Page 5 of 6 FirstFirst ... 3456 LastLast
Results 161 to 200 of 221
  1. #161
    Nov 07 2021
    Calgary/Alberta/Canada
    Quote Originally Posted by HyperM3 View Post
    I chose using the plugs in case that fuse was needed for anything not listed.
    Sent from my Pixel 6 Pro using Tapatalk
    Difficult to install? Can't find any install notes for a 2018 RS5 coupe.
  2. #162
    Veteran Member Four Rings HyperM3's Avatar
    Mar 20 2004
    Lawrenceville, NJ
    Quote Originally Posted by gabemcclintock View Post
    I have an S5 but I did it on a previous S6 also. All the plugs are basically the same. Toughest part is getting your fingers up and over the exhaust to get to the clips.
    21 S5 Coupe - RacingLine strut brace/034RearSwayBar/CTSTransMount/034 tune/VPS Res Delete/CTSIntake
    10 S4 (gone),13 S6 (gone),14 S6 (gone),14 S6 (gone),16 S6 (gone),17 A4 (gone),19 S4 (gone)
    20 BMW R1250RS
    ACNA Lifetime Member - 26690
    Respond to a post with an answer, they will keep asking questions. Teach them how to RTFM, they will learn to help others.
  3. #163
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Here it is on my SQ5. A little easier to get to with the air suspension. Plus You would need one on each side for S5/RS5.
    https://youtu.be/eB1Qb86FT-A
    -cW
    2023 X3 M40i Alpine White
  4. #164
    Senior Member Three Rings dal59's Avatar
    Mar 31 2021
    2021 RS5 - 2022 BMW X3 - 2002 Harley Wide Glide
    atlanta
    Fortunately, I have no problem, dislike or concern with my valves opening and closing. However, I am wondering if anyone knows for absolute certain why Audi set it up this way? It certainly would have been very easy for them to program the valves to stay open in Dynamic mode. I keep wondering if there is a legitimate mechanical reason to have them open and close. Meaning, as mentioned in other posts, to maintain proper back pressure and power when needed or some other reason we are unaware of.
  5. #165
    Veteran Member Four Rings scott1961's Avatar
    Dec 18 2007
    Boston
    It's to make car more quite, B9 does not open and close like 9.5 does. Drove me bonkers
    2021 Turbo Blue RS5 Coupe
    2022 Blue Lamborghini Huracan Evo AWD Coupe
    Gone
    2020 Blue Lamborghini Huracan Evo Spyder
    2019 Blue Ferrari 488
    2015 Blue Lamborghini Huracan LP610 VF-800 Supercharged
    2012 Red R8 V10 6sp manual, VF-750 Supercharged
    2009 Silver R8 V8 6sp manual VF Supercharged
    2008 Black RS4 Cab
    2007 Black S4 Cab
  6. #166
    Established Member Two Rings thadoggfatha's Avatar
    Jun 11 2017
    The topic in terms of the valves having an impact on back pressure seems odd to me. I only say this because the most restrictive point on the exhaust would by the primary cats. When removing the primary cat or going to a sport cat there would definitely be lower back pressure. This would have larger effect than the valve would have all the way at the back in the muffler. By that logic I don’t really see the valves being open have any effect on the power the car can deliver from a purely theoretical point. The only way to determine an answer to this is to put the car on a dyno.
    I also have my reservations about making less power due to the code of the valves being disconnected through the fuse. The reason I say this is if Audi wanted to reduce power by way of a code due to loss in back pressure I would assume the sensor by the primary cat would restrict the power the car is able to make when the back pressure is reduced/ eliminated.
    Now from what’s reported it seems people are not able to feel a decrease in power and correct me if I am wrong but there have already been test completed stating the valves have no impact on power loss. It would make sense if that was the case. Let’s also not forget that the AWE exhaust suit being offered removed the valves from the exhaust entirely.
    Feel free to critique this because maybe we can get to the bottom of this.
    '18 Mythos Black RS5 Coupe
    IG: evilrs5
    https://www.instagram.com/evilrs5/
  7. #167
    Dec 18 2007
    Boston
    Agree with above. All cars I have owned seem to have it that when in sport or race mode valves are always open. Also on my 488 that was TT first mod I did was to keep valves open at all times, most do that and have seen dyno's that show no change after. I really think it's all part of quieting cars down just like how you can't rev past 4K now. On my current Evo I can but wont be able to on my new one coming
    Gone
    2008 Black RS4 Cab
    2007 Black S4 Cab
  8. #168
    Apr 26 2021
    San Francisco
    Quote Originally Posted by thadoggfatha View Post
    When I first removed the fuse on stock sport exhaust, I did notice a decrease in burbles but in exchange for louder pops. Since then, I have got the AWE non resonated. I believe AWE actually argues that without the flaps working, you lose power and that’s why they included a dummy valve to trick the system that the valves are still working. I decided to pull the fuse anyway since I can’t stand the clicking sound the simulator makes.
    Never noticed any loss/gain in power.
  9. #169
    Feb 15 2011
    Northern VA
    Quote Originally Posted by ToroTheShibe View Post
    APR says the same - apparently measured a 20hp loss but nullified it with their tune. I personally didn't feel any difference, either.
  10. #170
    Dec 07 2020
    orlando fl
    good news guys, going in for a dyno session with my APR tuned RS5 SB ill try a run both ways and report the results back later this week.
  11. #171
    Dec 18 2007
    Boston
    Quote Originally Posted by solarrs5 View Post
    That could show that APR has tuned out the loss of power but what we really need is a stock car to do with and without fuse out
    Gone
    2008 Black RS4 Cab
    2007 Black S4 Cab
  12. #172
    Mar 31 2021
    atlanta
    Agreed. The car would have to be stock and put on dyno. Although, we all love this crap, so I am sure the results would still be welcome anyway. Naturally, I have no idea if pulling the fuse loses power or not. However, a loss or gain of 10HP or even 20HP is very difficult to "feel". I would seriously question anyone that claims to have a "butt dyno" that sensitive.
  13. #173
    Dec 07 2020
    orlando fl
    Hey guys i just got back from the dyno, ad i can report there was no change between open and close !!!
    we ran 2 runs each maybe 5 hp variances.
    the car put down 525hp and 600ft torque on a mustang dyno.
    the car is a 2019 audi RS5 SB with a stage 1 Tune, AWE intake, Carbon Labs downpipes.
    we were also on pump gas.
    i will upload the pics here soon.
  14. #174
    Dec 18 2007
    Boston
    Great numbers for a Mustang. I take it those are at crank numbers?
    Gone
    2008 Black RS4 Cab
    2007 Black S4 Cab
  15. #175
    Dec 07 2020
    orlando fl
    Quote Originally Posted by scott1961 View Post
    correct,
    it was 508 torque and 456 hp at the wheels factor in around 18% for drivetrain loss.
  16. #176
    Jan 05 2022
    Australia
    Hi all, I’m new here and I would like to thank the OP for discovering the 7.5 amp fuse. I was about to remove the exhaust flap plugs and blank them off because they were driving me crazy with their opening and closing. The OP has saved me a tonne of work.
    The car sounds glorious now with the flaps always opened. Those who are worried that the 7.5 amp fuse will make the car lose power or keeping the flaps opened all the time will make the car lose power are obviously too paranoid and don’t understand how cars are made 😜
  17. #177
    Senior Member Three Rings Innovator's Avatar
    Aug 05 2004
    As the OP, I've had the fuse out pretty much since I owned the car. But I don't actually have the fuse out, rather, I put a switch in line with the fuse, so I can turn it on and off.
    Sometimes the stock exhaust will drone especially when you're in a high gear if the flaps are left open.. If I'm on a long trip I will turn the switch on and allow the flaps to function normally. The actuator that moves the flaps makes a tremendous amount of noise when you come to a stop. It probably does it all the time but you don't hear it with the motion and noise at the car makes. But, the only downside is some occasional drone. Otherwise the car sounds terrific with the flaps open and there's no way that you losing power. That's crap.
  18. #178
    Junior Member Two Rings
    Sep 22 2019
    Boston
    Would this work on a 2021 S4?
  19. #179
    Mar 20 2004
    Lawrenceville, NJ
    Quote Originally Posted by Gilquattro View Post
    Yes
    20 BMW R1250RS
  20. #180
    Veteran Member Three Rings JGreen76's Avatar
    Jun 05 2008
    Houston, TX
    Without reading all of what's in these five pages. I ordered last night some plug-ins from Burger Motorsports that keep the vales open w/o a CEL. Updates to follow... and my Bull-X are due to deliver today.
    '21 RS5 Sportback-Tango Red - Black Optics Carbon Package
    '20 R8 Spyder Performance - Kemora Grey - Black Optics Carbon Package
    PAST:
    '21 SQ5 - Quantum Grey
    HIS: 2019 Glacier White TTRS Black Optics///HERS: 2019 Tango Red TTRS///2017 Macan GTS///2014 Q5 3.0T Glacier White with Black Optics///2015 S3..........:::Glacier White, APR Stg3::::.......///2013 MK2 TT Roadster///2007 B7 A4 S-Line 3.2
    IG: TwoCarGarage_HOU
  21. #181
    Dec 18 2007
    Boston
    Quote Originally Posted by JGreen76 View Post
    Seems pulling fuse does not give you a CEL, but you do get a soft code. So you will need to scan to see if you get that. I have a valve controller and no soft code with that if you set correctly
    Gone
    2008 Black RS4 Cab
    2007 Black S4 Cab
  22. #182
    Jun 05 2008
    Houston, TX
    I'm not a fan of removing fuses. I'll check for the soft code after install. Thanks
    PAST:
  23. #183
    Junior Member One Ring
    Jan 20 2022
    Q5, RS5
    Huntsville
    Do you have the flaps open at all times and the Bull-X? How does it sound?
  24. #184
    Jun 29 2011
    FL
    Cant you disable the exhaust flaps using vcds using the long coding?
    19' RS3 Uni Stg 3 ECU/TCU, IMS750 Hybrid Flex Tune (10.97@126mph On stage 1+ E85)
    21' RS5 Sportback Audi Exclusive Orange
    99' B5 A4 Quattro - Sold
  25. #185
    Dec 18 2007
    Boston
    Quote Originally Posted by yoffer View Post
    No
    Gone
    2008 Black RS4 Cab
    2007 Black S4 Cab
  26. #186
    Jun 29 2011
    FL
    No
    Hmmmm, ok.
  27. #187
    Oct 27 2019
    DFW
    Does anyone know if the exhaust button on the R8 steering wheel kit can be made to control the flaps directly? Yaode says yes on his website/YouTube, but not a ton of details.
    Installed burger plug in modules (which didn’t come with caps to cover the now empty sockets on the valves themselves). So far so good. Exhaust sounds great, haven’t scanned for codes yet.
  28. #188
    Established Member Two Rings itr0045's Avatar
    Mar 13 2019
    Shithole Portland Oregon
    Pulled the fuse, and am liking the results. Good post.
    2018 RS5 Coupe
  29. #189
    Established Member Two Rings Rodomontade's Avatar
    Oct 27 2012
    Audi RS5 Exclusive 2015
    Cental PA
    2015 RS5 Sport Edition Daytona Grey Pearl Effect
    30% Ceramic Tint
    XPEL Paint Protection
    Full LED Conversion
    CarPlay Integration Module
    Google Earth Standalone Programming
    Added Timer for Exhaust Flaps
    Capristo Exhaust
    Adams Polishes Graphine Advanced Ceramic Treatment
  30. #190
    Aug 05 2004
    Private video
  31. #191
    Oct 27 2012
    Cental PA
    Quote Originally Posted by Innovator View Post
    Private video
    Sorry bout that..
    Fixed
    30% Ceramic Tint
    Full LED Conversion
    Capristo Exhaust
  32. #192
    Dec 18 2007
    Boston
    Quote Originally Posted by Rodomontade View Post
    Sorry bout that..
    Fixed
    What exactly are we looking at? Is that something in our cars or something you add?
    Gone
    2008 Black RS4 Cab
    2007 Black S4 Cab
  33. #193
    Oct 27 2012
    Cental PA
    I wanted the car to start with the exhaust flaps open but still wanted to be able to select the modes. As you know the car always starts with the valves closed muting the cold start-up.
    I put a count down timer in to keep the valves open for 3.5 minutes and then revert to the OEM configuration once this timer reaches 0. I can tap the dash button or put it in sport mode if I want the valves to operate as normal. Timer can be set to any amount of countdown time. I was using the other options but I didn't like the fact the valves would be disabled all the time. This gives me the best of both worlds for my application. I can explain how I did this if anyone is interested.
    30% Ceramic Tint
    Full LED Conversion
    Capristo Exhaust
  34. #194
    Dec 18 2007
    Boston
    In 2021 valves keep opening and closing no matter what mode you are in, that is why I put on a Milltek valve controller. Almost always drive with them open and they are then open at cold start. But with a push of a button on my phone I can change to stock mode
    Gone
    2008 Black RS4 Cab
    2007 Black S4 Cab
  35. #195
    Veteran Member Four Rings Bezlar's Avatar
    Apr 05 2006
    992 c4s
    Blue Springs
    Delete plugs work great. Even open valved it’s not that loud.
    2005 1/2 imola S4 gone
    2004 mini s gone
    2007 gti gone
    2008 mini s gone
    2011 ibis avant gone
    2012 iced silver tts gone
    2015 golf r gone
    2018 rs3 garage
  36. #196
    Mar 31 2021
    atlanta
    So, when installing the delete plugs, do you have to make sure the valves are open before installing like you do when pulling the fuse?
  37. #197
    Apr 19 2019
    Toronto, Canada
    How loud are cold starts once you install the delete plugs? I read a few people that installed them on the S4 and said it was too loud and your neighbors will hate you lol
    Current: 2024 BMW M3 Competition xDrive | 2022 Audi Q7
    Gone: 2022 Audi RS5 | 2020 BMW M340i | 2019 Audi RS5
  38. #198
    Dec 18 2007
    Boston
    I have a RS5 with Miltek and valves are always open and it's not that loud. Neighbors may hate me for Huracan though
    Gone
    2008 Black RS4 Cab
    2007 Black S4 Cab
  39. #199
    Mar 31 2021
    atlanta
    Although I am unlikely to use them, I just bought a set of the exhaust valve delete plugs just to have a set handy. Everything I read for the RS5 said to make sure to get the 4-pin configuration. However, when I received them today, the plug that goes into the wiring harness has only 2 pins flanked by 2 female receivers. Since I have not been under the car yet to check, I am assuming that the harness plug also has just 2 pins with 2 female receivers in the center, and when these 2 plugs come together there will be 4 pins?
  40. #200
    Junior Member One Ring DarkPhantom's Avatar
    May 22 2018
    2021 Q3 Sport Premium Plus
    Nashville
    Quote Originally Posted by luuat View Post
    I have the Bull-X and just removed the fuse to keep the flaps open. The sound became loud in all revs, much more sporty, no more random open/close. Some big rumble with low revs, so no more quiet at all.
    The cracks and pops still there at the downshifts but for some reason no more pops when upshifting.
