Results 1 to 4 of 4
    Junior Member One Ring porschelou's Avatar
    Aug 21 2018
    02 Porsche 911, 2010 Audi A4 , 1985 Euro M6, 1968 RS/SS BB Conv Camaro, Italian Made Shifter Go-kart
    Mooresville,NC
    2010 A4 2.0t P0341 & Flashing EPC Light Fixed
    Hello,
    Figured I would post this and hopefully help someone one out. Car - CAEB 2010 2.0T A4 FWD
    History:
    - Bought the car with a destroyed head ( normal timing chain tension failure)
    - Rebuilt the engine using "Audi parts from China"
    - Rebuild lasted one year - Ring land on one piston broke - zero compression - out comes the engine again
    - NEVER buy parts made in China - everyone I have bought has failed.
    - Rebuilt the engine using JE pistons / found bad cam scoring on the head so bought a rebuilt head as well.
    - Ran great for another year ( 10k miles)
    - Drove it 30miles to downtown Charlotte and the EPC light started flashing
    - At 1200-1500 RPM the light would flash and car would buck
    - Scanned the ECU - has P0341 Cam Error
    - Noticed it only did it when the oil was hot
    - Verified the oil pressure at idle - 11psi - way too low. Staring thinking bearings but the only have 10k on them.
    Fix:
    - Swapped in a spare cam sensor - No help
    - Took a guess and installed a new N205 spool valve into the intake cam - No help
    - Took the cam bride off and BINGO! Found a small spring laying behind the bridge...
    - No idea how the spring came out but it hold the check ball tight. The check ball was now just loose inside the bridge.
    - Bought a new updated AUDI Bridge and tossed it in - Runs great now...
    - Yes I had an aftermarket Bridge in the car - never again.
    Figured I would pass this along and hopefully help someone out in the future.
    2011 Audi A5 CAEB Prestige, S-line, B&O - (H&R Coil Overs), Stance Rims, 275/30-20, Euro Headlights, ARP Carbon Fiber CAI
    2010 Audi A4 CAEB - Premium Plus - Bright Red
    02 Porsche 911 Aero - Speed Yellow, 6-speed, GT3 Suspension
    85 BMW M6 Euro - M88, 5-speed, Buffalo Leather
    68 Camaro 396 RS/SS Conv 1 of 400 made
    Veteran Member Four Rings RPMtech147's Avatar
    Apr 05 2014
    Texas
    = ) I see the screen fail on every one I take apart but I had one blow out the check ball on me the other day....First time for everything. The one I had cracked the casting where it held the check ball and I had to fish the pieces out of the oil port behind it.
    B6 S4, B8 A4, 8P A3, and something, something.
    Feb 15 2016
    Cambridge,Ontario
    There are many who swear " audi of China" parts are just as good. You will never sway those people.
    Sent from my SM-G973W using Audizine Forum mobile app
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Oct 10 2016
    Colorado
    Thank you so much for sharing this.
    I'm having the same symptom after several other fixes (coolant leak, PCV replacement, upper timing chain cover gasket replacement).
    Car has always been doing the EPC light flash and shaking/choking at low speed and sometime, stalling.
    How do you check the oil pressure? Also, any guides on how diagnosing the bridge?
