Results 1 to 15 of 15
    Senior Member Two Rings aquarian's Avatar
    May 29 2011
    Bellevue, WA
    Installed the Ghost lowering links
    I went with a modest drop, maybe 15mm. I adjusted the links to be 3mm different from stock links, which are made from a hard rubber material so they are somewhat flexible, making them easy to be removed.
    2012 Audi R8 V10 - Titanium package - TCU tuned - Hard-wired Escort 8500 X50
    2017 Audi Q7
    2021 Audi S7
    Oct 10 2019
    Toronto, Ontario
    Looks good! How long did it take to install? How easy are they to adjust?
    May 29 2011
    Bellevue, WA
    Quote Originally Posted by KJ-RS View Post
    About an hour working with 2 rennstand jack stands. The Ghost links come with 5 mm pre-adjusted (5mm shorter for the front and 5mm longer for the rear), and turning one of the heads 350 degrees equals 1mm. Super easy!
    2017 Audi Q7
    2021 Audi S7
    Oct 10 2019
    Toronto, Ontario
    Quote Originally Posted by aquarian View Post
    Thanks for the info!!
    Junior Member Two Rings wheeljouster's Avatar
    Mar 09 2021
    Washington
    Looks good!
    Did lowering affect your tire alignment or anything? I wouldn’t think so with it being such a minor amount.
    (First post!)
    Sep 22 2020
    Connecticut
    I installed my ghost links and lowered it similar to the OP car. I then took it in for an alignment and was told it didn't require one.
    YMMV
    Matt
    Quote Originally Posted by wheeljouster View Post
    Looks good!
    (First post!)
    2023 Defender 110
    2021 RS6 Avant
    2005 Porsche Boxster
    1997 Ducati 900SSCR
    2019 BMW GS310
    2004 Honda Lawnmower
    SMEG 2 Slice Toaster
    Mar 09 2021
    Washington
    Quote Originally Posted by MattF View Post
    I installed my ghost links…
    Matt
    Awesome. Thanks!
    2021 S6 Prestige
    2022 S5 Coupe Prestige
    2016 & 2009 Yamaha YZF-R1
    IG @wheeljouster
    Mar 09 2020
    Southeast Pennsylvania
    The included instruction state not to jack the car (use a pit) to install the links. Anyone have issues doing it as shown above?
    Sent from my iPad using Tapatalk Pro
    Mar 09 2020
    I just installed mine… put the car in tire change mode and installed links as delivered after measuring. I did one corner at a time ( I don’t follow instructions well) and the car is now 3/4” lower. No issues or problems.
    Junior Member One Ring
    Aug 18 2021
    Grand Rapids, Mi
    Have you had your car in the snow with the links? I installed some on my C8 Allroad a few months ago. We had our first snow of the year, and my car was a death trap in the snow. The rear end was all over the place, and I couldn’t safely drive over 35mph. I removed the links, and put the stock ones back on. Same result. So I doubt it’s the links. But this car in snow undrivable . Coming from 20 yrs or of owning a wrx, 2 STi’s, and a focus RS.
    May 29 2011
    Bellevue, WA
    Quote Originally Posted by GnarShred View Post
    Haven't driven in snow yet, but what kind of tires are you on?
    2017 Audi Q7
    2021 Audi S7
    Mar 09 2020
    Have a golf r on blizzaks for that until the Bronco comes in.
    Aug 18 2021
    Grand Rapids, Mi
    The oem all seasons with 9k miles. It’s not a tire issue. I bought an STi in January once, and before I could get it in for snow tire/wheels we got a couple inches of snow. I felt way safer in that. I do have an appointment to bring it into the dealer next week. But I’m trying to see if anyone has experienced something similar.
    Apr 13 2012
    San Diego
    This isnt from me but I found someone else on the boards with a recall about a rear end wiggle...I saved the texted but not the post...
    Had a recall completed while in service recently: 42L1, Audi is recalling several new models for a lock nut issue on the rear suspension. Since the recall I haven't experienced the wiggle. Might be sheer coincidence however it seems to have worked for me.
    2021 RS6 Avant - Navarra Blue with Xpel Stealth, Vossen S17-06 in Dark smoke, lowered 25mm, Milltek exhaust
    Aug 18 2021
    Grand Rapids, Mi
    Quote Originally Posted by sdaudiguy View Post
    Ok. This sounds exactly what I experience on dry pavement when I hit a bump. I wrote it off, because this is the biggest car i have ever owned. I’m just so used to driving sport compacts, that I didn’t know what to expect with this boat. I can hit a man hole cover that is slightly sunken, and I can feel the rear get squirrelly when the rear wheels hit it. I’ll bring this up when I drop it off at the dealer. Thank you.
