Results 1 to 17 of 17
    Veteran Member Four Rings A1 A2 German's Avatar
    Feb 28 2005
    Audi A4 B5, Audi Fox, Audi AMLS TT, GS450, CB175, CL175
    Tempe
    FS: 350HP 1.8T 1979 Audi 80 Fox Resto Mod $15k
    1979 Audi 80 Fox GT2871R Eliminator 350hp 1.8t
    Turn key start, walk out and drive anywhere, in short this is a highly modified Mk1 VW meets Audi A4 B5.
    1979 Audi 80 Fox GT2871R Eliminator 350hp 1.8t at ~1850lbs.
    Under dash master cylinder conversion and custom shortened ceramic coated short intake if you ever want to swap back to the oem brake system (oem master and brake booster included)
    Respray of undercarriage being rubberized, polyurethane coated fender wells, complete restoration of entire trunk (every nut, washer, hose, gas tank, trunk springs ceramic coated), all suspension components, steering rack system.
    Brakes
    Brand new wheel & tires
    New chrome tuner nuts and stud conversion
    Front large x-drilled Wilwood kit
    Rear large x-drilled Mk4 drum to disk conversion
    Full custom e-brake system
    New underdash 8:1 ratio mastercylinder system and 100% every line front to back custom made for the car.
    Brand new NOS rear proportioning valve and reconditioned spring/hardware/mounts.
    Interior:
    Professional made door cards
    Red seats and rear bench
    Mint roof with custom made visors, oh sh*t handles reconditioned
    Professionally redone carpet
    B5 conversion dead pedals with ceramic coated pedals
    Brand new audio system / Modern retro looking deck with JL Audio door speakers
    Brand new Made In Germany chrome Mk1 handles with color matched inserts and matching key locks
    Custom new A and B pullers
    Floor pan, rear shelf, door cavities, door pockets were cleaned, scuffed and shot in professional grade polyurethane with ~$300 in dead mat (rear shelf, door metal and pan).
    Chrome door latches
    Chrome door strikers
    Led interior automatic led lighting system
    Trunk interior automatic led lighting system
    - Flocked dash
    - Redyed plastics
    Engine
    - Custom made aluminum front mounted radiator with custom Spal fans as originally these cars have internally mounted radiators
    - Custom EVOMs 1.8t intake in tig weled plexiglass box
    - Tubular ceramic coated manifold with Garrett GT2871r - Elim
    - Full ~2.5" downpipe back all enimal coated
    - FMIC
    - Ceramic coated pipes
    - 440cc injectors
    - Unitronic 20 PSI software.
    - Mk3 serpentine belt conversion
    - Custom tig welded under the manifold coolant pipes and coolant tank.
    - Entire gas tank, 100% nylon stainless woven gas lines, ~800hp pump and billet filter, fittings all the way the rail all redone...basically redid everything.
    - FMIC auto boost activated intercooler sprayer bar.
    - Hidden stealth wiring harnesses
    - Hidden plugs and sensors
    - 10AN Vibrant scavenger kit
    - External oil cooler with puller fans
    Lighting:
    HIDs
    LED running lights
    LED brake lights
    LED license plate
    LED blinkers
    The paint is....looks o.k. from ~10', but really needs a respray and minor body work to match all the other work, which was next to do after putting in Vintage Air AC System (not included) (NEW A/C KIT UNIVERSAL UNDER DASH EVAPORATOR 406B 12V 14X20 cond. & ELEC. HARNESS | eBay)
    Cons:
    - Needs paint
    - Would replace all three cheapo center console dash gauges
    - Would swap the current MSD tach convertor module to a MSD 8918 tach convertor so the tach isn't so jumpy ($68).
    - Replace the external wastegate (~$75), currently boosting at ~8psi, this system goes to ~21psi. I've had to replace it 3 times before on other longitude 1.8t's due to it's poor placement saturated in heat.
    Pros:
    Rare:
    - Get the hell outta here with throwing around rare, seriously just stop people, here's a true, seriously case of rare.
    - 2nd gear starts are all that's need, 1st will chirp/peal out the tires with out trying. A nominal effort the car will always be first off the line and first across the intersection and off and away.
    - A slip on / slip over cat is provided if you need to pass emissions, and has passed tail pipe emissions with flying colors.
    - As if not rare enough, it's the rarest being a '79 as were only made for ~6 weeks.
    There's way more. Car is always garaged here in Phoenix, Arizona. $15k firm no trades. Blake 602-487-38threeeight (if you want to talk text first as too many robo callers so won't answer, text is fine too).
    Veteran Member Three Rings Dnovakovic04's Avatar
    Feb 02 2016
    Thousand Oaks, CA
    Show some pictures!!!!! Not in the market but want to see what this thing looks like!
    GLWS!
    2016 Glacier White SQ5 Prestige
    - AWE Touring Exhaust - IE Stage 2 Single Pulley - Roc Euro Intake - 034 Trans Mount - Alu Kreuz -
    Feb 28 2005
    Tempe
    For those who want a tamer look:
    - Flags remove in 2 mins without being obtrusive to the paint and body (stealth inside hood jam mount)
    - Restored/color matched oem rims with tires
    - Rebuilt enaimal coated oem front calipers
    - Brand new performance pads
    - Brand new cross drilled rotors
    In order to run oem wheels you must swap to oem calipers as the Wilwoods are too large.
    Feb 02 2016
    Thousand Oaks, CA
    Quote Originally Posted by Dnovakovic04 View Post
    GLWS!
    Phone wasn’t loading the pics. Now I see them ffs.
    Mar 10 2016
    Wish I could pick this up, this looks great
    '01 Audi A4 1.8TQM - stage 2 daily
    '95 BMW M3 Coupe S52 swap - RIP
    '01 Audi S4 K04 Stage 3 - stolen
    Veteran Member Three Rings IbisB7stage2's Avatar
    Mar 20 2013
    Bay Area
    yoooooo this is beautiful, incredible work. GLWS
    ~John
    B7 A4 quattro 6spd, k04 w/ meth, PSS9 coils, S4 recaros, basically everything else
    C5 S6 Avant 6spd
    Active Member Four Rings landfill's Avatar
    Nov 14 2013
    Pompano Beach, Florida
    Fucking love this car. Just keep her and enjoy it.
    Senior Member Three Rings Badger Audi's Avatar
    Feb 05 2014
    B8.5 S4
    San Diego, CA
    omg this is amazing
    Current:
    2013 Audi S4
    Previous:
    2005 Audi S4 - sold
    2012 Audi Q5 Premium Plus - sold
    2004 Audi A4 Quattro 6MT - sold
    1997 Audi A4 Quattro 12v - sold
    Feb 28 2005
    Tempe
    Feb 28 2005
    Tempe
    1) Fresh engine coolant flush/degreeser
    2) Fresh ~G12 coolant
    3) Fresh Rotella T6 synthetic oil change
    4) Fresh Redline MT-90 transmission fluid
    5) Fresh Pentison Super Dot 4 brake fluid
    6) Fresh pull of the fuel tank, exterior stripped, 6AN bungs welded on and sprayed with polyurethane, interior cleaned and lined with Red-Kote gas tank sealer (along with a ~650hp Bosch pump, billet filter and complete 6AN nylon stainless steel woven line system up to a custom fuel rail, and back).
    * The vehicle does not possess or have any other fluids beyond mentioned, aka, there's nothing left to replace/maintain.
    Jun 15 2021
    PA
    Wow! Incredible machine! GLWTS sir!
    Nov 14 2013
    If you still have it in a few months I definitely want to
    chat with you about this car.
    Feb 28 2005
    Tempe
    Shipping & transportation:
    Whomever buys this will most likely need it shipped. It'll drive out of a garage onto a trailer, and will have no issue loading onto a ramped rig (flat loader not required).
    I've already received ~25 quotes to transport a vehicle, the #1 cost factor is mileage, the best price turned out being an outfit that Paul@VwVortex uses so I'd pass that carrier to you. To travel 2,500 miles from door to door was $1050, this cost can change for the better if less mileage, a longer lead time, or having it dropped at a local hub in your city (opposed to directly to your doorstep, which is more).
    If you bought it, and it took weeks for the carrier to arrive that's no issue at all, it'll remain parked in it's dedicated garage space.
    Feb 28 2005
    Tempe
    Car was, can, is set up to accept Vintage Air ac. The bracket to hold an ac compressor is already installed, there's a clear, accessible passage area into the cab, and the car's dash was fitted with a very rare ac extension panel (above passenger foot well) to except/hide the ac main body unit. From there you can non-intrusivly run the cold air tubes to the factory ac vents very easily (no cutting/hacking...just slip the Vintage AC air tubes onto the back side of the oem vents). Unlike other dashes that are a nightmare with the interior guts looking like something outta the Matrix, it's nothing but a huge void from a-piller to a-piller under their with all the room in the world to work. It won't even be required nor needed to pull out the dash...but even then it's very easy if you want, 4 screws & 10 mins slides right out.
    Feb 28 2005
    Tempe
    This is the closest I can find of any example of an historic oem+ Audi and what it'd look like with the provided oem rims less all my flare. In addition, with the already installed coilovers, can be slammed. Do note the straps, flags, intercooler fmic spray bar system and mirrors can all be unbolted and tossed. You would however have to add side review mirrors to be street legal, which are easy to add any where you like (rivnuts) and I can also provide the lower profile mirrors (lower profile mirrors = smaller/shorter, as seen in picture #1).
    Feb 28 2005
    Tempe
    SALE PENDING
    Junior Member Two Rings SportbackMatt's Avatar
    Feb 22 2019
    NH
    I am inspired by this buiks
    Quote Originally Posted by A1 A2 German View Post
    SALE PENDING
    Congrats!
    I am early stage on a B1 wagon build and totally inspired by your’s 😍
    I’ve seen lots of people use the Quantum or VW Fox but felt they aren’t best to handle 300+ HP.
    What transmission did you use? Any tips? 😁
