Results 1 to 7 of 7
    Established Member Two Rings nicepants's Avatar
    Jul 23 2008
    Land%20of%20Enchantment
    Lexus GX470 mild build, tons of extras (NM)
    I should start by saying I adore this vehicle but need a change to something a bit smaller, coupe, sedan, or otherwise. This is the highly desirable non-Nav and non-KDSS suspension model, without those pesky systems you're able to install your own aftermarket kit without issues (and I have). The mileage currently sits just under 185k (see photos). Had timing belt and transmission flush done at ~169k. 4-wheel alignment with documentation done just recently. Oil done at <5k intervals with Rotella Gas Truck and genuine Toyota filters.
    Additions, all in the last 10k:
    rear airbag delete, swapped in Toytec perches in rear
    Bilstein 5100 on all four corners. adjustable height in front, at lowest perch
    OME 2885 coils in front
    OME 2895 equivalent heavy duty coils in rear
    ICON Vehicle Dynamics differential drop for proper a-arm alignment/travel
    smoked housing headlights (Sport trim) with LED-swapped bulbs in everything but turn signals, LEDs in rear plate mount, etc.
    smoked corner lenses with Lamin-x (also to protect)
    ATOTO A6 Android Headunit with gesture control - includes Google navigation, rear/front camera inputs, data logging, fast charging port, USB integration, SD card input, BT connectivity for multiple devices, and countless other options. You can use Spotify, Pandora, for music or even stream Netflix or YouTube to it quite easily. Tethers to any capable phone for mobile data, or you can buy a plan for it.
    OBDII Bluetooth tracker/scanner to communicate with headunit for real-time input
    Lexus steering wheel integration (steering wheel controls still work)
    NVX QBUS8v2 Subwoofer Enclosure w/ amplifier
    A/C recharge last summer
    hexagonal rubber floor mats, including rear
    In the last 15k:
    Falken Wildpeak A/T3W 33" tires
    new 4Runner Limited wheels (black is Plasti-dip, can be easily removed if desired)
    Curt Class III round tube receiver trailer hitch w/ wiring and port, 7500 lbs towing capable
    NGK Iridiums
    running board delete
    timing belt/water pump, new coolant
    transmission flush
    new gear oil and lube pretty much everywhere
    Extras included:
    a couple years worth of air and oil filters (genuine Toyota)
    a complete front-end suspension rebuild kit (a-arms, ball joints, etc - it just doesn't need it yet)
    cargo tie-down straps
    boxes and add-ons for the sound system
    Lexus headunit
    stock shocks & springs
    The bad:
    leather seat wear (typical of this age GX, I don't notice anymore but it's definitely worth mentioning)
    missing roof rack (last owner misplaced it. I actually think it looks a ton better without - I hate that body-colored roof rack, and planned on going GOBI complete with rear ladder but hadn't gotten around to it)
    MINOR leak from driver's side CV joint where it meets the transfer case (I replaced this seal once but didn't use a genuine Lexus part since my local stores didn't carry it - I believe this would mitigate the problem after heavily researching it)
    light squeak from front control arm. Suspension rebuild kit includes this part!
    I'm sure I'm forgetting other add-ons but will continue to revisit this list as needed. Basically, this truck needs nothing but to be driven and used as intended. It's been through heavy snow, mud, and used as a daily. However, it has just been rotated with another vehicle so I’ve kept the mileage I’ve put on it low, especially considering the amount of money I’ve spent on maintenance and add-ons. It's insanely capable off-road and in towing scenarios, but also has surprisingly good highway manners. No oil leaks, runs perfectly, and doesn't hesitate to start even in 12 degree temps. Glacier white pearl paint is in great shape. Dash has zero cracks. This was originally an Arizona vehicle so zero rust on the frame or anywhere else.
    Full photo gallery here
    Asking $16k, title in hand. Can meet serious buyers at the airport in Albuquerque or Santa Fe with prior serious commitment/deposit. Can also discuss shipping if you take care of the particulars.
    Senior Member Two Rings AeyBeCei's Avatar
    Oct 03 2017
    Beautiful car! These cars have been going for a premium over at Cars & Bids. GLWS
    Jul 23 2008
    Quote Originally Posted by AeyBeCei View Post
    thank you sir! Yeah, these have really caught on in the last couple years.
    Veteran Member Three Rings dennej1985's Avatar
    Jul 23 2012
    Wyoming
    I’m hunting for a weekend camper/overlander. This 470 looks great. Sorry if I’m missing it but what model year is it?
    Now: 2014 S4 |6MT|Estoril|Lunar/Black|AFE|
    Then: 2012 A4 Quattro 2.0T 6MT
    2003 A4 Quattro Avant 5MT
    Jul 23 2008
    It's a 2004.
    Quote Originally Posted by dennej1985 View Post
    Junior Member One Ring Mishel's Avatar
    Aug 08 2021
    Miami
    Still available?
    Sent from my BE2029 using Audizine Forum mobile app
    Jul 23 2012
    Wyoming
    Quote Originally Posted by Mishel View Post
    Still available?
    Nope, I have it now.
