Results 1 to 12 of 12
    Junior Member One Ring
    May 01 2021
    Santa Monica,CA
    S4 Brake Kit Recommendations
    Just bought a used 8.5 S4. I need to replace the rear brakes and rotors but figured I'd just do both front and rear. Does anyone have a kit that's the best "bang for your buck" suggestions? Been reading a few posts but the links are for parts that aren't available anymore. Also looks like ceramic is the way to go but open to others' experience.
    May 01 2021
    Santa Monica,CA
    For reference this is what I have my eyes on:
    http://www.rockauto.com/en/moreinfo....vUhvMbV5SZVSoh
    Junior Member Two Rings
    Jul 19 2018
    Sold- stage 1 B5 S4 :(
    Philly
    Veteran Member Three Rings king_j's Avatar
    Sep 09 2009
    Minneapolis
    I’m planning on getting ebc red stuff pads with either Zimmerman or Meyle rotors. Total will be 450-470 for F/R.
    What is cost on the power stop package?
    Have you read reviews on power stop?
    2006 A4 2.0T Q. S-Line 6MT - Arctic White
    JHM stage 1, 034 hfc, Europaparts exhaust.
    Miro 111 18x8.5 et 35, 034 RSB.
    Veteran Member Three Rings tbaudi's Avatar
    Jun 21 2011
    Naperville, IL
    I would check out FCP if there isn't something specific you are looking for. Lifetime warranty means the next brake job is much less expensive.
    https://www.fcpeuro.com/Audi-parts/S...&b=5&d=4572&v=
    Make sure you select your car.
    Sent from my SM-F707U1 using Tapatalk
    '16 Q5 | Prestige, S-Line, Sport, Black Optics | silver/black | EPL stage 2 SP | BG TCU tune (HPT) | B16 PSS10 (C7 version) | BBS CH-R staggered | RS Grille | 034 RSB w/ TRW end links | Airbox mod | RSNAV Standalone Planned - Custom exhaust tips
    '05 S4 Cabriolet | RS4 wheels
    Gone but not forgotten - '11 A4 Avant | Prestige, S-Line, Sport | silver/black | BG TCU tune (HPT) | RS grille | RSNAV Standalone | Black finished wheels | 18/35 SunTek Carbon tint
    Established Member Two Rings Atrevido's Avatar
    Mar 19 2018
    Florida
    I'm happy to recommend the Zimmerman rotors and Akebono Euro Ceramic pad kit from ECS.
    https://www.ecstuning.com/b-assemble...8k0698301mkt1/
    2013 S4 / 6MT / Phantom Black / APR Stage II Single Pulley / Sports Diff / RS4 Grille / Sachs Performance XTend Clutch / ECS Lightweight Flywheel / ECS Transmission Mount Insert
    ECS X-Pipe / K&N / Modded Air Box / CR-15 / Osram CBI 5500K HID / Zimmermann / Akebono / Pirelli P Zero AS Plus 3 / Hard-wired Valentine V1 Gen 2
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    Second the FCP suggestion if you plan on keeping the car long term for 50k+. EBC or Akebono's are good choices for pads, Zimmermann, Stoptech, or Myele are all fine if you are DD'ing the car only.
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
    May 01 2021
    Santa Monica,CA
    Quote Originally Posted by sacandagaD View Post
    This is my second car, used primarily for pleasure and cruising the canyons
    Jul 02 2013
    Then you can't go wrong with any of them, just comes down to your budget and choice of supplier. Slotted and cross drilled are really for show only, I personally had poor experience with a set of slotted Zimmermann in the past.
    Nov 14 2020
    APR stage 1+ B6 A4 Quattro 1.8t | 16 Kawasaki ZX10R KRT FBO, NPT tuned.
    Atlanta
    What was your experience with the rotors? I just went with akebono pads and drilled zimmermann rotors from FCP, purchased today. Cheaper than ECS btw.
    Sep 16 2020
    West Michigan
    I haven't put them on the car yet, but Akebono Euro Ceramics and Zimmerman solid rotors from FCP for me.
    2012 A6 Prestige - APR single pulley via Fluidampr 189, Injen intake+RS7 airbox, IE HPFP, EPL TCU, JHM HX, 034 motor mounts, Eurocode drivetrain inserts, gutted cats - 034 tunes purchased, not installed.
    Jul 02 2013
    Quote Originally Posted by Genvkawi View Post
    I had slotted ( not cross drilled ) fronts only, and they developed a lot of pedal chatter under hard braking after only about 10-15k from the slots, so I changed them out to solid and no problems ever after that. I've also used Akebonos exclusively for the last several years with good results. Yeah, I used to use ECS, but once I discovered FCP, I never looked back. As a matter of fact, I just returned an oil change to them today.
