Results 1 to 40 of 67
    Veteran Member Four Rings Samsonite's Avatar
    Apr 15 2013
    Golf Clubs
    Minnesota
    C7.5 4.0T X-Pipe?
    Recently traded in our C7 S6 for a C7.5 with sport exhaust. After searching exhaust, it looks like I want start by trying to delete the suitcase with an X-pipe and probably delete the 2 resonators too. Our C7 was stage 2 with catless downpipes and full exhaust and we’re looking to start out a little more tame with this one.
    So, wondering if it matters where to get the X-pipe? Looking around, they seem to vary in price quite a bit. Seeing if there is a proven favorite here on the forum or what to look for.
    Thanks.
    2020 Range Rover Sport • HSE Dynamic • SC 5.0 V8 • Santorini Black
    2016 S6 • Ibis White • Black Optic • Sport Pckg • APR TCU/ECU Stage 3
    2013 S6 • Phantom Black • Sport Diff • Revo Stage 2
    2013 Q7 S-line 3.0T • Glacier White • Sport Pckg
    2011 S4 6MT • Ibis White • Black Optic • Sport Diff
    2008 A4 S-line Avant 2.0T 6MT • Ibis White • APR Stage 2
    2008 A4 S-line Avant 2.0T • Dolphin Grey
    2005 A4 Ultrasport 3.0 6MT • Dolphin Grey
    Veteran Member Three Rings choy188's Avatar
    Jun 02 2019
    2019 S5 Sportback, 2022 Polestar 2; Sold: 2012 A6 3.0T, 2006 A6 4.2
    Danville, CA
    From the ones I've heard the ecs one is by far my favorite, not too expensive too
    Sent from my SM-N986U1 using Tapatalk
    2019 S5 Sportback Prestige | Navarra Blue Metallic | Black | Options: Sport Package, Dynamic Steering, Cold/Warm Weather Package, Black Optics, Direct TPMS Retrofit
    Sold: 2012 A6 Prestige | Oolong Gray Metallic | Titanium Gray | Options: Innovation Pack, Cold Weather Pack | Mods: Lane Assist Retrofit, Injen Intake, 034 Stage 1 ECU+TCU
    Sold: 2006 A6 4.2 | Atlas Gray Metallic | Platinum | Options: Technology Pack, Cold Weather Pack
    Veteran Member Three Rings Burkeomatic's Avatar
    Feb 22 2021
    14 A8L 4.0T, 96 Corolla Wagon
    San Antonio
    Yep, install is less than 2 hours on a lift too.
    2014 A8L 4.0T - DS1 Stage 4/JHM TCU, FE Axlebreakers, E85
    Apr 15 2013
    Golf Clubs
    Minnesota
    Looking at the ECS one, isn’t that actually an H-Pipe?
    Feb 22 2021
    San Antonio
    No, it is an x-pipe. A "H" pipe would be two separate pipes connected by an individual third pipe.
    Established Member Two Rings tuscani66's Avatar
    Aug 09 2018
    Pittsburgh-PA/Acworth-GA
    I just ordered the ECS about an hour ago, says it'll ship Friday, wonder how long it'll take to get to GA.
    Samsonite, did you order it? It is an X, not H, and I ordered it because it looks to be the cleanest and priced well. Couple weeks ago I bought the Magnaflow 2.25" X Pipe section for 100 bucks and was going to go to a shop to have it cut and welded in, changed my mind because I knew it wouldn't clean but would be cheaper than the ECS.
    Mostly changed my mind because when I install the ECS version I'm not cutting into my OEM system (as it was intended) as I'm just going to remove the rest of it, then take it to the exhaust shop to mendral on some pipes continuing from the ECS section as I intend to delete my rear mufflers too.
    2016 S7 Prestige in Mythos Black over Arras Interior.
    Other Garage Items : Volvo S60 R / Lexus RC F / Saleen S281-Cobra Conv / Porsche Cayenne Turbo S / Toyota Tundra
    Veteran Member Four Rings 09S5's Avatar
    Dec 04 2015
    A8L, 4X4, c6 VETTE, New CTS-V
    TN
    Just order 1.
    Sent from my SM-N976V using Tapatalk
    Oct 19 2019
    2013 S7 Prestige, 2006 Yamaha YZF-R6R
    Arizona
    I recently installed the ECS one onto my '13 S7. Honestly, pretty disappointed with it. It is barely louder than stock on cold start and doesn't provide any real growl under load.
    Sent from my SM-N970U1 using Audizine Forum mobile app
    Dec 04 2015
    TN
    Oh boy refund time.
    Dec 04 2015
    TN
    Maybe H pipe is the way to go.
    Watch "2016 Audi S7 resonator delete" on YouTube
    https://youtu.be/hr15WdKhmQE
    Dec 04 2015
    TN
    Hopefully I can get that same growling from the Champ.
    With the suitecase delete, aka H pipe instead of X.
    I have the sport exhaust which sounds shitty..
    More to follow.
    Account Terminated Four Rings
    Mar 11 2014
    Dallas/TX
    I went with the Magnaflow X pipe . Significant difference over stock and it screams in dynamic.
    Sent from my SM-N975U using Tapatalk
    Aug 09 2018
    Quote Originally Posted by AZallroadProj View Post
    Do you have the OEM S7 sport exhaust? I learned that there is a difference between the non-sport and sport exhaust and doing the X-Pipe swap for suitcase muffler made a difference. My neighbor has a S6 with sport exhaust and his does growl a bit more, prior to swap, his exhaust is already louder than mine and that is because I do not have the sport exhaust on my S7.
    I personally am deleting the suitcase with this ECS conversion and deleting the rear mufflers, I heard a S6 with this scenario setup (xpipe swap and no rear mufflers) and sounds great!
    Jun 02 2014
    Waukesha, WI
    I recently had an Amazon X pipe installed in place of my main suitcase muffler on my 18 S6 with sport exhaust. The result, in my opinion, is just right. More noise than stock, and almost exotic sounding in sport mode when getting after it.
    2018 S6
    Veteran Member Four Rings esemes's Avatar
    Jul 02 2019
    whirlpool cabrio washer and dryer
    clearwater florida
    I have the suitcase muffler removed - straight through passage.
    You NEED to have the valves forced open if you do this. A cheap plug in is available and an easy install.
    I have the nice V8 sound and the turbos on demand.
    the crackles are no longer though. they are moreso shotgun bangs.... for sure.
    2016 S6 - sport - optx- atlas - AE nardo
    Junior Member One Ring
    Apr 26 2014
    Netherlands
    Quote Originally Posted by esemes View Post
    Hi,
    Do you know where to get this plugin?
    Best regards,
    Marvin
    Jul 02 2019
    clearwater florida
    Quote Originally Posted by Freemann View Post
    Hi,
    Best regards,
    Marvin
    yep. bought from here, too.
    https://www.audizine.com/forum/showt...ete-Simulators
    Apr 26 2014
    Netherlands
    Thank you!.
    I have the pre-facelift (2013), so I just found out that it doesn't require having the forced valve open with suitcase muffler delete. They can function normally as stock. As both of the valves of the pre-facelift model are located behind the rear resonators never blocking the flow completely.
    Junior Member Two Rings DVS S6's Avatar
    Jan 06 2020
    Birmingham, AL
    Just FYI, I got the ECS xpipe about a month ago and it's a substantial difference in sound. It actually sounds like a high end sports car, lol
    I have a 2016 with sport exhaust.
    It's a perfect amount of V8 growl that makes the car sound like it should from the factory.
    I love the sound of a cold start and driving under bridges that much more.
    It's very well built, easy install and costs less than $300.
    Sent from my SM-N986U using Tapatalk
    May 05 2021
    Toronto, ON Canada
    Guys, who has a clip or review on the xpipe with nonsport exhaust? Theres so many posts with different reviews. I just want a tad more louder than stock but no drone or ricer sound. Im sure muffler delete would sound the best but its way too loud.
    Dec 04 2015
    TN
    Quote Originally Posted by eclipes1127 View Post
    Here's a real good video on exhaust.
    Aug 09 2018
    That video, above, both S6 has the sport exhaust FYI.
    Dec 04 2015
    TN
    Aug 09 2018
    Nice link! Thanks.
    Sad, the first sound clip of the S6 4.0L Stock is still louder than my S7 4.0L Stock. My new ECS xpipe has been sitting in my garage all week, been stuck doing house work, and now I'm leaving town for a few weeks so maybe in July I can do my exhaust change.
    Dec 04 2015
    TN
    Quote Originally Posted by tuscani66 View Post
    Nice link! Thanks.
    Thanks.
    I'm following your led on that ESC x pipe.
    I received mines today hopefully after the 4th July I will get it installed by a exhaust shop.
    Quality looks good as you know.
    I hoping I get that deep growling without any drone.
    Dec 04 2015
    TN
    I'm not sure why my pics looks distorted when upload on this forum but it's starting to bug me.
    Samsung Galaxy Note 10+ 5G.
    Aug 09 2018
    Quote Originally Posted by 09S5 View Post
    Thanks.
    Looks good, here it is installed (just ignore the other bit of it).
    I also cut off my mufflers, due to car warmed up I don't have "cold start run/idle" but I have a couple rev's, I'll get a cold start tomorrow since I want one anyways.
    Aug 09 2018
    Not sure, but doesn't look distorted to me. I forgot to get a warm rev just doing the ECS X-Pipe, sorry, so I don't have a video/sound of a before and after. I just did it all at once (ECS X install and straight out the rear with welded on dual/slanted/staggered tips.
    Dec 04 2015
    TN
    Looks amazing brother.
    I have the Sport exhaust once installed I'll do a sound clip also.
    Veteran Member Four Rings Audisthesia's Avatar
    Aug 14 2019
    Tampa
    "nice vc8 SOUND""" lmfao
    More like Richard Petty firing up his #43 with headers
    18 S6
    Apr 15 2020
    houston
    What you guys think about the 034 xpipe they just released ?
    Jul 02 2019
    clearwater florida
    Quote Originally Posted by Audisthesia View Post
    You know it brings smiles for miles....
    which reminds me, I have next up some.........
    Dec 04 2015
    TN
    Here's mines
    ECS tuning x pipe.
    Watch "2017 s7 COLD START up, ECS tune x pipe." on YouTube
    https://youtube.com/shorts/zlr5yHZ5mwY?feature=share
    Dec 04 2015
    TN
    Another 1
    Watch "2017 Audi S7, X pipe w/ sport exhaust." on YouTube
    https://youtube.com/shorts/ER9i82YJY_g?feature=share
    Aug 09 2018
    Quote Originally Posted by ayoaudi View Post
    Looks the same as others, but at 300 bucks shipped I think is a deal; it is basically on par for a mandrel bent exhaust with X-Weld section that a local exhaust shop would charge in my opinion but this way you can do it yourself at home and don't have to worry about transporting dirty/old section back home or landfill (or some shops may charge disposal fee).
    Here's mines
    ECS tuning x pipe.
    Nice! Here is my warm and cold start (2016 with ECS xpipe delete and no rear mufflers):
    Warm : https://youtu.be/5nw7bCIfw74
    Cold : https://youtu.be/N2LH6877NMQ
    Dec 04 2015
    TN
    Sounds dam good brah.
    Aug 09 2018
    Thanks!!
    Senior Member Two Rings sittinlow's Avatar
    Apr 08 2009
    Long Island
    any sound clips or videos? Sounds exactly like what I may need to do haha
    Jul 23 2020
    Sold - 2017 Audi S7
    Ontario, Canada
    Guys how is the sport exhaust and non sport exhaust is defined ? I’m not sure what I have. I know my exhaust is valved but really in dynamic mode now much of a change in the exhaust note.
    Aug 27 2016
    B5 S4
    Austin
    2016 stage 1+ w/ sport exhaust. I went to my local muff shop and they pulled both res. and suitcase. He welded in a random X pipe and two straights for $300 out the door in two hours.
    Nothing fancy! I get compliments all the time. Substantially louder but not too bad for me(late 50's). Allot of Tesla's with stupid license plates in my neighborhood so its my way of pushing back. My wife on the other hand does not appreciate it. She says it sounds like some kids Mustang;)
