Results 1 to 35 of 35
Thread: 0-60 times
    Junior Member One Ring ehhh6's Avatar
    Jan 09 2019
    Cincinnati OH
    0-60 times
    Curious what others are running
    I just did a pull and ended with 3.32 seconds
    Dec 08 2020
    Portland, OR
    What car and mods? What did you use to track the time?
    I just got a dragy, 2012 A7, EPL TCU Tune and DP Tune, JHM 207mm pulley. 0-60 3.78 seconds
    Quote Originally Posted by ehhh6 View Post
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    Some clarification might be in order.
    Measured 0-60 mph?
    Draggy 0-60 mph?
    1ft rollout like the magazines test? (Draggy also does this calculation)
    0-60 foot, real measure of launch capabilities.
    I've seen a Stage II DP A6 with TCU and 104 tune do a 3.2s (3.02 w/ rollout) 0-60 mph in draggy.
    I think p3u has pulled off a 2.99s w/o rollout!
    For 60 ft times 1.8-1.7 is very good and 1.6 is about as good as I've ever seen for the whole C7 platform on street tires. I think some of the 10s RS7's crack into the 1.5s 60 ft but that has to be modified and likely with slicks or drag radials of some type.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Jan 09 2019
    Cincinnati OH
    Apr DP II, tcu tune. Merc heat x
    Jan 09 2019
    Cincinnati OH
    Prestige a6,, no rollout
    Oct 02 2005
    The Moon
    My best is 2.82 without rollout, 2.66 with. Mods in signature.
    Also, as GK1 mentioned method of measurement is important. Using a P3 gauge isn't accurate where as a dragy or v box are.
    Jun 12 2019
    MK5 Rabbit 2.5 5spd
    Natick, MA
    I’m in the 3.5s with my 2016 APR single pulley with Berk tcu. That was a few months ago prior to the MercRacing hx which I just installed today (which wouldn’t be likely to have much if any effect on a single pull). Also changed to cooler plugs today and my runs in the 3.5s were pulling ~6 degrees timing for knock correction
    2016 A6 P+ 3.0T / Aviator Blue Metallic / APR Stage II Single Pulley 93 Octane / BG_SQ5 tcu / MercRacing hx v3 / Hartmann Rotor Reps 20x9 ET40 w/ 265/35-20 PS4S / 0-60 3.56 sec
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by p3u View Post
    2.82 !!!!
    Let's see... that is on par with....
    Ferrari 458
    Lamborghini Aventador
    Multiple McLarens
    Ariel Atom
    911 Turbo (997)
    Corvette Stingray Z51
    "Plain" Tesla Model S
    Very Nice.
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Veteran Member Three Rings choy188's Avatar
    Jun 02 2019
    2019 S5 Sportback, 2022 Polestar 2; Sold: 2012 A6 3.0T, 2006 A6 4.2
    Danville, CA
    I feel slow now at 4.2 stage 1 034 ecu and tcu tune
    Sent from my SM-N986U1 using Tapatalk
    2019 S5 Sportback Prestige | Navarra Blue Metallic | Black | Options: Sport Package, Dynamic Steering, Cold/Warm Weather Package, Black Optics, Direct TPMS Retrofit
    Sold: 2012 A6 Prestige | Oolong Gray Metallic | Titanium Gray | Options: Innovation Pack, Cold Weather Pack | Mods: Lane Assist Retrofit, Injen Intake, 034 Stage 1 ECU+TCU
    Sold: 2006 A6 4.2 | Atlas Gray Metallic | Platinum | Options: Technology Pack, Cold Weather Pack
    Veteran Member Three Rings A665's Avatar
    Oct 26 2019
    Mid-Atlantic
    Quote Originally Posted by choy188 View Post
    That's plenty quick :)
    2013 Audi A6 3.0T Prestige | S-Line / Sport | Full LED | 034 Stage 1 ECU+TCU | ECS Trans Mount Insert | JHM Driveshaft Carrier Bushing | FormulaOne Pinnacle Tint
    Mar 23 2019
    KS
    Agreed. That would feel slow.
    Jun 02 2019
    Danville, CA
    Quote Originally Posted by A665 View Post
    At 19 any faster is probably a horrible idea
    Veteran Member Four Rings 07S6's Avatar
    Sep 17 2010
    APR Stage 2 single pulley / Injen intake / AWE Touring exhaust
    3.92 0-60
    3.65 (1 ft rollout)
    2012 A7 Prestige, Innovation Pkg, Sport Pkg, B&O / APR Stage2, AWE Touring, Injen intake
    2012 A6 Prestige - Phantom Black/Nougat/Innovation Pkg. (sold)
    2007 S6 5.2L V10 (sold)
    Veteran Member Four Rings ANMS4's Avatar
    Dec 18 2012
    Framingham MA
    I've done 3.07 using my P3 gauge on IE STG2 DP+TB 93 oct and launch control, I haven't gotten a change to do one on E40, I'm guessing sub 3 tho :)
    2014 S8*SMR Intakes*HMD Exhaust*DS1 tuned by SLEEPERTUNED*E50* MELEN TCU TUNE
    SOLD 2014 A6-IE STG2 DP+ TB E40 tune and Melen TCU Flash, RS7 Airbox, AWE Touring Catback+Resonated DP, Ported SC By Shane
    Veteran Member Three Rings WatchMeSpend's Avatar
    Mar 19 2019
    2016 A6 3.0T Technik S-Line
    Toronto/Ontario
    Quote Originally Posted by 07S6 View Post
    3.92 0-60
    3.65 (1 ft rollout)
    How about getting a TCU tune? The APR charts suggest you are making lots of power in the top end that you can't access. Would love to see the before and after a TCU tune results with APR STG2 SP.
    Jun 12 2019
    MK5 Rabbit 2.5 5spd
    Natick, MA
    Quote Originally Posted by WatchMeSpend View Post
    My best time with stock tcu was 3.77, with Berk tcu and no other changes 3.56. Similar DAs. Only did 3 or 4 runs so not a ton of data but the initial launch and 1-2/ 2-3 shifts are noticeably more aggressive with the tcu.
    Sep 17 2010
    Yes, would be interesting to see. I've been thinking about just doing the TCU tune, rather than worrying about going dual pulley + cooling upgrade.
    Oct 26 2019
    Mid-Atlantic
    Here's a YouTube covering a late-model S6 with Unitronic ECU and TCU. https://www.youtube.com/watch?v=-tO3BixxGM8
    The video creator considers himself very funny and hams it up here & there, so the content is partially tongue-in-cheek. But it offers some good & useful info as well.
    Senior Member Three Rings Nosferatu's Avatar
    Aug 19 2019
    C7.5 RS7 Performance, McLaren 720S Spider, Tesla Model S Plaid
    Tampa, FL
    For both my cars...
    RS7 Performance with DS1
    0-60 3.1 w/o roll out
    2.8 with roll out
    Given only mods are software not complaining. Stock otherwise.
    2017 R8 V10 Plus also stock minus a noise maker catback...
    0-60 2.8 w/o roll out
    0-60 2.5 with roll out
    EDIT: Both RS7 & R8 are 93 pump
    2018 Audi RS7 Performance in Mythos Black with DS1 Stage 1, Milltek (non-resonated) Catback, Uniden R7 Blendmount, Viofo A129 Duo
    10.8 @ 128.7 MPH
    Other Toys:
    2019 McLaren 720S Performance Spider Keeping the ICE dream alive!
    2021 Tesla Model S PLAID the Silent ICE killer
    9.33 @ 150.2 MPH
    Feb 10 2020
    1985 Monte Carlo SS (race car) 2015 Dodge Charger Scat Pack (sold) 2015 dodge challenger Scat (sold)
    Ridge, New York< United States
    Quote Originally Posted by Nosferatu View Post
    For both my cars...
    2.8 with roll out
    sick times and sick garage... one day for me lol
    Aug 19 2019
    Tampa, FL
    Quote Originally Posted by ferrara42 View Post
    Thanks! His & hers we share them but when the little one needs a ride it's the RS7. Baby seat does "fit" in the R8 but I won't take her in there until she can sit forward facing.
    10.8 @ 128.7 MPH
    Other Toys:
    9.33 @ 150.2 MPH
    Veteran Member Four Rings johnnybravo!'s Avatar
    Feb 20 2006
    323 EASTLOS, CALIFAS
    for those that didn't...can ya'll add/edit in what octane level where ya at when achieving your best times? thanks
    SRM K24 - Bosch 1000cc - Rods - 2.8 Cams- RR STG 4 clutch - AA-built 01E+4:1 - OS Giken LSD - ER IC's - JHM SS - SRM DPs - Vibrant 3" - Vast W/M - RS4 Y-Pipe - ASP MAF - APR Bi-Pipe - Ohlins MS Coilovers - AP Racing BBK - 034 Rear Sway
    C7 A7 Silver- Jackal STG 2+E40 Shane Horning ported s/c Merc HX- Pierburg 100-3 - Eibach Springs- OZ 20" UL wheels/Michelin PS4s- Eurocode Sway Bar- Borla- IE Intake
    Audi. Truth in Understeering.
    Feb 05 2021
    Hobart, Tasmania
    3.25 0-100km/h
    16' RS7 DS1 Stage 1 Map 1
    Veteran Member Three Rings Patrick Matte's Avatar
    Jun 12 2018
    old car's: Porsche 911 86 3.6 varioram plus G50, elephant racing track suspension, 996 turbo brakes
    Beloeil , Canada
    Audi A6 C7 IE Dual E40 / Melen TCU tune / 192mm&57.3mm / cooling mod’s
    Stock intake/ stock TB / Stock Blower
    19 inch OEM Wheels& Continental Extreme contact sport.
    -Audi A6 2012 3.0T-
    IE Stage 1 93 Oct- Melen TCU : 11.72
    IE Stage 2 dual E40 : 11.05
    Established Member Two Rings Trevorshackelfo's Avatar
    Dec 17 2020
    2003 Land Rover Discovery 2 SE7
    San Diego, Ca
    Here are my entries, best is 3.36 with the mods in my sig
    Ive since dropped the redline to 7100 and am running the same thing, going to try dropping to 6900 to see the change
    Going from PR of 2.9 to 3.2 trims my time by about 0.20 seconds
    -2017 A6|Moonlight Blue Metallic|Nougat Brown|Prestige 3.0|ZF8|20" 5-arm-star|Sport Suspension
    -Power: APR Stage 2 93 Oct (E30)|Dual APR Pulley PR 3.28 (57/187)|Gates RPM 1310 belt|IE Intake|Stock plugs|Stock Gap|Berk TCU Tune
    -Looks: Debagged|Dechromed|P3 Gauge
    -Cooling: Merc Racing Quad Pass|CWA100-3|100% Duty mod (CREC=De-Pin the red wire!)
    -Times: 0-60-3.36|1/4 mile-11.875 @ 118.258 mph|Full Weight|200 lb driver| 50' D/A|Firehawk Indy 500 255's|40 PSI
    San Diego, Ca
    Senior Member Two Rings gkott78's Avatar
    Apr 22 2018
    Metro Detroit
    2015 A6 Full Weight
    034 Stage 2 Dual Pulley (running APR pulleys) 75mm TB, Intake, test pipes, full exhaust and Merc HX. On 104 octane I was getting around 3.2 to 3.3 consistentl (straight time no 60ft) per Draggy. I know it can pull better with improved DA. Upgrades to e40 have been delayed but I have all the parts at home and ready.
    Having some cooling issues and high IAT's right now which i'm still working to address. I want to get that sorted before I put the e40 in after swapping the HPFP.
    2018 SQ5 Prestige - 034 Motorsports Stage 1 E85 ECU, Stage 2 TCU, 034 Carbon Intake, Rev 9 Intercooler, 034 Trans Mount Insert. Pending install CTS Turbo Catted Down Pipe, Stage 2 034 tunes R1 Concepts brakes and rotors.
    Jun 12 2018
    Beloeil , Canada
    Quote Originally Posted by gkott78 View Post
    2015 A6 Full Weight
    How high is your iat’s ?
    Envoyé de mon iPhone en utilisant Audizine Forum
    -Audi A6 2012 3.0T-
    Established Member Two Rings dee5330's Avatar
    May 14 2017
    2018 Audi Q7 Prestige
    Temecula, CA
    Modifications include:
    Engine Management Setup:
    Dyno Spectrum DS1
    Custom dyno tuned by SRM
    Low boost: 700WHP
    High boost: 800WHP
    Turbo Setup:
    SRM Xona XR5756 Twin Turbos
    SRM Tial Wastegates
    SRM Mac Valve Kit
    SRM 4 Bar Pressure Sensor Kit
    Intake & Intercooler Setup:
    Eventuri Carbon Fiber Intake
    Exhaust Setup:
    APR Downpipes
    SRM Exhaust Cutouts
    Milltek Non Resonated Exhaust System
    Transmission Setup:
    SRM TCU Tune
    JXB Driveshaft Carrier
    Fuel Setup:
    SRM E85 Flex Fuel Adapter
    SRM Low Pressure Fuel Pump
    SRM fuel lines
    Autotech High Pressure Fuel Pump
    PHR Billet High-Flow Dual-Passage Flex Fuel Adapter
    Cooling Setup:
    SRM Methanol Injection Kit w/ injection plates
    SRM Water Pump
    SRM HX Fans
    2016 RS7 Glacier White Metallic, 21x10 Vorsteiner VFN-315, Eventuri Carbon Fiber Intake, Milltek Non-Resonated Exhaust, APR Stage 2 Tune, APR Downpipes, CETE Lowering Module, Nardfaktor Carbon Fiber Mirrors, Prior Design Front Spoiler Lip, Maxton Design Side Skirt Diffuser & Rear Side Splitters
    Dec 08 2020
    Portland, OR
    Quote Originally Posted by Patrick Matte View Post
    What is the best way to log iat's?
    Junior Member Two Rings
    Jun 14 2021
    Oregon
    0-60 times
    Any of you guys track your times as you add mods? I’m really curious what just a K&N filter and APR Stage 1 ECU/TCU will do to my 2018 S6 times.
    I got my dragy today and laid down some stock OEM times before I start modding. I was feeling good until I saw the times you guys are laying down. It was 88°F out, under cooler conditions maybe these would be better.
    4.04s 0-60 (w/o rollout)
    3.83s 0-60 (1ft rollout)
    12.37s 1/4mi
    Jul 08 2021
    FL/OH
    I have a Berger JB4 coming in the mail for my 2017 S7 with sport exhaust option.
    Does anyone have results/feedback from adding a JB4 with the sport exhaust?
    I'm curious if the sport exhaust allows for any addition whp vs the standard exhaust.
    Sent from my SM-G998U using Audizine Forum mobile app
    Jun 12 2018
    Beloeil , Canada
    Quote Originally Posted by markdjr View Post
    Vagcom , P3 gauge or HP tuner cable an do the job.
    -Audi A6 2012 3.0T-
    Established Member Two Rings Aaronl4903's Avatar
    Feb 22 2021
    HARRISBURG, PA
    Quote Originally Posted by Worksjo View Post
    12.37s 1/4mi
    ‘15 Audi S6 Stage 1 APR TCU w/SRM Intakes/Catback exhaust/crap Pirelli tires and heavy wheels
    0-60 3.7 seconds with no rollout. 75 dgF.
    0-60 with rollout, I have no idea how to do that
    RPM set at 3500
    2018 S6 Phantom Black w/Sport Package
    Veteran Member Four Rings JWebb_C7_Comp's Avatar
    Jan 11 2018
    Civic, A6, Q7
    Chi-Burbs
    stock? 91 or 93 octane?
    Veteran Member Three Rings Burkeomatic's Avatar
    Feb 22 2021
    14 A8L 4.0T, 96 Corolla Wagon
    San Antonio
    I have gotten 4.2 with my JHM stage 2 single pulley. In 90+ degree heat and a 3200 DA with some wheel spin from my crappy Chinese tires. Way better than the 4.7 with EPL. IATs are minimum 45C starting out. I think I will do way better in cooler weather. I am getting my cooling upgrades going soon. It is starting to look like here in San Antonio, meth is a must.
    2014 A8L 4.0T - DS1 Stage 4/JHM TCU, FE Axlebreakers, E85
