1kg for 1.200 km.
    I say to check the PCV, but honestly I think that is the engine itself, I mean the cylinder.
    This can explain why they changed the cylinder, in the CHWC are in Alusil, in the CREC in cast iron.
    What is the medium oil consumption of your cars?
    Jul 16 2018
    Atlanta
    SSP 624 says the EA837 evo block is closed-deck aluminum-silicon alloy, just like the EA837. But it has "Thin-wall cylinder liners made from cast iron with nodular graphite with a wall thickness of 1 mm (press-fit)".
    For the piston changes of the EA837 evo, we note:
    • Graphite coating
    • Required for cast iron cylinder races
    • Reduction in friction
    • Improved limp-home performance
    So why did Audi change it? For the only reason Audi changes anything, lower regulatory bills (emissions/efficiency).
    Just like why CRE has a different supercharger pulley system: "Many details of the air supply and charging system were revised. Here, the designers saw another possibility for improving the engine's fuel economy."
    Any side benefit of power handling and longevity to the tuning owner is coincidental.
    Veteran Member Four Rings hahnmgh63's Avatar
    Jan 10 2008
    Roy, WA
    2013 CGXC, 58k, bought it from Copart with front end damage. Did the RS5 look front conversion and 034 Motorsport Stg2 w/X-pipe resonator delete. No oil consumption on this motor.
    2003 RS6 (6Spd)
    2013 RS5 (Headers, Aluminum DSG Flywheel,JHM Stg2, etc...)
    2013 S5 (034 Stg2 & TCU)
    1974 911 (3.6ltr)
    2006 CTTS
    944T
    Jun 02 2021
    Italy
    Quote Originally Posted by hahnmgh63 View Post
    CGXC?
    Jul 16 2018
    Atlanta
    CGXC is the US emissions version of CGWC.
    Jun 02 2021
    Italy
    So CGWC Alusil cylinder, CREC sleeve cylinder cast iron, new EA 839 same engine, again Alusil with plasma spry coating iron on the cylinder wall.
    Jun 02 2021
    Italy
    Quote Originally Posted by Smac770 View Post
    • Graphite coating
    Yes, yes, but I was thinking about the oil consumption, the hardness of the cylinder wall.
    From other perspective I read of many BMW engine faults because of the cylinders sleeve
    Jun 02 2021
    Italy
    Hello, do you think i can fit this in my 2012 A6 TFSI? https://www.ebay.it/itm/265509940690
    - 2015 Audi Q5 TDI 163 cv, Brilliant Black
    - 2012 Audi A6 3.0 TFSI, S-Line ABT 420 CV, Phantomshwarz Met.
    - 2011 Mercedes C63 AMG 6.3 V8
    Jan 10 2008
    Roy, WA
    The last generation of the 3.0t (Supercharged) engine like the CREC you listed above have quite a few changes as you know from the previous generation. I know the Supercharger is not interchangeable. It is more than just a magnetic clutch at the front, the Diverter at the rear is different. At the least you would need the complete engine harness and ECU to control that clutch controlled Supercharger. Who know how many other sensors may be different. A new and different ECU in the car may be more than just an immobilizer coding issues. I would think someone on one of the forums may have an answer if the engine, with harness and ECU, can be plugged relatively easy into an earlier car.
    2003 RS6 (6Spd)
    1974 911 (3.6ltr)
    2006 CTTS
    944T
    Jul 16 2018
    Atlanta
    The CRE engine is a EA837 evo engine, very modified compared to prior EA837 3.0T engines. And it's more modified for EU than for US. EU CRE has both direct and port injection, etc.
    If you want to swap to a CRE, sure it can be made to work. But you'll be swapping all the supporting components like the ECM and such as well. Basically a full dissimilar engine swap process.
    Nov 27 2015
    UK, West Berks
    IIRC the SIMOS 16 has a number of digital (SENT) sensors. If these go beyond those fitted to that used engine then they will need to be replaced too.
