A quick update for anyone looking to do this work themselves, getting the back springs out can be a pain.
I am fortunate to have access to a lift and when I replaced the OEM rear springs on my B8 A4 Avant, it is very hard to get the lower control arm low enough to release the OEM spring so previously I lowered the rear sub-frame an inch plus that gave me enough room to pry the original springs out of their perches.
In the B8 A4 forum there is a guy who posted a method he used and others have since that I used this time. Even using his method of compressing the springs and using heavy duty zip ties to keep compressed I still had to have my brother pull down on the lower control arm with a 3' pry bar to get the springs out freely. I'm sure you can do this other ways but for me this worked well.
https://www.audizine.com/forum/showt...1#post12505872
https://www.mcmaster.com/1168N2/
Getting the springs in went well by having the height adjust all the way in and having my brother push down on control arm with pry bar.
There are rock guards on the lower control arms that need to be removed, there are plastic pins that hold these on and I could not figure out how to release so I broke them and ordered new.
https://www.audiusaparts.com/oem-par...bC12Ni1nYXM%3D
The other challenge as stated above is the male connector prevents you from removing the top rear shock mount to replace the original bump stop with the shorter one provided with the new spring kit. You can just modify the original bump stop as JGutz said but I have found 2 options if interested.
1.) With the proper tool you can remove the pins from the connector so you can get the nut from the top shock mount and the mount pass the connector, I do not have these tools so going to #2
2.) You can buy a new connector that will allow you to cut the male connector off, I found the required connector on ebay.
https://www.ebay.com/itm/293484376999
It was a hot day so I have not done the front springs and will hopefully get those done this week.
If a shop charges $600+ for install I understand why
