Results 1 to 12 of 12
    Junior Member One Ring
    Apr 23 2020
    Raleigh, NC
    VAG COM alternatives out there?
    I have used an OBD II scanner/reader but it was basic. Clearing codes and reading...but...doesn’t clear the, “Service Due!,” notice.
    I can’t find anything out there that says that it will clear that and I don’t want to buy one without knowing if it does or does not clear the service due.
    Is there one that anyone would recommend purchasing?
    Thanks
    Wayne
    Senior Member Two Rings Blkdoutv's Avatar
    May 25 2018
    2017 RS7 Performance 2018 SQ5 2016 A3 2.0T
    Texas
    Carista clears the service light
    Jul 31 2016
    PA
    It OBD11, but VCDS is still the best functionality you can get. Not worth it if all you want is the service light though.
    Sent from my SM-G988U using Audizine Forum mobile app
    Custom DP 194/57 E40 Water-Meth (Aquamist) | BG HPT ZF8 Tune | APR CPS with AWE Reservoir (Divorced Coolant Loop) | APR Open Intake and 034 Intake Tube | RSE Heat Shielded HFCs | CTS Downpipes with Vibrant UQ Resonators Added | AWE Touring Exhaust | 034 RSB | Bilstein B8 Shocks and H&R -3 Springs | ECS Trans and Drivetrain Inserts | 034 Trans and Motor Mounts | Moog Front End Links | Headlight Projector Retrofit and Painted Housings
    Junior Member Two Rings
    Mar 06 2020
    Fort Worth TX
    Does anyone uses the one from ECS? I want a tool that doesn’t rely on a laptop or android device.
    Mfg Part #
    007868SCH01B
    ECS Part #
    ES#2996394
    Brand
    Schwaben by Foxwell
    Apr 23 2020
    Raleigh, NC
    I want more than just clearing the service due but wanted a good priced product knowing it works.
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    The gold standard for consumer VAGCOM access is RossTech VCDS. The three VIN version is only $199. It does scanning, including deep soft code scanning (error codes that don't trigger a light), clears codes, data logs, and permits recoding of most of the modules on the car. Its software is regularly updated with new features.
    It runs on Windows 10 laptop or tablet connected by USB cable to your OBD-II port. The purchase also includes access to their cloud-based FAQs, user board, and even personalized email tech support for difficult diagnostic problems.
    Worth every penny.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    Dec 01 2020
    2014 Q5 2.0T
    I bought a laptop for exclusive VCDS use for $35 on Craigslist, upgraded it to Windows10 (free), and spent $70 on NewEgg/Amazon to swap out the HDD to a SSD and add 8 GB RAM. Thing runs fast as lightening now for this use. If I ever sell my VCDS remaining 2 VIN's I would probably just sell it with the laptop, pretty sure it would add more value than the $100 I have invested in it.
    Veteran Member Four Rings ILVTRANCE's Avatar
    Dec 19 2012
    New York
    I use carista. not vin limited and works on almost every car make. May not be as powerful as VCDS but it does everything I need and more.
    2014 SQ5 P+ | 034 Stage 2 ECU + TCU | 034 190mm crank pully | 034 Street Density motor mounts | 034Motorsport S34 Carbon Fiber Intake | Merc Racing HX V3 | Bilstein B8's w/ H&R Springs | 034 Trans insert | RSNAV 10.25
    NEW EDM MIX APRIL 2021 https://soundcloud.com/matt-scheinwa...in-my-basement
    Mar 07 2020
    Minnesota
    I use OBD11 and it works fine for more than just the service reminders. I like that I always have it with me. At the time I thought the $80 I paid was worth it vs. vcds but I had to upgrade to pro to get what I needed to code a trailer module, so now I'm at $150 or so. In retrospect I should have just gotten VCDS.
    Nov 22 2014
    Cheshire, CT
    Quote Originally Posted by DTM_SQ5 View Post
    Mfg Part #
    007868SCH01B
    ECS Part #
    ES#2996394
    Brand
    Schwaben by Foxwell
    Could not get the ECS ProSan to reset service light - customer service wasn't able to help. I went with Carista.
    Mar 06 2020
    Fort Worth TX
    Quote Originally Posted by silver_tt View Post
    I don’t think I’m that tech savvy. I hate that you need electronics to do simple shit like rear rotors and adjusting headlights.
    Thanks for your reply also sevarino.
    Veteran Member Four Rings spijun's Avatar
    Oct 10 2010
    Audi Q5 2.0TFSI S tronic
    Sarajevo, BiH
    Mfg Part #
    007868SCH01B
    ECS Part #
    ES#2996394
    Brand
    Schwaben by Foxwell
    Sorry but this is bullshit. Professional VW / Audi Scan Tool that does not support vehicles from 2017 (B9, Q5 Typ 80A ..... and ....)
    Buy VCDS for a little more money, it's proven software and hardware from hundreds of users
    OBDeleven and Carista have a simple interface, so that the average user can make some changes he wants
    ODIS S and ODIS E are the only two VW official software
    ODIS S and ODIS E have no limits, but you can also do damage especially with ODIS E if you don't know what you are doing
    Another extremely good software and hardware is VCP (old name VAG Can PRO )
    And Abrites Diagnostics tool and .......
