I did the recommended coding (Module 19, Start Stop Voltage Limit set to 12) to disable Stop/Start. That disabled it except for when I shift into Park. Should Stop/Start be completely eliminated by this coding? The other method that I've read about is to modify Module 19 - Start/Stopp Auntemperaturvorgabe-Minimaltemperatur, but that parameter doesn't appear in the list under Module 19. Any suggestions?
Also, I've read that in order to display the gear number while in Drive, you can modify Single Gear Display under 02-Auto Trans to a value of "D on/S on". On my car there are only 3 channels under 02-Auto Trans. Production Mode, Deactivate Production Mode, and Dynamometer Mode. No Single Gear Display. Is there another way to do this?
