Hello, my 2015 A4 has started burning oil a few months ago. I bought this used almost 2 years ago and tuned it to IE stage 1 with new coil packs, spark plugs and ECS intake around a year ago. At the moment, it's sitting around 72k miles. I had my local shop take a look for leaks when getting a wheel bearing replaced, but they didn't see anything. On March 26th they flushed the oil system and refilled with fresh oil to see if that made a difference. They also installed a GFB diverter value plus. Today, May 9th, I had to add another quart of oil.
I've searched the forums as well as reddit only to find that there could be a variety of issues causing oil consumption. I used my OBD11 to test the timing chain wear and the result was around -4.5 degrees. From what I've seen, that isn't a good number but shouldn't be bad enough to cause something like oil burn. I also saw posts about the PCV valve causing this so I tried the finger over the hole for pressure test only to find no suction at all, so I don't believe that could be the culprit. Now, the major cause could be piston rings which isn't really something I can check myself at home so I am leaving that for the shop to find out, but I don't want to have them open the engine just to find out that this isn't the issue.
Is there anything else that can cause this? Did I miss something? I love this car, but don't want to take it on vacation or trips in fear that it'll break far from home. At this point, I've started looking for a B9 S4 but I'd prefer to keep my A4 longer.
Thanks for the help.
Total Mod List:
-IE Stage 1
-ECS Tuning Intake
-NGK BKR7EIX spark plugs
-OE coil packs
-GFB Diverter Valve+
