Results 1 to 8 of 8
    Oct 08 2020
    Dayton, OH
    Intake Silcone hose worth it for Stage 1 on A6 3.0T ?
    Thinking about getting an intake silcone hose for Stage 1.
    But will not add an upgraded filter like a K&N, setup will just be: stock air box, stock filter and silcone hose... is it worth it?
    Sep 27 2008
    Phoenix
    Quote Originally Posted by Daytonview View Post
    Worth it how? Not sure what you're looking for here. More performance, more sound?
    Oct 08 2020
    Dayton, OH
    Not sound, but performance. If I do not add an upgrade filter like K&N. Is buying the silcone intake hose worth it?
    Veteran Member Three Rings paul-g's Avatar
    Dec 02 2011
    2013 Ford F150 3.5 EcoBoost 4x4, 2018 Volkswagen Tiguan
    actually the stock intake is decent say i'd say no
    2016 Audi A6 3.0 S line, APR Stage 1, Melen TCU Tune
    Veteran Member Four Rings f4m0u5's Avatar
    Aug 04 2014
    Gloucester MA USA
    I think stage 1 is fine on stock pipe for performance. When stage 2 you have chance of collapsing the stock intake tube.
    But changing to the silicone will add a little bit of supercharger whine and willhave you ready for stage 2 later.
    Dec 02 2011
    Quote Originally Posted by f4m0u5 View Post
    Funny never heard of that, i doubt you'll collapse a stock intake.
    Sent from my SM-G981V using Audizine Forum mobile app
    Veteran Member Three Rings Burkeomatic's Avatar
    Feb 22 2021
    14 A8L 4.0T, 96 Corolla Wagon
    San Antonio
    Quote Originally Posted by paul-g View Post
    I was told by a few people it could. If you look at that bulgey part, it looks like it has some kind of white insert, presumably to muffle the sound. If you squeeze it, it is pretty squishy. I just duplicated this set up.
    https://www.audizine.com/forum/showt...5-C7-A6-Intake
    I didn't like having a hot air intake, so I just grabbed another 45 degree and ran the filter a little above and behind where the fog light would be, popped that little panel out to get air flow, and heat wrapped the pipe. I had my intake done for under $100ish including heat wrap.
    That being said, I switched back and forth between stock, and this set up. Butt dyno felt no difference. My stocker obviously wasn't collapsing. I had a recently cleaned stock replacement K&N though. I guess if your filter were clogged enough, it could create enough of a pressure differential, and therefore a vacuum, and collapse.
    2014 A8L 4.0T - DS1 Stage 4/JHM TCU, FE Axlebreakers, E85
    Established Member Two Rings joejoe3's Avatar
    Nov 25 2020
    Calgary AB
    If you plan on going stage 2, you will need to open up the stock intake.
    I modified my stock air box with an additional hole, added afe dry filter and a JHM intake silicone hose for that setup.
    If you plan on sticking with stage 1 only, the stock setup is fine.
    2014 Audi S7
    GONE: 2014 A7 3.0T / S line / Moonlight Blue Metallic
    [ EPL Stage II (PR 3.04) | EPL TCU | CTS 192mm Crank Pulley w/ stock SC pulley | JHM Heat Exchanger | JHM Inlet Hose w/ aFe Power Dry S | Eurocode Drivetrain Inserts ]
