Originally Posted by
Rilla
What?? You need to explain what you are talking about.
Sure.
Some places in the States will fill tires with nitrogen gas because it’s lighter than regular air. I guess the idea is to reduce the rotating mass. I’m sure we’re talking about mere grams, but whatever, that’s what some retailers do in an effort to provide “value-added” service. Costco is a big company that does it, as well as Big O Tires, Firestone, and Discount Tire I believe. All of these places offer to “top up” tires for free. But gas stations and typical shops just use regular air.
Whenever a tire is filled with nitrogen, it’s supposed to get a green cap on the stem. Not all places do this, but most do. Regular air gets black caps. If a person replaces their tire stem caps with a sweet aftermarket or vanity cap, then someone else might not have that indicator of which gas the tire is filled with. This can lead to accidental mixing, i.e., nitrogen filled but topped off with regular air, or regular air-filled but topped off with nitrogen.
So if a person has a mix of nitrogen and regular air in their tires, what you have is a certain amount of weight - due to the different weights of the different gases (or basically the non-nitrogen parts of regular air) - that wants to settle to bottom of the inside of the tire. Again, it’s mere grams, so it’s not much and really not noticeable at low speeds, say 30mph or in city driving. It just kind of sloshes around at those speeds.
But at higher speeds, like 50+mph or highway driving, centripetal force causes the greater mass of the regular air to stay pressed against the same spot on the inside of the tire, like swinging a bucket of water real fast around your head: the water stays in the bucket because of this force and you don’t get wet. This phenomenon then causes the heavier regular air to act as an unbalanced weight applied to the wheel and causes vibration at high speeds. I don’t know how much or how little of a gas mix would be necessary to cause the vibration or at which speeds depending on the mix ratio.
Anyway that’s what I was referring to.
