Results 1 to 6 of 6
    May 22 2021
    Hongkong
    A4 B7 instrument cluster swap color DIS
    I had a A4 B7 with red DIS cluster. weeks ago i found a A4 B6 cluster with color DIS in a junkyard.
    1、could i just swap the color LCD part?is it work?
    2、i knew A4B6 is RB4 cluster and b7 is RB8,can i swap them by reprograming of some tools like vvdi?or may be just impossible?
    tks for your great information!
    Jan 26 2017
    2008 Audi A4 Quattro
    St. Louis, Missouri
    Quote Originally Posted by cady_dolce View Post
    The parts are physically incompatible. Swapping screens is not possible. There is a company that can reprogram the new dash to work. Let me look it up.
    Sent from my Pixel 5 using Audizine Forum mobile app
    Jan 26 2017
    St. Louis, Missouri
    https://www.speedosolutions.com/Audi...ster_p_38.html
    Here is what I found when I was searching.
    May 22 2021
    Hongkong
    i found your website before.it says b6 b7 cluster is incompatible.i dont know if it's ture because lot of b7 in china swapped.
    seem so had to reprogram by myself.actually i had many equipment like xhorse vvdi and xtools i80 pad.would it help?
    Veteran Member Four Rings a4audi4fun's Avatar
    Sep 28 2007
    2017 B9 A4 Technik 6 spd manual, S-Line , 2008 B7 2.0T Avant 6MTQS S-Line, Past-2005 B6 A4 3.0 6MTQS
    Vancouver, BC, Canada
    Pretty sure the issue between B6 & B7 clusters is the immobiliser difference these models which means ECU is also involved. Link aaronfield33 posted is the best bet if you want to switch clusters. Red B7 can be replaced with colour B7 cluster - that's what my dealer had to do for me when I bought my car new but there's a story behind why I made them do that.
    Mar 24 2013
    Oakdale, CT
    You can switch to a B7 color cluster with reprogramming by speedosolutions, but a B6 cluster will not work.
    -Adam
