Results 1 to 11 of 11
    Jun 14 2018
    BC
    ATTENTION: 2002 Audi A4 B6 3.0L engine survivors....
    Looking for someone to be kind enough to take a picture of the vacuum routing decal, which resides in the engine compartment on the drivers side rain deflector cover which is above the Engine ECU box.
    This is some kind of allusive cat or trying to find the "needle " in the hay stack !!!!
    DOES ANYONE..... HAVE a complete decal ?
    I've searched and searched and seems this must be the first thing that falls off of the Audi's..
    I understand they are VIN designated but come on...... V6 3.0L people.
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    Like this?. I have an '03 and 96% of my sticker is gone, but the one in that post looked accurate from what I remember.
    Sent from my Pixel 5
    Jun 14 2018
    BC
    Quote Originally Posted by imnuts View Post
    Not sure..... Can you read a Audi Part number off of your decal ??
    Feb 10 2011
    MI
    I have one. Ill try and look tomorrow.
    Sent from my LG-TP450 using Tapatalk
    2004 Audi A4 Quattro 3.0 6sp Ultrasport
    2002 Audi A4 Quattro sport "development" car
    2005 Passat TDI Wagon 6 m/t
    1996 Audi A4 Quattro 2.8 (daughter)
    And all the Ford trucks you could want
    Senior Member Four Rings Deerhurst's Avatar
    Jul 22 2019
    1986.5 SE-V6 4x4 Nissan D21
    Oregon
    That looks pretty accurate to me from what I remember replacing vacuum lines.
    2003 A4 Avant 3.0 6MT Quattro
    2003 A4 Avant 3.0 6MT Tuned, TTV SMF, RS4 Clutch, Joey Mod, Clear Corners, Mini H1 7.0, Xtrons, Skar Audio, Panda Subs
    1986.5 SE-V6 4x4 D21 Cammed, Long Tubes, VG33 swapped
    Jun 14 2018
    BC
    Anyone with an actual picture ??
    Jul 22 2019
    Oregon
    You are wanting a photo of the diagram linked to? From my past experiences I'd trust the service manual over a sticker under the hood.
    Aug 12 2009
    Dirty Jerz
    There are only a few variations of the 3.0 vacuum system AFAIK. The '02-'03 models have a line going to the fuel pressure regulator, the '04-'05 models have the regulator built into the fuel filter. The automatic transmission may have an additional tee in the system for an auxillary vacuum pump as well. I don't think there are any other differences, so the picture I linked to is going to be very close or the same as what you need.
    Jun 14 2018
    BC
    More like this...... Found this decal..
    Nov 03 2010
    2019 Audi A5 Sportback, 1986 MB 560SL
    Fallbrook, CA
    Thankfully the 3.0 has a fairly simple vacuum layout, the only area that I messed up was the SAI valve hoses. I misconnected those after having the intake manifold off.
