I’m getting a misfire randomly but mostly at idle and only cylinder 3. Tried swapping over coil packs and spark plugs but misfire stays at 3. I’ve put a new pcv on, looked for leaks,new valve cover gasket, cleaned the maf sensor and put an injector clean additive in the tank just to try. I’m thinking it might be an injector causing this or maybe a vacuum leak somewhere. Anyone have experience of something similar, I’d really appreciate the help. Also how bad is it to drive it like this? It drives fine but idle is rough but rpms stay even. I need it to get to work so I don’t have much choice than to drive it like this until I figure it out. Thanks !
