Results 1 to 6 of 6
    Senior Member Three Rings sage0607's Avatar
    Jul 30 2020
    2014 f150 5.0 coyote full bolt on e85 175 shot nitrous
    Minnesota
    C7 a6 test pipe install
    Does anyone know if you have to raise the motor to install test pipes on the a6 c7 like you do on the dsg s4's?
    Sent from my SM-G960U using Audizine Forum mobile app
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    On my 2012 A7 I had to sag the back end of the trans to get the old converter in and out. If you take the cowl bulkhead plate out it will help with access to the top studs. I only worked on the passenger side, I remember reading that you will have the steering wheel linkage in the way on the driver side.
    Jul 30 2020
    Minnesota
    Okay I see I'll definitly figure it out when the time come haha
    Nov 27 2018
    Valparaiso, IN
    You will need about 4 feet of extensions to reach the nuts from below. for the top nuts 1/4 inch sockets worked better for me since I needed to reach in 18 - 24 inches and the 1/4 inch tools were lighter than the 3/8 inch tools. You might wind up needing to replace the exhaust studs in the repairs as well. You can get an stud extractor from Autozone for about $20.
    If you run into problems in the repairs feel free to PM.
    Sep 16 2020
    West Michigan
    Please make a video or writeup!
    2012 A6 Prestige - APR single pulley via Fluidampr 189, Injen intake+RS7 airbox, IE HPFP, EPL TCU, JHM HX, 034 motor mounts, Eurocode drivetrain inserts, gutted cats - 034 tunes purchased, not installed.
    Jul 30 2020
    Minnesota
    Quote Originally Posted by Valpo A7 View Post
    Thanks man, I won't get to that for a little while here as I still need to get my ported blower and ie throttle body ported as well
