Results 1 to 8 of 8
    Junior Member One Ring dbphotos's Avatar
    Jan 02 2017
    Audi Q5 S-Lline & Audi S4 S-Line
    DFW Texas
    TRANSMISSION ISSUE - Error Code P0750
    2013 S5 with 79,714 miles.
    Ever since they updated transmission software (pre-covid) I have been having rough shifting from 1st to 2nd and 2nd to 1st as well as coming to a stop. Maybe a coincidence. A few days ago I got the dreaded transmission malfunction and TPMS malfunction simultaneously. I pulled over turned off the car and it cleared itself.
    My initial research had me thinking I was looking at the expensive and common problem of having to replace the mechatronics unit. Audi knows this is a widespread problem and should issue a recall to fix it or at least cover the repairs. My research shows that the manufacturer of the part knows there is an issue and hasn't been able to fix it yet, however, there is a company in the UK that will repair it and guarantee the repair for $580 plus shipping.
    I just ran a scan of codes and it appears the codes I'm getting are the P0750 which says I have a "shift solenoid A" failure, and 8955 Valve 3 in partial transmission1 mechanical malfunction. Has anyone else had a similar issue? Did having "solenoid A" replaced fix the problem? I don't want to just start fixing things to find that doesn't solve the hard shift issue. Looks like the cost of the parts is about $100 and the labor cost should be between $250-500. Does anyone have any experience with this? What should I expect to have done to resolve the issue?
    Thanks for any input.
    David
    Veteran Member Four Rings hahnmgh63's Avatar
    Jan 10 2008
    Roy, WA
    When is the last time you had the transmission serviced? Being that it is a 2013 then it is a good chance that it's the Mechatronic. Who updated your TCU software? Dealer? Do you have a engine/DSG tune?
    2003 RS6 (6Spd)
    2013 RS5 (Headers, Aluminum DSG Flywheel,JHM Stg2, etc...)
    2013 S5 (034 Stg2 & TCU)
    1974 911 (3.6ltr)
    2006 CTTS
    944T
    Senior Member Three Rings SteveRS4's Avatar
    Jul 07 2019
    uk
    You can get a mechatronic repair kit now save you getting a whole replacement but don't get them from eBay unless they are genuine oem with the correct part code. You need a oem one this replaces both clutch 1 and 2 seloniod's for clutch pressure and new PCB wiring harnesses plus another seloniod but I can't remember what that one is off the top of my head.
    Yours being a 2013 will have a Generation 1 in it you want a Gen 3 and you can tell by the PCB wiring harnesses as the Gen 3 has muti colour wiring. So make sure you get this one as it's the latest version and should solve your problems.
    Part number is in the first picture sorry it's the only one I have it's not that clear I'm afraid.
    Sent from my SM-G920F using Tapatalk
    Jul 07 2019
    uk
    Just looked part number up it is 0B5 398 048 D
    Jan 02 2017
    DFW Texas
    Quote Originally Posted by hahnmgh63 View Post
    Transmission service by dealer at 65,000 miles. Dealer updated TCU at the same time. No engine tune.
    Sent from my Pixel 5 using Audizine Forum mobile app
    Jan 02 2017
    DFW Texas
    Quote Originally Posted by SteveRS4 View Post
    Thank you!
    Jan 02 2017
    DFW Texas
    Thank you!
    May 21 2021
    Ft Lauderdale
    Hey I'm facing the same issue as you. Same year car just a bit more miles. Did you ever find a solution?
