Most recent was my BMW 128i Cab.
Of course my 2017 A3 Cab was next up. This was MUCH easier than the BMW. No need to remove the lights and bumper cover and bumper. Just bolt it on, mostly.
Curt hitch, with wiring kit, $215. Not bad.
The kit comes with the appropriate bolts, flange supports, and even fish tools to install it.
Install the fish wire on the bolt and flange, fish in the wire, grab it with a curved pic, and the bolts are ready. Be careful, you do not want to push the bolt out of the hole installing the hitch. I used a shop stool with a piston riser to lift the hitch slowly into position.
Found the two inner bolts on the rear bumper restricted movement, so I removed them, then carefully lifted up the hitch, gently added the retaining nuts while holding the bolts in place with a hook pick, and got all four bolts started without pushing the bolts up into the holes. Once that was done, it was easy to tighten them down to 110NM. Basically the hitch is now done.
The hitch fits up high and tight, with it showing, but only if you are looking for it. Nice kit!
Total install time, doing it alone, 45 minutes. With two people, maybe half an hour. If all you want is to haul bicycles around, you are done.
For me, I also haul a trailer with stuff in it, so I need to wire up the car for the trailer. Problem is, I am not yet sure what wire is brake, left and right signal, and running lights. Ideas?
