So i recently had the joy of breaking a front knuckle and figuring out that there's a half year where the lower control arm ball joint is 12mm or 14mm. the older, pre november 2009 production year knuckles arent available anywhere but a salvage yard. The newer production year knuckle can still be purchased new. The salvage yard wont know what you are talking about or what you need if you explain it to them and even wolfautoparts doesnt distinguish between the split year. I even found a knuckle with the same part number as my broken one but it was a 14mm ball joint so it had a different insert size! So it's either your car doesnt get back on the road or you come across just the right knuckle. Now I thought the inserts could be pressed out and swapped to the newer knuckle but in Audi's infinite wisdom the inserts have different outside diameters so they cant be swapped. If anyone has this issue im having an insert machined that will fit the 12mm control arm ball joint but also fit into the newer split year knuckle. Is anyone interested in purchasing an insert that has a november 2009 and earlier B8?
