Results 1 to 29 of 29
    Aug 06 2019
    Ontario
    A4 B8 Piston replacment recommendations
    Hello! Hope everyone's having a good day :) my 09 a4 b8 is burning oil as expected... I've done many things to try and fix it but it still goes, but that's ok.. Just wondering if anyone has any recommendations for pistons to replace the old ones with.. currently the car has an IE stage 2 tune, adventually I do think ill get a k04 and a stage 3... wondering what pistons may combo best with this for some good performance, since I gonna be in there either way I could do some boring etc...
    Mar 21 2019
    Florida
    Quote Originally Posted by Larrybobcarl View Post
    I’m stage 3 k04 and i just decided to go with the oem updated pistons. The other options were more expensive and required mods to the oil squirters, balancing, and had horrible wait times. I literally walked into the dealer and bought pistons off the shelf and threw them in.
    Aug 06 2019
    Ontario
    Quote Originally Posted by Zuzuwu View Post
    Ohhh ok lol that is very worth knowing, thank you very much
    Feb 15 2016
    Cambridge,Ontario
    can an 09 be done with stock pistons without updating rods ???
    i was under the impression updated pistons had larger wrist pin and needed new rods?
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Clicky click®
    ATG Piston & Piston Ring Φ21mm Set Fit For VW Golf Tiguan Audi A3 A4 Skoda Seat
    Senior Member Three Rings ericA6's Avatar
    May 03 2012
    Dallas, Tx
    Unbranded from China. Has anyone used this kit?
    Current - '10 A4q S-Line
    '16 Honda CB500F - I like my bikes naked
    Past - '05 A6q 3.2L
    Feb 15 2016
    Cambridge,Ontario
    yeah old guy i have seen those, that's why I said" stock" pistons. It was recommended that OP go to dealer and just buy them. i'm just not sure on an 09 you can do that and just get pistons without rods. That was really my point.
    1976 Yamaha XS 360
    Jul 16 2018
    Atlanta
    '09 builds had the 21mm wrist pins. To not have to replace the rods when they did mine, they used 21mm A3/TT pistons (06H 107 065 AM) since 21mm A4/A5 pistons were likely gone by then. Had they not been able to source a 21mm piston, they would have had to change my rods to 23mm versions (06H 198 401 A).
    Change date from 21mm to 23mm for new builds seems to be May 30 '11.
    Veteran Member Three Rings DrGER's Avatar
    Aug 31 2014
    '17 Audi A4Q 6MT CYMC/RJN, '11 VW GOV TDI 6MT CJAA/LHD
    NW OH USA
    When AoA replaced the pistons in our '09 A4 CAEB back in Dec 2014 at our local dealer, they used piston PN 06H-107-065-AM (list $215 each at the time) according to the repair order. When we sold the car 37K miles later in Jul 2017, oil consumption was negligible between 5K mile changes.
    2017 B9 A4Q P+ 2.0T 6MT Daytona Gray. Previous: 2014 B8.5 A4Q P+ 2.0T 6MT Monsoon Gray; 2009 B8 A4Q P+ 2.0T 6MT Brilliant Red; 2005 B6 A4Q 1.8T 6MT Cambridge Green; 1995 B4 A90Q V6 5MT Pearl White; 1990 B3 A80Q I5 5MT Crystal Silver; 1984 C3 5000S I5 5MT Montego Black; 1978 C2 5000 I5 4AT Helios Blue; 1977 C1 100LS I4 4AT Signal Green; 1974 B1 Fox I4 4AT Sahara Sand.
    Jul 16 2018
    Atlanta
    Mine was in Feb 2014. And it seems these AM ones are still out there new: https://www.genuineaudiparts.com/oem...on-06h107065am
    Veteran Member Four Rings fastboatster's Avatar
    Apr 23 2019
    2010 Audi A4 3.0T, lol
    CA
    Quote Originally Posted by DrGER View Post
    When AoA replaced the pistons in our '09 A4 CAEB back in Dec 2014 at your local dealer, they used piston PN 06H-107-065-AM (list $215 each at the time) according to the repair order.
    these seem to be an "old-style" pistons, just bigger drain holes in the oil control rings and from what I gather, this piston/ring style will start to burn the oil again eventually. If I ever get a 2.0T (not likely, N54 is a king, lol), I'd like to try some Russian pistons (https://www.instagram.com/forged_pistons_sti/) since I saw some 500+ hp builds with those, figured that if that's true then at their cost (like some noname chinese parts), these are real winners.
    Jul 16 2018
    Atlanta
    I've got 140k miles on my AM replacements, and I don't have to top off any with 7.5k intervals.
    Veteran Member Four Rings MyDimeIsUp's Avatar
    Dec 04 2019
    West Chester, PA
    Why has there never been any case for the 2013 - 2016 models?
    2020 BMW M340i xDrive - Mineral Grey
    2012 Audi A6 3.0T Prestige - 034 Stage 1 ECU and TCU | CTS Turbo Intake | 034 Street Density Motor Mounts w/ JHM Trans Insert | ECS X-Pipe
    2013 Audi allroad - RIP
    2007 Toyota corolla
    Jul 10 2015
    Colorado
    Dealer replaced the pistons on my 2011 in 2017 at 75K with the AM version. Around 130K now with no oil consumption.
    Mar 21 2019
    Florida
    Quote Originally Posted by MyDimeIsUp View Post
    Because it is less common on the b8.5 and also there’s aren’t as many in the mileage range ti start burning oil yet. But there seem to be a lot more coming around lately.
    Veteran Member Three Rings Chillaxin's Avatar
    Mar 28 2018
    Jacksonville FL
    Depending on how long you plan on keeping the car should help decide between the AM pistons (one part oil control ring with slots) or the DM (3 piece "waffle style" OCR) that requires 23mm rods. The DMs have the highest probability of not have oil consumption issues.
    Apr 23 2019
    CA
    The main selling point of the pistons I posted is that besides being forged and very attractively priced (something like 300$ for a set?), I’d that they also allow to reuse the old b8 rods.
    Veteran Member Three Rings Depthcharge's Avatar
    Nov 15 2007
    '21 PS2, '20 SQ5, '14 A4
    DFW, TX
    Quote Originally Posted by Smac770 View Post
    Thinking about going ahead and doing the pistons with the timing chain for my 2014 CPMB. Going to be a giant PITA.
    Feb 15 2016
    Cambridge,Ontario
    Timing chain is relatively easy, pull front forward ... Easy weekend its done..
    Pistons are a complete engine out rebuild job .. not exactly" while you are in there"
    Sent from my SM-G973W using Audizine Forum mobile app
    1976 Yamaha XS 360
    Dec 04 2019
    West Chester, PA
    Timing chain is relatively easy, pill front forward ... Easy weekend its done..
    Facts. I'm heavily considering a piston replacement job but I'm starting college this August + I would need an engine hoist + stand, topping over $1,400. $1,400 that can go towards college, future flight training, unexpected things, etc. I'm guessing there is no concern about oil burning until you start getting to < 1,000 miles? I'm at 1,700miles a quart so maybe I can squeeze some more life out of my pistons.
    2007 Toyota corolla
    Feb 15 2016
    Cambridge,Ontario
    i was 180 miles per quart , pulled like a freight train and no codes... did have to keep washing my white garage door i parked in front of though.
    1976 Yamaha XS 360
    Nov 15 2007
    DFW, TX
    I know, I'm just weighing the argument of 'should I just do it now, or wait about 70k' argument. It only has 75k miles but burns oil as all of my Audi's have haha. I'm probably at about 3-4k before adding a quart of oil. Noticeably when I drive it hard.
    Mar 28 2018
    Jacksonville FL
    You can try this procedure to get some more time before you need to do a motor overhaul: https://www.audizine.com/forum/showt...1#post14377958
    I haven't done this, but it makes sense that it could be a temporary solution to the oil rings not doing their job.
    Junior Member Two Rings
    Jun 15 2017
    Central NJ
    I'm currently in the rebuild process and picked a quality piston kit through https://www.bar-tek-tuning.com/produ...2.0l-tfsi-tsi/
    Its a German company with great customer service at fast shipping considering coming from Germany.
    - - - Updated - - -
    Feb 15 2016
    Cambridge,Ontario
    A bit expensive no?
    1976 Yamaha XS 360
    Jun 15 2017
    Central NJ
    I could've looked for a cheaper set-up but I believe that if a part fails replace it with something better. Hopefully I achieved building an
    bullet proof bottom end and I won't have to worry about the internals going forward. I saved some money on less critical parts where I could.
    I guess only time will tell !
    Dec 04 2019
    West Chester, PA
    Quote Originally Posted by AForced4 View Post
    What parts did you save on just out of curiosity?
    2007 Toyota corolla
    Senior Member Four Rings
    Mar 05 2020
    NewYork
    Im using these with K04 and IE tune.
    https://docs.google.com/spreadsheets...#gid=790763898
    I drive a 2011 Audi A5
    Jun 15 2017
    Central NJ
    I used aftermarket upper and lower timing chain covers. I also compared part pricing using FCPeuro, Europaparts, ECSTuning, UroTuning and GenuineAudiParts
