Results 1 to 14 of 14
    Junior Member Two Rings Rydah's Avatar
    Dec 05 2018
    Ventura County, CA
    Updated MMI Firmware and Maps - Now Nav is blank
    Hey guys, hope you're all well.
    For the most part, I am a long time lurker here and over all, pretty inexperienced when it comes to car stuff. I recently paid off my 2013 Audi A6 2.0T PP and getting things fixed up and updated, etc...
    Quick breakdown of what happened: I updated my MMI from HN+R_US_AU_P0609 to HN+R_US_AU_K0942_3 successfully. I then looked around online and found newer maps and updated from 5.7.3 to 6.20.1. MMI is fine but shortly after using nav, nav closed and nav version is blank...
    I found the MMI firmware posted online (HN+R_US_AU_K0942_3) and was able to download it and put it on an SD card. Update went well and definitely seeing a bit of better speeds with the bluetooth module loading up a tad bit faster.
    While at it, I figured I'd update my maps if I could find it online as well. I ended up finding 6.20.1 and was able to download that and throw it on an sd card. Update seemed to go well as well (this one took forever! lol) Once done, I opened the version information screen and confirmed that the version was updated. I open nav and it's up and running. At this point, I shut off my car for a few hours. The 6.20.1 maps I found for my car came with an activator which I threw on a different sd card but the nav never asked for it nor did it do anything when I put the activation sd card in the car. IDK if my issue is because it isn't activated? (or is it activated?)
    Upon returning to my car, just to see what's different with maps, I open Nav and it's working when suddenly it closes and now in the version information screen, it is blank.
    I have attached some photos.
    1. My stock firmware and database version from when I purchased the car
    2. After updating firmware and maps
    3. A few hours after updating firmware and maps
    I am unsure what happened and what I need to do. Do I need to reflash maps? I see there is a maps update for 8R0051884HG NAR 6.22.1 and another user is looking for people to group buy so i want to get in on that but for now, want to get nav working again.
    Any info or help would be greatly appreciated.
    Veteran Member Four Rings Alabama's Avatar
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    I'm no expert but I have updated my firmware and map database. One procedure you don't mention is rebooting the MMI after finishing loading the new map database. Turning the car off and on again does not do a software reboot. Different models/years use different key combinations; you can search threads for your specific car.
    2014 CPO S6, SunTek PPF (applied by CGS Vinyl), BlackVue dashcam (installed by Radio Active), Hawk Brake Pads/Zimmermann Rotors/Goodridge SS Brake Lines, H&R sway bars, Alu Kreuz, 034 Drivetrain Mount Inserts, SRM Driveshaft Carrier (mechanical/maintenance by Franklin Automotive)
    Dec 05 2018
    Ventura County, CA
    Oh shoot, you're right. I totally missed that part
    Dec 05 2018
    Ventura County, CA
    Just to update this thread, I've resolved the issue. I got the newer maps 6.22.1 and followed the guide to update (which includes the reset combo mentioned above.) All good now!
    Now I need to find out what the best option for adding android auto is for my car.
    Senior Member Two Rings E-SWIFT's Avatar
    May 07 2009
    TDI-Passat, M109
    philadelphia
    Quote Originally Posted by Rydah View Post
    Check your in box
    2014 A7 Garnet Red Pearl.
    Stop-tech slotted/drilled rotors F/R w/EBC ceramic Pads.
    I.E. Stage 2, Dual Pulley, JHM 187 mm Crank Pulley, Euro-code inserts
    RKX intake w/K&N filter. Eurocode Sway Bar Kit -F/R.,
    Aug 24 2014
    Newport Beach, CA
    I used Carplay on here, there's a thread about it. It was money well spent and works flawlessly (Android Auto) on my C7.5.
    2024 M3 Comp xDrive
    Dec 05 2018
    Ventura County, CA
    From what I've read, I will need to purchase some additional hardware and have it installed under the MMI dash (probably wrong term for it.)
    I have a 2013 A6 2.0T P+
    Aug 08 2019
    orange, nj
    Hello do you have the download link for the newer maps 6.22.1?
    Junior Member One Ring Luvadubdub's Avatar
    Oct 17 2020
    Edmonton, Alberta
    Interested also if its as simple as installing a downloaded file.
    2016 Glacier White Pearl S6
    Black Optics Package | Carbon Atlas Decorative Inlays | Driver Assistance Package | Night Vision Assistant | Cold Weather Package | Apple CarPlay
    034 Transmission Insert | Lowered 16mm via OBD11
    Jul 12 2021
    Interested for C7.5 S6 as well
    Oct 18 2017
    NW Philly
    Same here. I would like firmware and maps, both...
    Mar 07 2018
    Pacific NW
    Ditto
    Sep 09 2010
    Destin, FL
    All the info you guys need for maps here.
    https://www.audizine.com/forum/showt...to-update-maps
    Jul 12 2021
    Quote Originally Posted by The Infiltrator View Post
    Thank you
    I’ve got the same 18 S6 with similar options
