Results 1 to 11 of 11
    May 31 2011
    moore
    Coolant/Antifreeze
    Is it okay to top off the pink coolant reservoir with ones from Peak or any brand that is formulated for European cars? Autozone site says it fits my vehicle but I'm not able to find G12 or G13 antifreeze locally. My level is below minimum.
    Sent from my SM-G955U1 using Audizine Forum mobile app
    Senior Member Three Rings BEight SFour's Avatar
    Oct 13 2019
    Alpine White E36 M3.. RIP rear ended
    Bay Area CA
    Just fill it up with distilled water if you don't need to top it off that much. Thats what I always do. Or just regular water sometimes too haha
    Sent from my SM-G975U using Audizine Forum mobile app
    Veteran Member Three Rings supple's Avatar
    Jan 27 2016
    I don't have a garage
    Woburn, MA
    I've topped off with generic brand stuff before. As long as you make sure to stick with the right one. Top off non silicone with non silicone, you get the idea.
    Sent from my HD1907 using Audizine Forum mobile app
    2013 S4 Monsoon Grey | APR Stage 2 Single Pulley | Roc Euro Intake | 034 RSB + Drivetrain Inserts + Control Arms | CR-15 | KW V1
    RIP 2007 Brilliant Black A4 Quattro | Unitronic Stage 1+ | Bilstein Sport + H&R Sport | Apikol Snub | GFB DV+ | 034 Turbo Inlet, Street Density Motor Mounts, RSB & End Links, Control Arms | Pipercross Filter
    Sep 16 2020
    West Michigan
    Many AutoZone's these days carry Pentosin.
    2012 A6 Prestige - APR single pulley via Fluidampr 189, Injen intake+RS7 airbox, IE HPFP, EPL TCU, JHM HX, 034 motor mounts, Eurocode drivetrain inserts, gutted cats - 034 tunes purchased, not installed.
    May 31 2011
    moore
    Quote Originally Posted by sepheroth86 View Post
    Autozone and Advanced auto parts carry mostly Peak or Prestone in my area.
    Veteran Member Three Rings BucDan's Avatar
    Jul 19 2017
    San Diego, CA
    If you live in an area that doesn't snow, distilled water is fine to top off.
    Aug 01 2019
    2013 S4 APR Stage 2, 2009 Subaru 3.0R
    Statesboro, GA
    Have you checked NAPA? There is where I found the Pentosin.
    Jul 31 2016
    PA
    Distilled water is fine or any European formula should also be fine. You aren't going to significantly change the ratio going from min to max, even at 70-30, you are protected from freezing down to -5F or something like that.
    Sent from my SM-G988U using Audizine Forum mobile app
    Custom DP 194/57 E40 Water-Meth (Aquamist) | BG HPT ZF8 Tune | APR CPS with AWE Reservoir (Divorced Coolant Loop) | APR Open Intake and 034 Intake Tube | RSE Heat Shielded HFCs | CTS Downpipes with Vibrant UQ Resonators Added | AWE Touring Exhaust | 034 RSB | Bilstein B8 Shocks and H&R -3 Springs | ECS Trans and Drivetrain Inserts | 034 Trans and Motor Mounts | Moog Front End Links | Headlight Projector Retrofit and Painted Housings
    Aug 08 2010
    Alaska
    It's easy to just get the right stuff from any number of online sellers. Actually just got some of the SF in today for my B6. There is a chart here that might help, although some of the years are maybe not 100% accurate: https://www.fcpeuro.com/products/pp-...g012a8gm1-1-5l
    Established Member Two Rings Arn560's Avatar
    Aug 10 2015
    Toyota Sequoia SR5, VW Jetta
    Monroe, NJ
    Quote Originally Posted by hiwasss View Post
    Stop in at a VW or Audi dealership and snag a gallon!
    Sent from my P027 using Audizine Forum mobile app
    2011 B8 S4 Prestige, Ibis White, B & O, Nav, Carista Mods, Sports Differential, Black hide & Alcantara, CF inlays, S4 rubber mats, 19" Peelers, Ziza interior LEDs Lubed with Mobil 1.
    Dec 25 2019
    Howell, MI
    I used peak in mine. So far it’s been fine. I usually go with pentosin pentofrost, but my coolant pissed everywhere (loose drain plug) so I had to use what the store had. Just make sure it’s the g13 violet coolant, which is what our car takes. Peak makes the g13 violet euro formula.
