Results 1 to 32 of 32
    Veteran Member Four Rings bb-tt's Avatar
    Apr 30 2018
    2017 TTS, 2011 Avant, 82 c3 vette, 2002 TT (sold), 2010 CC (sold), 2013 Jetta, 2018 Q7, 2019 Tiguan
    DFW, TX
    PR code help (Smac??)
    Smac,
    Or anyone for that matter do you know what pr code NY2 (extra battery capacity) is or what it means? My original battery from 2011 has finally needed jumped one to many times.
    no. No. Origin Family Description
    130 J0B L BAT Battery 520 A (92 Ah)
    135 NY2 L BGK Increased battery capacity
    2011 A4 Avant S-line Prestige
    Nothing to see here, keep moving!
    WPT+
    Jul 16 2018
    Atlanta
    I've never seen the NYx codes before when looking at B8 stuff. While I'm sure my car has a NYx PR code associated with it, it didn't make the short list on the PR code sticker. I'd need to get the full unabridged list for my VIN from a dealership.
    NY0 BGK Standard battery/alternator capacity
    NY1 BGK Increased battery/alternator capacity
    NY2 BGK Increased battery capacity
    NY3 BGK Increased alternator capacity
    NY4 BGK AGM battery and increased alternator capacity
    NY5 BGK AGM battery and standard alternator capacity
    There's a specific PR code for the battery, separate from this NYx charging system specification PR code. That's the Jxx PR code. Yours is J0B, the same as mine: 92Ah group 49 (H8) AGM. So that's what I would look for if you need to replace it. Just about everyone has some H8 AGM battery available. Old list I had made back when I was looking into a replacement - https://www.audizine.com/forum/showt...1#post13263820
    Veteran Member Three Rings DrGER's Avatar
    Aug 31 2014
    '17 Audi A4Q 6MT CYMC/RJN, '11 VW GOV TDI 6MT CJAA/LHD
    NW OH USA
    I got the full set of PR codes from erWin for our '14 A4q VIN when we got the car in '17, which included code "NY2" (but not on the PR sticker), along with battery code "J0Z" (Battery 520 A (110 Ah)). No AGM spec indicated. So, the question here might be "battery capacity increased from what?" IDK. Seems to me the J0x code is more relevant when battery replacement is required.
    2017 B9 A4Q P+ 2.0T 6MT Daytona Gray. Previous: 2014 B8.5 A4Q P+ 2.0T 6MT Monsoon Gray; 2009 B8 A4Q P+ 2.0T 6MT Brilliant Red; 2005 B6 A4Q 1.8T 6MT Cambridge Green; 1995 B4 A90Q V6 5MT Pearl White; 1990 B3 A80Q I5 5MT Crystal Silver; 1984 C3 5000S I5 5MT Montego Black; 1978 C2 5000 I5 4AT Helios Blue; 1977 C1 100LS I4 4AT Signal Green; 1974 B1 Fox I4 4AT Sahara Sand.
    Apr 30 2018
    DFW, TX
    Quote Originally Posted by Smac770 View Post
    yeah that NY2 is what is throwing me off it list J0b then has the NY2 what does "extra battery capacity" mean why a separate code the J0b is already specifying a larger capacity than the normal.
    Best part is went to audi parts online says battery no longer available, go to vw parts had it for 180$ said cool paid went to pick it up and they say yeah we dont have that and cant get it wtf???? why would you sell to me then after i show up say no cant get it.
    WPT+
    Apr 30 2018
    DFW, TX
    Quote Originally Posted by DrGER View Post
    yeah i was just wondering why the second code or what its significance was.
    could probably charge and keep on going but 10 years is pretty good and pushing it for a battery
    WPT+
    Jul 16 2018
    Atlanta
    There's six PR codes for the 8K batteries. H7 (94R) standard and AGM, H8 (49) standard and AGM, H9 (95R) standard and AGM. So NY2 means you're not H7, if we had to speculate an interpretation. Now, why not NY5 for the AGM versions? No idea. Just because PR codes exist does not mean that for a given platform/generation/product they utilize the full range of them. You have a PR code for the battery (J0B in my case) and the alternator (8GU in my case) which are more specific to your car parts than the NYx PR code. It's very possible the NYx code plays down into other part decisions elsewhere.
    Apr 30 2018
    DFW, TX
    yep we have exact same codes
    92 8GU L GEN Alternator 140 A
    WPT+
    Apr 30 2018
    DFW, TX
    FWIW i emailed AoA when i bought and they sent me the full list of pr codes for my car if you were wanting yours smac
    WPT+
    Senior Member Two Rings LmG7119's Avatar
    Jun 03 2014
    MNN
    Where do I find PR code on 2013 allroad? Where is the label located? I looked everywhere.
    It seems wlamart has the best deal so far. EverStart Platinum AGM Automotive Battery, Group Size H8 / LN5 / 49 12 Volt, 900 CCA 150 RC for $179 with 4 years warranty.
    "Note: PR-J1U, Battery is vented to outside of vehicle.; OE manufacturer used various size batteries in production. Verify Battery Size in Vehicle.; PR Codes denote factory installed options for the vehicle., Vehicle computer system must be reset, contact your service specialist, Battery Spec: H8 Group Size; 900 CCA; 1000 CA; 160 Minute Reserve Capacity; 4 Year Free Replacement"
    2013 Allroad Premium Plus UM stage 1
    2003 Allroad EPL Stage1+ straight downpipes catless(sold at 187K miles)
    Jul 16 2018
    Atlanta
    One gets put on at time of vehicle delivery (to buyer) inside the cover of the maintenance booklet. The other is put on during production at the factory; that's the one that's on the spare tire well, on the sheet metal. You'd have to pull the cargo floor and spare and subwoofer to likely be able to move that spare tire well liner enough to find it.
    Jun 03 2014
    MNN
    I found it in the booklet. My battery is JOB. My battery is an original from 2013 but car fires up just fine. Knock on wood. I think it is time to change it. It seems Walmart or Costco has the best pricing. I assume either will do.
    I saw many posts by you and was just wondering. 1 digit change with VCDS anywhere in the S/N would do. Right?
    Jun 03 2014
    MNN
    One more thing. I have a battery tested based on the image in this thread I could use DIN = 520A or 860A with EN, but not with CCA
    Jul 16 2018
    Atlanta
    J0B (that's zero, not o) is H8 AGM. Same as mine. My original is still on the shelf, replaced it three years ago (~13 years old) when I was hunting a charging system issue. But the battery itself is fine enough. I throw it on a charger every few months to maintain SoC.
    Just get any H8 AGM, the minor variation of the CCA and Ah values is not significant. Walmart/Sams or Costco is likely going to be your best pricing. I went with a NAPA since it was close enough in price and available down the road (when I want to test something, I want to get it done, not "wait for delivery"). After installing the new battery, reset the date/time in the menu system, then update the adaptation value, changing the serial number.
    Since it's still H8 AGM, you don't need to touch the p/n . Not sure which one they put in your much later build, maybe 000915105CE, mine was 4F0915105E. For the serial number, you could get cavalier and set it to YYMMDDxxxx where YYMMDD is from the date code on the battery and xxxx is whatever you want. For example, 180322NAPA. But I don't need that much accuracy to know my own car. I just changed a digit and carried on. The vendor code and serial number are for record purposes, not operational purposes.
    Jun 03 2014
    MNN
    "reset the date/time in the menu system" I have not seen this step. Why would you need to do this?
    Jun 03 2014
    MNN
    Is 860A a CCA on the label or EN/SAE/GS( this is what on my label next to my 860 A)?
    Jul 16 2018
    Atlanta
    You want the history data log entries to be intelligible. They won't be if all the records have timestamps of 2008 or such.
    860A would be a cranking amp rating, but to which standard? It would have to be posted there next to the value. https://www.yuasa.co.uk/info/technic...pecifications/ DIN rating will be a much smaller number than the others.
    Jun 03 2014
    MNN
    "reset the date/time in the menu system" Is this required even if the date time was no affected by the battery change?
    It is nowhere on the label CCA is mentioned.
    Jul 16 2018
    Atlanta
    If the date/time is correct, then the date/time does not need to be corrected. If the date/time is not correct, then correct the date/time before updating the battery adaptation value.
    You already said the 860A is labeled EN/SAE/GS, so which CCA standard that value represents is already labeled. There's no need for CCA to actually be in the text.
    Jun 23 2015
    Michigan
    This thread title
    Jul 16 2018
    Atlanta
    Yeah, but I probably look more like LEGO batman than the Dark Knight.
    Senior Member Three Rings MongoMcG's Avatar
    Apr 15 2022
    B8 A4, C2 Corvette, Austin-Healey 3000 BJ8, SN95 Mustang, 36 Ford hot rod truck, A4 B9 S-line, A3 8V
    Michigan
    Quote Originally Posted by A4Qwattro View Post
    This thread title
    There are a bunch of heroes on this forum that help cats like me every day, but Smac has a very particular set of skills...
    “The Force is strong with this one.”
    My K04X build thread
    Apr 30 2018
    DFW, TX
    This thread title
    now that's funny
    WPT+
    Apr 30 2018
    DFW, TX
    Quote Originally Posted by LmG7119 View Post
    so i got 10 years out of the Varta(it was still good but i was doing flashes on side of road and it was a little weak so didnt want to chance it) Smac got 13. I bought a battery for daughters jetta at AutoZone on a Sunday as she was going back to college it died with in 3 months, no worries took it back and got it replaced. the second one died with in a couple months went back to autozone and they f'd me and said oh you already used the warranty so you cant get another replacement said battery is supposed to have 36 month warranty and it hasnt even been 6 month since i purchased first one and they said too bad. went and got battery at vw it was like 100$ cheaper than autozone and has not had an issue in like 5 years. when i replaced the battery for the avant audi dealer was actually cheaper than everywhere else ( i know odd because some shit they are ridiculous but they were reasonable for the battery and based on the life i got out of the original i would have paid more)
    WPT+
    Jun 03 2014
    MNN
    Hey. Do you have by any chance a diagram of pins to measure resistance for upper and lower heating elements?
    I found a seat from 2013 A4 with matching codes but the junkyard does not know if it is working or not. They said I can come out and measure it myself.
    Jul 16 2018
    Atlanta
    The green plug on the bottom of the seat, measure across the two larger wires on 3 and 4. The two smaller wires on 1 and 2 are for the thermistor. I measure 1.8-2.2 Ω for the grid and 7.2-7.3 kΩ for the thermistor with the plug disconnected. The seat bottom grid and the seat back grid are in parallel. If you get a reading but higher, it's possible one of the two grids are out. If you get no reading, such as on my broken driver's side, then either both grids are broke, or the break is between the plug and the parallel junction point.
    Jun 03 2014
    MNN
    The green plug on the bottom of the seat, measure across the two larger wires on 3 and 4. The two smaller wires on 1 and 2 are for the thermistor. I measured 1.8-2.2 Ω for the grid and 7.2-7.3 kΩ for the thermistor with the plug disconnected. The seat bottom grid and the seat back grid are in parallel. If you get a reading but higher, it's possible one of the two grids are out. If you get no reading, such as on my broken driver's side, then either both grids are broke, or the break is between the plug and the parallel junction point.
    SO I know my seat back does work(to be honest it gets very very hot on setting 1) but the bottom is lukewarm or maybe I think it is lukewarm because the back gets too hot. LOL
    I assume I can disconnect the green plug without battery disconnect as long as I don't pull the yellow airbag plug. Right?
    I can do this and compare it to my passenger seat. I believe that one is working. I'm a very visual person. You couldn't grab pictures, could you?
    Thanks
    Jul 16 2018
    Atlanta
    Don't touch the yellow plug.
    Just disconnect the green plug, it's no big deal. It'll be curious what you measure for Ω if you have one of the two grids functional.
    I'd have to go take the car back apart. Just move the seat up and back, remove the cover over the connector station (lift the front of it), disconnect the green plug, put the probes on the two wider pin slots.
    https://www.audizine.com/forum/showt...1#post13954781
    Looks like access to the plug to the seat back grid is possible if you're Gumby. Forgotten about the current values in the measuring blocks.
    If you can get the probes angled in to backprobe the connector still plugged in, that's fine too. Was just a lot easier to pull up the green plug and slot the probes in on the mating side.
    Jun 03 2014
    MNN
    I do have VCDS. That would not help, wouldn't it? I will try to move the seat and measure the ohms.
    Jun 03 2014
    MNN
    This is what mine looks like
    Jul 16 2018
    Atlanta
    Ok, but how is that going to help you with a junk yard inspection? You can't power up the car at a yard. The resistance measurement is something you can do here and there to compare. Your VCDS readings do imply something is wrong with the driver's side, be it either the bottom or back grid. From your knowing it's the seat grid that's out, it's clear the seat grid has a lower resistance, consumes more of the current, than the back grid. You'll probably read 1.8 Ω on the passenger side and around 5 Ω (just the seat back) on the driver's side. That would give us around 2.8 Ω for the seat bottom alone, to read 1.8 Ω overall (bottom and back in parallel).
    Jun 03 2014
    MNN
    That was just me quickly doing it. I'm still planning to measure Ohms and compare the driver and passenger sides. I also took a picture of what I think is a memory module to make sure it would look similar at junkyard's seat.
    I know the back of the driver seat is working fine as it is evenly heating up. What was interesting was that the temperature of the driver's side was not going up at all. Which is strange. Don't you think?
    Jul 16 2018
    Atlanta
    That's the idea that the seat bottom grid is broken. In my case, it's before the parallel connection to the seat back, so nothing works. In your case, it's after the parallel connection, so the path through the seat back is still good and still works.
