18” 255/60 Goodyear Eagle Sport All-Season AO (W-Speed Rated) Made in Germany tires made for Audi.
These are the original tires that came on the Q7 when purchased on November 29, 2019.
Took the car in for a recall of Deformation Element and 20,000 oil change. I complained about the serious issue with both of the front tires as previously described. The rear tires were like new and had no rubber loss like the front tires. The actual mileage on the car at the time of service was 19,583.
The service advisor blamed the roads I drive on and driving during summer high temperatures. He also talked about the Technical Service Advisory. I was informed that I would have to pay for the replacement tires and alignment. I was over a millage stated in the TSB. Thank but no thank you.
My local tire shop guy looked at the 2 front tires and was surprised at the damage. The tread wear bars showed uniform ware across the tire with chunks and slivers of rubber pealing off the tire. The actual tread wear on the front looked tires about the same as the rear. Mike commented he had seen tires worn like this only once before and it was a truck being used at a Rock Quarry. I told him I did not want to use the same tire as a replacement and he agreed. He recommended replacing all four tires with 225/60R 18XL 112V Continental Crosscontact LX Sport. These tires are Extra Load instead of Standard Load of the Audi AO tires.
