Results 1 to 40 of 74
    Junior Member One Ring
    Dec 14 2019
    Ukraine
    B9 3.0 TFSI ticking/knocking sound driver side
    Just purchased b9 s5 couple weeks ago, started to notice pretty loud ticking sound when accelerating, mostly audible on low RPMs around 1000-1500 with opened window when passing a wall on the left side of the car or in tunnel. I can still hear it to around 2500 RPM, then exhaust becomes louder. Sound is very similar to injectors ticking or hpfp, but very loud, more like diesel cars.
    I tried revving car with opened hood to the same RPMs - I can hear nothing when car is not moving, engine works quietly. Engine was inspected, everything is fine, no fault codes etc. Sound appears both on cold or hot car, just every time accelerating on low rpms. Running RON98 fuel.
    I found a lot of threads on this topic, looks like this is a common issue, but no one actually posted a video with his exact sound, so I decided to start a new thread. Just trying to find out is my ticking the same as a lot of owners mentioned in previous threads or mine is another.
    Feb 14 2021
    Though it’s not really that audible in your video, yeah it’s the same.
    Dealer claimed it’s the fuel pump/injectors and is normal on my 2018 S4. Sounds like engine tapping to me though.
    Ive got a long Audi extended warranty though so I’m just gonna drive the car and not worry about it.
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    Sounds like top end noise and the dealer blames the HPFP as an excuse to not do anything about it. It seams a lot of these motors have a tick 1500-2500 ish. Mine is dead quiet for what it’s worth.
    Established Member Two Rings Zenarcher's Avatar
    Jan 21 2020
    1983 Jeep CJ-8 Scrambler Laredo
    Charlotte, NC
    I have the same noise and pretty sure its the HPFP after checking with stethoscope. The volume of the tick is definitely is correlated to oil level, bc when i notice its really loud, i check the oil and every single time its lower than max. Either that or i'm losing it... I plan on trying thicker oil or some Ceratec.
    2018 S4 P+ Mythos Black with Magma seats. JB4 | BMC
    Feb 23 2010
    Emmaus Pa
    I use Motul 5W40. I'm not running piss water in my car bc Audi specified it for emissions.
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
    Mar 01 2021
    GLC300, CL600, Tundra, Tercel
    Miami, FL
    Heavier oil will always help with strange engine noises, and these modern systems have so much load on the oil system and run such thin oil, I also end up stepping up to a better oil in most of my cars. Hot climate just makes it worse for me too.
    Years ago, in my '08 350z, I ran some 15-50 that I had around for one oil change, and it was amazing how quiet the engine was compared to the 5-30 ester oil Nissan calls for, but I did notice, on first cold starts (south FL cold, so 80 degrees, not cold), the oil pressure was so high the VVT system would overshoot on adjustments, I could hear the cams moving around under light load via intake noise changing, until the engine got up to temperature. Didn't hurt anything, but when I went to a 5-40 at the next oil change it stopped doing that. So there is a happy medium for most engines, and it's often thicker than factory fill, because as mentioned above, they do that for emissions/fuel economy, not engine longevity.
    '21 S4 Navarra/black, EMD springs, 12mm spacers
    Dec 14 2019
    Ukraine
    I'm running 5W40 motul, video is filmed less then 1000 miles after oil change and sound is exactly same from day one of my ownership (bought the car it had 3000 miles on oil, don't know exactly which oil it was running), oil level remains max as for now. I think sound is coming from fuel injectors, since it is very audible from the side where they are located and hpfp in on the top on the passenger side. I always use motul fuel additive for injectors cleaning once in around 5000 miles on all cars, will try it here, interesting if it makes any difference
    Feb 23 2010
    Emmaus Pa
    If it were my car I would pull the valve covers and take a gander in there. Look for any damage to a rocker arm since that has happened to some. That noise sounds like top end noise, not injector tick, even with DI injectors. You could also put a breaker bar to your ear and try to pinpoint the noise a little more closely.
    B9 S4- EPL/AWE
    Sep 22 2011
    Western MA
    Anyone proposing thicker oil is in a time machine (used to be a good idea, not anymore). Bad plan. While it may make your motor quieter short term you will witness accelerated wear (grooves) especially on cams and cam bearings correlating exactly with what bearings and cam lobes that see oil last at start up (made even worse from start/stop). It can also cause fault codes with the variable valve timing.
    If you are in a hot climate and only change slightly you will probably be OK but I won't be doing that potentially expensive experiment myself.
    Thicker oil made more sense before variable valve timing/ start stop and oil passageways specifically designed for the thinner oils that will dangerously restrict oil flow with thicker oils.
    2020 SQ5 Ibis White
    2016 A3 Cabriolet Glacier White 2.0T
    2011 Q5 Ibis White 2.0T (sold)
    2008 A4 Cabriolet Ibis White 2.0TQ (sold)
    2000 A4 Laser Red 1.8TQM (sold)
    Dec 14 2019
    Ukraine
    I will inspect everything on next service, will try to find issue. The only strange thing for me is that there in absolutely no noise in Neutral when I rev the car to exact RPMs when noise in mostly audible when car in moving. I just can't get this. But noise frequency becomes faster when I accelerate to higher rpms and goes away when I lift the gas, so my logic tells it's engine related, however I can't get the noise on neutral
    Feb 23 2010
    Emmaus Pa
    Quote Originally Posted by WtA4WtQ5 View Post
    Do you know the difference in bearing clearance between the 2.9 and 3.0? Difference in VVT passages? I've yet to see this theory play itself out in the real world with 5w40. There is a member on here that did an oil analysis on 0W20 vs 5W40, both motul. If you were getting accelerated wear between the cams and journals that would have absolutely shown itself in the analysis.
    B9 S4- EPL/AWE
    Sep 22 2011
    Western MA
    Quote Originally Posted by CELison View Post
    Do you know the difference in bearing clearance between the 2.9 and 3.0? No.
    Difference in VVT passages? No.
    One oil analysis by itself does not prove to me that it is a good plan to deviate from manufacturer specified oil viscosity and spec in a modern, complex and very expensive engine. Visual appearance differences (less shiny to start) on wear surfaces will begin to appear well before any metals are actually are seen in a conventional motor oil analysis.
    If you change your oil outside of a dealer and have an engine warranty issue and are asked to provide receipts, not having the correct spec oil on your receipts to show most probably won't end well.
    2020 SQ5 Ibis White
    Jul 19 2019
    midwest
    You know it wouldn't have cost you any money from starting this pointless and irrelevant argument. Take this buffoonery to the oil discussion threads.
    Moving forward, I've had this sound both on the 0w20 508 and the RS5 spec oil. 37k miles, not really sure what to do about it since the dealer will just say HPFP. Not really wanting to pull valve covers off as im a nooby in the wrench world
    2018S4 Glacier White / JB4 / AWE Switchpath / BBS CI-R
    2009 G37S
    2019 Escalade
    Feb 23 2010
    Emmaus Pa
    Well that is false, it would absolutely show in an oil analysis. And it wouldn't be "less shiny", you would see score marks like bands just like any JB that is starved from oil. And if you can see those marks, that removed metal will show up in an OA. The 2.9 (5w40) and 3.0 (0w20) have the same oil pump part number. If the clearances and veins on the 3.0 are tighter, that would mean they would need to do a gear reduction to spin the 3.0 pump slower in order to maintain similar oil pressure. Did Audi do that? What exact hardware changes did they make if any for 0w20? I don't know either, and unless you know these things for sure, what you're saying is just your theory/what you've read on the internet. And hey, it may be correct. But what I'm willing to bet is, the switch to 0w20 was mainly emissions based and that running something like 5w40 will not cause any harm to the motor. So you keep using 0W20, I'll keep using 5w40 and more than likely neither of us will see any side effect from either.
    Cheers
    B9 S4- EPL/AWE
    Sep 22 2011
    Western MA
    It is your car, absolutely do what you want. Wrong viscosity and wrong spec. Good Luck to both of us! Is there even a VW 508/509 spec 5W-40 oil available?
    I do use 5w-40 of the correct spec in the car that it is specified to be used in. And every Audi we have had. My SQ5 is the first one that called for something different.
    2020 SQ5 Ibis White
    Feb 23 2010
    Emmaus Pa
    The manual for this motor says you can run VW50400. Which again, points to 0W20 being for emissions. Page 26-> https://www.yumpu.com/en/document/vi...5/ssp655-wg-en. So the whole you won't get proper lubrication on startup thing due to viscosity isn't really holding up since many 504 400 oils are 5w30.
    B9 S4- EPL/AWE
    Apr 11 2012
    when reports of this ticking first came up, I thought it could be a telltale sign that your motor was about to blow since that actually happened to one person on here, but years after, no one else whom had ticking reported their motor blew. My guess, Audi deemed it low risk and just a noise annoyance and is calling it "normal".
    Sep 22 2011
    Western MA
    I have that (4) year old document, learned a lot. My 2020 calls for 508.00 0w-20
    https://docs.google.com/viewer?url=h...-Year-2020.pdf
    Been running this since 4600 miles:
    https://www.amsoil.com/p/sae-0w-20-l...motor-oil-ezt/
    Engine is always quiet (exhaust not so much) and haven't used any oil on the MMI gauge currently @ 7K miles
    2020 SQ5 Ibis White
    Feb 23 2010
    Emmaus Pa
    There hasn't been any internal engine changes in those 4 years, which again points to it being for emissions. Why else would they take away the higher viscosity oil from the manual? Development on this motor started maybe 2014/2015? Since then EPA regs become a bigger and bigger hurtle, Audi in response specifies the oil that achieves better MPG should be used and gets rid of the other choice as it is not as emissions friendly. But I think we've derailed this thread enough. Sorry OP. Like others have said, many members experience this ticking with zero side effects besides the annoyance.
    B9 S4- EPL/AWE
    Dec 14 2019
    Ukraine
    CURRENT UPDATE
    Sound occurs only under load, even without car moving, if I hold both brake and accelerator to around 1100 RPM (mostly audible) as If you launch, ticking occurs. Absolutely no noise in neutral or park. Ticking becomes faster if you increase RPM and It goes away at around 1800 RPM. Sound is coming somewhere from back end of the engine or at the place where engine connects to gearbox. So this is surely not fuel related (hpfp or injectors) as it seems for now.
    Still searching for the reason, trying to call other local dealers if someone found solution. Possibly engine removal will be needed. However no side effects besides awful noise as for now.
    Dec 14 2019
    Ukraine
    Can you please tell anything further about rocker issue? Can’t find anything
    It turns out, my car was at the dealer about a year ago when it was discovered one rocker was out of its place, but any further damage was found
    Mar 01 2021
    Miami, FL
    Valvetrain noise shouldn't change under load, just rpm. Check around the exhaust for any leaks, spray soapy water on it when completely cold, and see if it bubbles when it starts.
    Feb 23 2010
    Emmaus Pa
    After hearing all these ticking at low rpm stories, I have a feeling it my be lspi. An actual rod knock would show itself sooner than later with engine failure and lifter noise would be through all rpms and idle. What fuel are you using? These motors have all the ingredients for lspi. Small turbo, DI, shit IC, low rpm shift points. I’m not sure when the converter locks up but that would be interesting to know too. I remember the one blown motor thread that had ticking before hand and had destroyed a piston. To me, that says detonation. Didn’t spin a bearing, destroy a lifter, or toss a rod. The piston got the hell beaten out of it. Just my opinion from fiddle fucking with Audis the past 15 or so years as a hobby. Not a professional mechanic so take that with a grain of salt.
    Mar 26 2021
    Dallas
    Tricky part of oil viscosity, there’s some countries that Audi recommended use vw504 instead of vw508 due to the gas quality. (Ex. Australia, their gas does not comply to EN288. anybody wonder, just look up owners manual for Australian version or try Mobil1 Australia and use oil finder). The other proof is on Porsche's document, there are group 1 and group 2 countries, group 2 means hot climate and group 1 is rest of world, if you are in group 2, Porsche recommends to use VW502(Porsche A40) spec for EA839 equipped vehicle. All in all, EA839 is capable to handle multiple specs other than what Audi USA "Requires". However, if you are in the US, and you are not using oil specs that Audi USA requires, there is high chance they would not honor the warranty.
    Dec 12 2019
    St. Louis
    Quote Originally Posted by dasistspark View Post
    To add to this, always make sure you keep receipts for your oil if you do it yourself. Had an issue on my B8 A4 where I was loosing almost a quart a week (car was out of warranty with about 55k miles on it). My Audi dealer went to battle with Audi USA about it and they tried blaming it on the kind of oil I was using. They ended up replacing about $8,000 worth of parts for free after I submitted 3 years worth of my oil purchases receipts
    Oct 27 2019
    DFW
    Took 2018 S5 (11/2017 in service date) to dealer for subtle clicking noise as described above (1500-2000 rpm, only under load).
    Dealer determined something is “wrong” in passenger side cylinder bank. Recommending 20hr $5,000 tear down to determine what the issue is.
    Car is out of factory warranty.
    Car is at dealer now, so I can’t take video of sound.
    Thoughts?
    Feb 02 2021
    San Diego
    My first s4 2018 did that, my second s4 2019 does that, the loaner 2022 A5 Sportback does that, and so I don't think it's anything to worry about
    Senior Member Two Rings AndreiMTM's Avatar
    Jul 15 2013
    MK7 GTI DSG
    Shelby Twp, Michigan
    Just bought a B9 S5 with 75k miles and noticed this exact noise. Only under load, doesn’t do it in neutral, same RPM range. Anybody find a solution or more insight on this? OP?
    Current: 2014 C7 Audi A6 3.0 TDI
    Past: B7 A4 avant s-line, , B7 manual passat, K04 Vw CC, B6 1.8t A4, C5 2.7TT manual A6, B5 manual passat, Mk4 VR6 Jetta.
    Established Member Two Rings Dsobczak's Avatar
    Oct 16 2019
    Chicago
    Quote Originally Posted by Vladok View Post
    This is completely normal.... It a combination of a lot of thing on the car but what you are hearing is injector pulse and top end rotating assembly operations. Direct injection cars make a lot of feedback noise and this is 50% of the reason engine covers were designed! Yes they help with heat and look better to most consumers, but most of it is for sound dampening so people wouldn't think their car was trying to take itself apart LOL. You are also hearing it a lot more in this video b/c you are right next to the wall there.
    Here's the rule on engine noises, If it DOESN'T get louder with increased RPM, you haven't broken it yet! Broken top or bottom end part will sounds like hell the harder you push the motor. A great example of this is a blown STI motor from 15-19, sounds normal up to 3K, then the demons start to sing when you try and run all the boost!
    My EVO X did the same thing from the day I bought the with 25miles on it.... They ran plastic valve covers on my year and it was like a mining company set up shop in there!
    you can different oil if it bothers you but its fine!
    Junior Member Two Rings
    Sep 24 2022
    C8 A6
    Hi,
    Any Update?
    My 2018 SQ5 does have the noise. It doesn't have the ticking when the engine under 1100 rpm. The engine will make the ticking when it is above 1100 rpm, however the ticking will disappear when I lift the gas pedal even when the engine is above 1100 rpm. I'm not sure if it will still happen when it is greater than 2000rpm because the other engine noise is louder at that time.
    Jul 15 2013
    MK7 GTI DSG
    Also waiting for an update but doesn’t seem like OP is still active on here
    Veteran Member Three Rings E.Anderson's Avatar
    Jun 23 2010
    Oswego, IL
    pretty sure you're all fine. If you want less tick run 5w-30
    2021 S4 | PREMIUM PLUS | MYTHOS BLACK | ALU OPTIC | SPORT DIFF | B&O | LEATHER
    Previous
    2018 S4 | PREMIUM PLUS | DAYTONA GREY | BLACK OPTICS | SPORT DIFF | B&O | LEATHER | JB4
    2011 S4 MT6 | PREMIUM PLUS | QUARTZ GREY | TITANIUM PACKAGE | ROC EURO | LED INTERIOR | SPORT DIFF | B&O | LEATHER
    2008 A4 SE
    Sep 24 2022
    C8 A6
    Quote Originally Posted by E.Anderson View Post
    Yeah, I have the same feeling. I booked an appointment with the dealer to see if I can use thicker oil at the next service.
    2022 A6 Black
    2018 SQ5 Ibis White
    2018 Q5 Ibis White (sold)
    2018 Q3 Ibis White (sold)
    Jul 19 2019
    midwest
    Quote Originally Posted by DavidZ View Post
    You can, just buy some motul sport Esther 5w-30. Plenty of people are running it on this platform
    2009 G37S
    2019 Escalade
    Oct 13 2017
    Birmingham, AL
    Audi S4 B9 3.0T, rocker arm service. What to expect from S4 with 55.000 miles on clock ?
    https://youtu.be/otfln0yBGwM
    2018 S4: 034 Stage 1 ECU : S2 TCU : Wagner IC : Modded intake
    Sep 24 2022
    C8 A6
    Quote Originally Posted by YoYo View Post
    I read a lot related threads here and “Audi world”, and watched the YouTube. According to 034, they said they haven’t seen this failure, but did hear of it. For me, it is doubtful that a rocker arm failure won’t light the engine-light. Maybe you can ask the technician to check your engine banks with a stethoscope when there is any abnormal ticking.
    Most of the ticking comes from either di or hpfp, which you can easier tell the difference among them and timing chain, rocker arm, etc.
    2022 A6 Black
    2018 SQ5 Ibis White
    Feb 23 2010
    Emmaus Pa
    How would a failed rocker trigger a CEL? It would have to cause a misfire on that hole, which I don't see it doing most of the time. I've had collapsed lifters and no misfires.
    B9 S4- EPL/AWE
    Sep 24 2022
    C8 A6
    Quote Originally Posted by crhh95 View Post
    You know what. The noise can hardly be noticed when the temperature goes below 15 degree in Canada. I have to drive my car on highway a while to reproduce it.
    Jan 26 2019
    Care to share a link? I can only seem to find Sport ester 5W40 everywhere but not 5W30
    Jul 19 2019
    midwest
    Quote Originally Posted by Esmin23 View Post
    Sorry it’s 5w-40, I mistyped. FCP euro has it, or you might be able to save money with a bulk order on eBay. I got 8 bottles off there for a heavy discount
    2009 G37S
    2019 Escalade
