NEW: IE C7/C7.5 S6 & S7 4.0T ECU Stage 1 Tune!
IE is excited to announce the all-new ECU & DSG Tune for the Audi 4.0T C7/C7.5 S6 and S7 is now available! Enjoy a massive power increase, refined driving maps, harder launches, and full E85 support that will deliver up to 652HP & 760TQ!
The all-new 4.0T EA824 Tune is packed with features, are you ready for real power?
Click here ---> https://bit.ly/3yxRUnH
Power Results:
Audi Advertised stock: 420HP / 406TQ
IE measured Stock: 455HP / 456TQ
IE Stage 1 91 Octane: 575HP / 621TQ
IE Stage 1 93 Octane: 602HP / 646TQ
IE Stage 1 E85: 652HP / 760TQ
Leading Features:
- IE guarantee -45 days risk free
- Horsepower & torque gains maximized
- Stock boost control optimized for all conditions
- 91, 93, & E85 octanes available (95, 98, RON & E85)
- ECU safely adapts between E65-E85 Ethanol
- Optional Exhaust Crackle feature
- Optional Ghost Cam feature
- Rev limiter increased to 6800 RPM with DSG flash
- Launch control torque increased for faster launches
- Road speed limiters removed
- Annoying cylinder deactivation deleted
- Engineered for all climates and elevations
- Direct port OBDII at-home flashing
- Easy octane switching takes only minutes
- Upgrade stages to match hardware upgrades
- Simple on/off feature toggling
- Read and clear diagnostic/problem codes
- Easy to use Data-logger
Full E85 Ethanol Support
E85 fuel unlocks the most performance potential from our ECU tunes for your Audi S6 or S7. Ethanol contains tons of oxygen, burns cooler, and has a high resistance to knock. This provides more horsepower and torque than running conventional gasoline and is more readily available (in most states) and less expensive than race gas. E85 is an optional fuel map included with all tune purchases.
Safeguards are included within the E85 ECU calibrations to adjust for ethanol as low as E65.
DSG Tune Required
Due to turbo sizing and engine characteristics, massive torque gains are seen through the low-mid range of the powerband. This exceeds the torque limitations of the factory DSG calibration and will cause slipping in the clutch packs. Instead of sandbagging power and reducing performance, IE tunes are safely engineered to fully realize all available performance, but will require the additional purchase of the DSG transmission tune to reliably take advantage of the intense power.
Learn More HERE
Optional Features
Ghost Camuses the variable valve timing to produce a lopey V8 idle. This large cam sounding idle is active during idle only and will return to normal function during driving.
Exhaust Crackle feature will add a motorsport-inspired crackle sound to your exhaust note when you free-rev the engine or decelerate.
Easy Install
IE's POWERlink Cable and Flash Wizard software gives you the freedom to quickly flash your new IE ECU Tune. Simply plug your POWERlink into the vehicle's OBD-2 port and follow the on-screen directions, it's that easy!
Reliability Testing
IE's fully proven software brings track-ready ECU programming to your turbocharged V8 engine while retaining factory comfort and reliability. IE's own tuning technology suite is used to completely reverse-engineer the factory ECU mapping, allowing our software engineers access to realign all safety protocols and sensors for the new performance calibration. Every tune parameter undergoes months of testing on our in-house dyno systems that utilize the world's only Sea Level Generator developed specifically to verify tune operations in any condition. Confidently drive from LA to Pikes Peak with power that will keep you smiling every mile!
Five Star Guarantee
IE's number one goal from purchase to installation is to provide you with the best customer experience in the industry. We want what you want; a simple purchase process, products that exceed expectations, and a brand that's got your back. If at any point you have any questions, need help, or require support with your new tune IE's educated customer support team and tuning specialists are standing by and happy to help. Purchasing an IE tune not only guarantees a quality product, but that you will always have us in your corner.
Live Fast, Buy Fun
