Results 1 to 18 of 18
    Senior Member Three Rings sage0607's Avatar
    Jul 30 2020
    2014 f150 5.0 coyote full bolt on e85 175 shot nitrous
    Minnesota
    3.0tfsi stock internals hp limits?
    Does anyone happen to know how much power the 3.0 tfsi engines can make before the stock internals might start to fail?
    Sent from my SM-G960U using Audizine Forum mobile app
    Veteran Member Three Rings a1dan_87's Avatar
    Mar 07 2018
    Utah
    Quote Originally Posted by sage0607 View Post
    To my knowledge, it's more common to run into issues with the supercharger or melting cats before hitting the limit. Somewhere around 500+ by my estimate.
    Sent from my PH-1 using Audizine Forum mobile app
    Veteran Member Four Rings RoofRails's Avatar
    Apr 29 2018
    I don't believe anyone has found that limit yet because pistons are being burnt up by a lack of fueling before the rods are bending. My guess is 600 ft lbs of torque will be a true test for the internals. There are people now running 500whp and close to 500W TQ and as long as whatever supplemental fueling they have keeps working the engines seem to take it like a champ.
    Sent from my SM-N986U using Audizine Forum mobile app
    2015 Q5 3.0T S-Line | Glacier White |10.96 @ 126mph ! | 034 Stage 2+ E40 octane tune | Fluid Damper Crank Pulley 200mm / Griptech 60mm SC Pulley | Jokers Ported blower with APR UC TB | BG SQ5-HPT TCU tune| Snow WMI injection kit 400cc @ TB, 300cc @ BPV | Merc Racing C7 HX / CWA 100-3 pump 100% DC | APR open intake W/carbon UC pipe | Vogtland Springs | Nuespeed RS102 20/9.5/et25 rims |
    Jul 30 2020
    Minnesota
    Quote Originally Posted by a1dan_87 View Post
    Okay that's pretty darn good out of a little 3.0 thank you man
    Jul 30 2020
    Minnesota
    Quote Originally Posted by RoofRails View Post
    I don't believe anyone has found that limit yet because pistons are being burnt up my a lack of fueling before the rods are bending. My guess is 600 ft lbs of torque will be a true test for the internals. There are people now running 500whp and close to 500W TQ and as long as whatever supplemental fueling they have keeps working the engines seem to take it like a champ.
    Ohh okay that makes sense thanks for your input man
    Veteran Member Four Rings Morritse's Avatar
    May 08 2018
    Stage 2 b8 a5 (sold)
    Berkeley, CA
    It's torque not power that will break stuff. I think around 600lb ft is the limit for the 3.0t and the dl501
    FBO B8. ~ 10.95@126 ~ 2.96s 0-60 ~ full weight street tires.
    Veteran Member Four Rings Ashtonts's Avatar
    Jan 17 2015
    With auxiliary fueling an S4 made like 575 whp, and they’re hoping to crack 600. I can’t recall the torque numbers, but these motors have a lot more room to stretch their legs than we previously thought.
    2007 Porsche Cayman | 5MT
    Jul 30 2020
    Minnesota
    Quote Originally Posted by Ashtonts View Post
    Jesus 575 is still crazy and especially if they broke into the 600whp mark!
    Jan 17 2015
    That’s just on a ported SC too. I’m super excited to see what we can do on a bigger blower once fueling is sorted out. That’s probably when we’ll start to see the limits of the internals
    Jul 30 2020
    Minnesota
    Hell yea man, I know there is a guy with a custom turbo s5 on YouTube he says he makes around 600wheel he ran a 10.6 at 133 full weight too which is crazy especially because the s5 weighs a little more
    Veteran Member Four Rings UkuRiSh's Avatar
    Jan 09 2010
    New York
    That's me! My car actually did 10.4@136mph before that track day this in theory over 600whp. But this year I will be doing secondary fuel injection and new intake manifold setup ! Intake a alone spool up my turbo faster by 10% I'm super exited for this year.
    2013 AUDI S5 4.0T SWAP 9.7@145mph < Press @svarog_performance < last test updates
    Jul 30 2020
    Minnesota
    Quote Originally Posted by UkuRiSh View Post
    Thats crazy fast! Very interesting to see how far she will go
    Apr 29 2018
    Is that passenger side overflow tank for Meth ?
    Jan 09 2010
    New York
    No, This is coolant for intercooler that paired with my chiller
    Jul 30 2020
    Minnesota
    I was wondering the same lol
    Jul 30 2020
    Minnesota
    Does that mean your the fastest s5?!
    Sep 16 2020
    West Michigan
    I want to say that S4Matty has the record S4 at something like 10.2 seconds. (3.0t supercharged)
    2012 A6 Prestige - APR single pulley via Fluidampr 189, Injen intake+RS7 airbox, IE HPFP, EPL TCU, JHM HX, 034 motor mounts, Eurocode drivetrain inserts, gutted cats - 034 tunes purchased, not installed.
    Jul 30 2020
    Minnesota
    Quote Originally Posted by sepheroth86 View Post
    I know he has the fastest s4 but he has an s5 which is heavier and I believe he was even full weight for his pull
