Results 1 to 11 of 11
    Junior Member One Ring
    Oct 14 2018
    Czech
    MIB2 retrofit help
    Hello, I have been trying to get help with no success in retrofitting MIB2 into A6 C7 pre-fl.
    I got a guy who can do softwares, CP, coding etc. but not wiring.
    Is anybody able to help me please?
    I need to retrofit MIB2 unit into car with MMI 3GP, rear view-camera, TV tuner and BOSE soundsystem.
    The guy that will be doing software coding got all units needed (MIB2, display, gateway, bose amp, USB ports, instrument cluster) but how to make connectors adjustments? can anybody help please?
    Established Member Two Rings vrod's Avatar
    Oct 02 2018
    Germany
    Most likely you won’t need any connection-changes, but the MIB2 unit has to be cracked. If you do standard CP Removal, the FeC’s are gonna get removedz
    Oct 14 2018
    Czech
    Thanks for reply but no... SW is no problem for me, but the pinout is whole different. Just look at MIB2 and 3GP back of units :(
    Apr 21 2022
    Sweden
    Hi! Did you fiind any thing? doing same for my Audi A7 prefacelift RMC to MIB2 and im not sure what wiring i need for gateway to MMI.
    Sep 08 2021
    2013 Chevy Tahoe
    Philadelphia, PA
    im gonna follow this cuz i been interested in the swap, but everything points to just get an RSNAV instead of retrofitting just based off the cost.. MIB retrofit is almost double buying an RSNAV
    Daily -2015 Audi A7 Prestige| 20% rear & 35% front 3M Ceramic IR tints|Custom Alcantara Starlight Headliner|
    Music, Real Estate, and Audi
    Veteran Member Four Rings Audisthesia's Avatar
    Aug 14 2019
    Tampa
    Quote Originally Posted by AudiInMyA7 View Post
    Not to mention the huge leap in functionality
    18 S6
    Sep 08 2021
    2013 Chevy Tahoe
    Philadelphia, PA
    the only reason i havent switched to RSNAV yet is because i really like tucking away the screen sometimes... kind of "unplugs" me lol
    Aug 14 2019
    Tampa
    If your MMI is pre MIB2, there are touchscreen retrofits out there that fit in factory folding housing.
    18 S6
    Sep 08 2021
    2013 Chevy Tahoe
    Philadelphia, PA
    Quote Originally Posted by Audisthesia View Post
    ..... tell me more im intrigued, i have the 3g+ high or whatever its called
    Aug 14 2019
    Tampa
    I know they are sold on aliexpress. I saw numerous models when looking to find one for mib2. Someone on the forums installed one as well, you’d have to search for that as I don’t recall what thread it was in
    18 S6
    Apr 13 2013
    UAE
    @AudiInMyA7
    please share any info you could find
