In order of what happened:
-Made a whooshing noise from the pass side firewall
-Started stumbling above 3.5k
-Heavy fuel/exhaust smell in cabin
- Exhaust started backfiring, started running like shit
-Car was really sluggish for a few minutes, flashing CEL
-Flashing CEL cleared up, car started running better again.
-Codes are all focussed on cylinders 4,5,6 (Drivers side)
Here are the codes:
17775 Cylinder 5 Ignition Circuit
17778 Cylinder 6 Ignition Circuit: Open Circuit
17772 Cylinder 4 Ignition Circuit
17865 EGT Bank 2 (Residual, has been there for months)
16689 Cylinder 5 Misfire Detected
16690 Cylinder 6 Misfire Detected
16688 Cylinder 4 Misfire Detected
16684 Random/Multiple Cylinder Misfire Detected
The plugs I pulled all look like this (NGK PFR6Q with .030~ gap)
Coil packs are visually okay. Minus the one pictured, because it doesn't have a seal.
I did a boost leak test, nothing found. Timing is fine.
I considered an MAF issue, but I don't think a MAF issue would mess with only the right bank cylinders. Maybe an ICM? Or could replacing my plugs clear it up? I've replaced them with .025 NGK BKR7E, but I'm waiting on a coil pack seal before I button everything back together.
