Hi Folks,
It’s my first post here; I’m glad I found y’all.
I picked up a 2018 Audi A4 Allroad this week. It’s on OEM Continental ProContact TX 245/45/18 tires on the OEM 18x7.5” rims.
I have a set of barely used 225/45/18 Michelin Pilot Sport All Season 4s I pulled off the car I traded in for the B9 A4 allroad. From what I read about matching tires to rim sizes, seems like a good rule of thumb is to match the tire tread width to be the same or maybe just a little smaller than the rim width. The 225/45/18 Michelins have a tread with of 7.2”, which would seem to sit nicely on the OEM 7.5” wide wheels. However, the OEM wheels have an 8” tread width, 1/2” inch wider than the rim width. Audi had a reason for spec’ing the car this way; I would think this might contribute to a more floaty ride feel.
I’m in California and will use the car for road trips and camping trips, with only light dirt roads to get to the good camping spots. I’ll likely see snow at Lake Tahoe area only 2-3 times a year on weekend trips.
What do you Audi owners advise? Would it be ok (or even smarter) to put on the 225/45/18 Michelins or should I buy a new set at the OEM size (245/45/18)? I know the diameter of the 225/45/18 will be smaller, which will affect the speedometer, wheel gap and ground clearance. I’m just curious if the 225 tire’s tread with of 7.2” would make for a more planted ride or if it would be too compromised for what the car was originally designed to be?
