Results 1 to 19 of 19
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    Thinking about getting a power washer
    So I am thinking about getting a power washer and foam cannon for cleaning cars and cleaning around the house. Cleaning My deck and pool area should be a lot easier with a power washer.
    I was thinking about this power washer because it gets great reviews. I don’t need anything huge or to the point it can strip rust.
    Sun Joe SPX3000 2030 Max PSI 1.76 GPM 14.5-Amp Electric High Pressure Washer, Cleans Cars/Fences/Patios https://www.amazon.com/dp/B00CPGMUXW...ing=UTF8&psc=1
    Also I was thinking about this foam cannon.
    Tool Daily Foam Cannon with 1/4 Inch Quick Connector, 1 Liter, 5 Pressure Washer Nozzle Tips https://www.amazon.com/dp/B07HC898GM...ing=UTF8&psc=1
    Why this one? Not really sure other it seems to get top reviews at Amazon.
    If anyone has other recommendations please post them up.
    Veteran Member Three Rings eurospek's Avatar
    Mar 15 2008
    Chicago
    Check out Obsessed Garage on YouTube. Very extensive testing of all power washers on the market. I personally went with the Karcher K1700 Cube, awesome unit, but stock accessories (wand and hose) are lacking, as with most stock units. That’s your first area of upgrades.
    Junior Member Two Rings
    Jul 06 2017
    2014 Audi S5
    Albany, NY
    Quote Originally Posted by Valpo A7 View Post
    I have that sun joe. It’s solid and gets the job done. I would just get a stubby nozzle since the large one is cumbersome
    Sep 21 2015
    Plano, Texas
    Another +1 to Obsessed Garage, and even if you don't buy your pressure washer from him, you're far better off buying his accessories, hose, fittings and trigger/wand/foam cannon from him, as he's cleverly assembled the best and most convenient lists of parts that actually last and go much farther than trying to shop for the same equivalents on Amazon.
    The recent reviews on the ACTIVE VE52 washer seem impressive for a light-duty, inexpensive pressure washer for a car-- far better than Sun Joe. I'm still holding out for a deal on a proper triplex pump with TSS, like the AR630-TSS, but the AR Blue Clean AR610 seems to be a decent middle ground and will remain compatible with a 15A household circuit.
    Veteran Member Three Rings choy188's Avatar
    Jun 02 2019
    2019 S5 Sportback, 2022 Polestar 2; Sold: 2012 A6 3.0T, 2006 A6 4.2
    Danville, CA
    I got a greenworks one from Costco but I'm not sure which one
    Sent from my SM-N986U1 using Tapatalk
    2019 S5 Sportback Prestige | Navarra Blue Metallic | Black | Options: Sport Package, Dynamic Steering, Cold/Warm Weather Package, Black Optics, Direct TPMS Retrofit
    Sold: 2012 A6 Prestige | Oolong Gray Metallic | Titanium Gray | Options: Innovation Pack, Cold Weather Pack | Mods: Lane Assist Retrofit, Injen Intake, 034 Stage 1 ECU+TCU
    Sold: 2006 A6 4.2 | Atlas Gray Metallic | Platinum | Options: Technology Pack, Cold Weather Pack
    Veteran Member Three Rings WatchMeSpend's Avatar
    Mar 19 2019
    2016 A6 3.0T Technik S-Line
    Toronto/Ontario
    I have the Sun Joe SPX you are looking at. It gets the job done. I use it to power wash the fences, soffits and windows. I use a windows concentrate in one tank and simple green in the other for dirty jobs.
    I pressure wash the curbs at the street and all my patio stones to keep them looking new.
    I use a foam cannon from Chemical Guys and numerous soaps depending on the time of year (Mr Pink for the first clean of the summer) and then citrus wash and gloss unless I’m applying Hydr02.
    I used to pressure wash the dirt off the driveway but I bought an EGO 650 CFM blower to dry the car without touching it.
    The leaf blower has enough power to small blow stones away without the mess of water.
    Cleaning has never been easier. Every homeowner should have a pressure washer and a powerful blower to make short work of tasks.
    The blower gets all the water out of every nook and cranny on the car, like S-Line honeycomb, the water that hides under the window trim, the water that hides behind the mirror etc.
    No touching after a wax or Hydr02 means no visible scratches and a very shiny car.
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by eurospek View Post
    Karcher K1700 Cube
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Established Member Two Rings dmroberson's Avatar
    Mar 27 2012
    2021 Hyundai Palisade Caligraphy
    Scott AFB, IL
    I have the Sun Joe SPX4000. Been using it since 2017 on multiple cars. Works very well. I typically use the low pressure setting on the car and high setting on everything else.
    Understeer -- n. [uhn-dur-steer] "Why isn't this $h1t turning!?"
    Oversteer -- n. [oh-vur-steer] "Oh, $h1t!!"
    Veteran Member Three Rings GasMan's Avatar
    Jan 13 2019
    Michigan
    You get what you pay for with Sun Joe. I had an electric unit from them that started leaking this year. Tore it apart to discover a non serviceable part had broken. To the trash.
    Bought a Husqvarna gas unit from Costco.
    Both would work the same for your car, but if plan on using the power washer for concrete or siding I'd step up to a gas powered unit. 3200 psi with the Husqvarna can do things my 2200 psi Sun Joe could never do.
    2016 RS7 - Gone to car heaven
    2023 Taycan GTS
    Veteran Member Four Rings a4lownslow's Avatar
    Feb 12 2014
    2007 Audi A4 2.0T
    Hudson WI
    Just bought this with the griots foam blaster. Love it and short wash gun. My intent with this setup is for car detailing specifically. It’s small, portable, and doesn’t require gas (obviously). It may be capable for other light duty tasks but if you want to pressure wash your house, decks, etc you’ll want to break out the gas washer
    Active VE52 | 1800 PSI | 2.0 GPM | 13 Amp | Electric Pressure Washer https://www.amazon.com/dp/B0853F8RXR...GTDY3Q1D1QC0ZB
    Sooprinse High Pressure Washer Gun,3000 PSI Max with 5 Color Quick Connect Nozzles M22 Hose Connector 3.0 TIP https://www.amazon.com/dp/B07KPVM5MS...N7EJAAK9DPXGK3
    Established Member Two Rings HokieDude's Avatar
    Dec 05 2020
    Tesla MY
    Fredericksburg VA
    I'd go Chemical Guys for all your foam cannon needs - as far as the Power Washer I have a Honda and it's a BEAST! with everything in life, you get what you pay for
    2016 A5 B8.5 2.0T S-line premium+, suzuka gray metallic, B&O, tech pkg, sport pkg, blk optics // K&N drop-in // APR FMIC // ECS turbo inlet tube // ECS charge pipes // 034 turbo muffler delete // APR coil packs (red) // APR Stage 1
    Established Member Two Rings WhiteA7's Avatar
    Apr 25 2020
    2022 Audi E-tron
    Ft. Worth, TX
    I have the Sunjoe SPX3500. It works great for car but is weak compared to gas. We will see how long it lasts. When I use my Adam's Polishes foam cannon with it. I doesn't really do a good job foaming up I assume due to its lack of powah
    2016 A7 Prestige. IE CAI. IE Single pulley E85 ECU tune. IE TCU tune.
    Nov 27 2018
    Valparaiso, IN
    Thanks for the info guys. Still leaning towards the SunJoe but I need to check its flow and make sure its adequate for the foam cannon. Seems a few reviews are specific for minimum flow with a cannon. Father in law has a big 3,000 psi washer I can borrow for the bigger jobs, just looking for simple use out of this one. His tends to chew his deck a bit if your not careful with the stream.
    Aug 14 2012
    S4 B5 Imola Yellow, A6 4G Mugello Blue
    FIN
    Recently a Kärcher power washer in our garage started to have some hickups and wasn’t functioning properly. Nobody knows if it has ever been maintained or serviced during it’s life time so we gave it a little TLC. Just basic oil change, teardown, cleaning bits and it now functions again properly apart from a little leak. The said washer is from the year 1988 and built in West-Germany. Man those things were built to last and against anything the Warsaw Pact could through at them. To fix the leak, I think we need to find some gaskets from the museum of technology or something.
    Not really helpful on your search for a new power washer but wanted to share. :)
    Junior Member One Ring
    May 17 2020
    Vancouver Canada
    Sunjoe SPX3000 will power that foam gun perfectly fine.
    For even denser foam you can upgrade to a 1.1mm orifice; plenty of options on Amazon, etc
    Current: 2018 A6 Competition | 2020 Lexus UX
    Gone: 2018 S4 Technik | 2014 Ford Focus ST | 2007 Subaru Legacy | 2002 Ford Ranger | 1994 Toyota Camry Coupe | 1987 Toyota Camry
    Veteran Member Four Rings ericw.'s Avatar
    Apr 23 2011
    C7 S7 4.0TT, Jeep JKU, MB GLB
    Sac Area, CA
    I splurged and got the Dewalt and my friend's Sun Joe puts out much better water flow. He has this one: https://www.amazon.com/Sun-Joe-SPX30...dp/B00CPGMUXW/
    IG @lolzhax
    //AGILITYDRIVES.US
    C7 S7 4.0tt faster than kaploww and passed smog | LX7U | JHM STG3 ECU+TCU | JHM DP + CATBACK + Oil Screen Relocation + LW Crank Pulley + Heat Exchanger | SRM +4MM Turbos | S-FloV2 | EUROCODE SWAYS | CETE ASC | RFX7 | PS4S | RS7 FR+R | PD700R Splitter | Maxton Skirt+Spoiler Extensions | Indicator Delete | Hardwired
    b7 a4 2.0t | Stage 2+ | DTM Body [sold]
    Mar 19 2019
    Toronto/Ontario
    1000% it will do it. Most of the videos that fail a the foam cannon on any decent washer is for 3 reasons:
    1. Wrong soap/not enough soap
    2. Didn't put hot water in the cannon
    3. Didn't SLOWLY tilt the container back and forth to mix the water and soap.
    I paint the car with foam and let it drag all the surface dirt off which is going to take 5 plus minutes. I changed the orifice size because it was cheap to do and I don't think it made a difference. For what the washer costs, you can't go wrong. Don't store it outside in the winter without removing the water from it if you live in a cold area because that is how you'll break it, when the water freezes unless your prep the machine.
    Would I want a gas for more power? Sure. But in between my quiet EGO mower and the quiet Sun Joe, I can work early Sunday morning cleaning the car and mowing the lawn. This leaves the rest of the day to have a nap in front of the offset smoker while the pork shoulder or brisket is cooking.
    Nov 27 2018
    Valparaiso, IN
    Quote Originally Posted by WatchMeSpend View Post
    Thanks for this info.
    And sometime soon I will be picking your smoking brain about the pork shoulder and brisket, we just got a Traeger pellet smoker.
    Mar 19 2019
    Toronto/Ontario
    I keep my Traeger in between the stick burner and vertical bullet.
    When the weather turns to windy and rainy, I use the Traeger with a cover over it.
    The stick burner is king for flavor with certain meats but you can’t go far. The Traeger is king with chicken, sausages, baked beans, unattended pulled pork cooking sessions, bacon wrapped asparagus, atomic Buffalo turds, wings, smoked pork tenderloin and more.
    If it’s Saturday or Sunday and the car and house exterior is clean and the lawn is mowed, people know that I’m home and magically drop by. They smell the Traeger or stick burner and know good food is coming.
    Gotta get back to the track this year. Still need a HX and a trans tune. Spent all my money on investments so I might just be on the sidelines.
